[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-18-g4cc9d7a
Sun Nov 29 17:32:48 PST 2020
the project "PostGIS".
       via  4cc9d7adb122726047646648bd75e2972cd6c7b4 (commit)
       via  1d03bb67e1ce84c65b14c62eaa239d88f0dff86b (commit)
       via  dad434d9795682a3751c801cfc46b748d76ad385 (commit)
      from  ed1de589b145cf1b02f68c2a04b6d211f0c62889 (commit)
revisions in full, below.
commit 4cc9d7adb122726047646648bd75e2972cd6c7b4
Merge: ed1de58 1d03bb6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Sun Nov 29 17:32:40 2020 -0800
    Merge branch 'rouault-fix_ST_GeomFromGML'
commit 1d03bb67e1ce84c65b14c62eaa239d88f0dff86b
Merge: ed1de58 dad434d
Date:   Sun Nov 29 17:28:10 2020 -0800
    Merge branch 'fix_ST_GeomFromGML' of https://github.com/rouault/postgis into rouault-fix_ST_GeomFromGML
commit dad434d9795682a3751c801cfc46b748d76ad385
Author: Even Rouault <even.rouault at spatialys.com>
Date:   Fri Nov 27 19:07:11 2020 +0100
    ST_GeomFromGML(): fix axis order issue with urn:ogc:def:crs:EPSG:: syntax on projected CRS with northing,easting axis order
    It was assumed that coordinate swapping was only necessary on geographic CRS
    when srsName='urn:ogc:def:crs:EPSG::XXXX', but there are projected CRS such
    as EPSG:2393 that have a northing,easting axis order too.
    This is very similar to a TinyOWS fix I just did in
    https://github.com/MapServer/tinyows/pull/94
diff --git a/postgis/lwgeom_in_gml.c b/postgis/lwgeom_in_gml.c
index f5028c6..eeb4356 100644
--- a/postgis/lwgeom_in_gml.c
+++ b/postgis/lwgeom_in_gml.c
@@ -384,25 +384,25 @@ gml_reproject_pa(POINTARRAY *pa, int32_t epsg_in, int32_t epsg_out)
- * Return 1 if given srid is planar (0 otherwise, i.e geocentric srid)
- * Return -1 if srid is not in spatial_ref_sys
+ * Return 1 if the SRS definition from the authority has a GIS friendly order,
+ * that is easting,northing. This is typically true for most projected CRS
+ * (but not all!), and this is false for EPSG geographic CRS.
 static int
-gml_is_srid_planar(int32_t srid)
+gml_is_srs_axis_order_gis_friendly(int32_t srid)
-	char *result;
+	char *srtext;
 	char query[256];
-	int is_planar, err;
+	int is_axis_order_gis_friendly, err;
 	if (SPI_OK_CONNECT != SPI_connect ())
-		lwpgerror("gml_is_srid_planar: could not connect to SPI manager");
+		lwpgerror("gml_is_srs_axis_order_gis_friendly: could not connect to SPI manager");
-	/* A way to find if this projection is planar or geocentric */
-	sprintf(query, "SELECT position('+units=m ' in proj4text) \
+	sprintf(query, "SELECT srtext \
                         FROM spatial_ref_sys WHERE srid='%d'", srid);
 	err = SPI_exec(query, 1);
-	if (err < 0) lwpgerror("gml_is_srid_planar: error executing query %d", err);
+	if (err < 0) lwpgerror("gml_is_srs_axis_order_gis_friendly: error executing query %d", err);
 	/* No entry in spatial_ref_sys */
 	if (SPI_processed <= 0)
@@ -411,11 +411,49 @@ gml_is_srid_planar(int32_t srid)
 		return -1;
-	result = SPI_getvalue(SPI_tuptable->vals[0], SPI_tuptable->tupdesc, 1);
-	is_planar = atoi(result);
+	srtext = SPI_getvalue(SPI_tuptable->vals[0], SPI_tuptable->tupdesc, 1);
+	is_axis_order_gis_friendly = 1;
+	if (srtext && srtext[0] != '\0')
+		char* ptr;
+		char* srtext_horizontal = (char*) malloc(strlen(srtext) + 1);
+		strcpy(srtext_horizontal, srtext);
+		/* Remove the VERT_CS part if we are in a COMPD_CS */
+		ptr = strstr(srtext_horizontal, ",VERT_CS[");
+		if (ptr)
+			*ptr = '\0';
+		if( strstr(srtext_horizontal, "AXIS[") == NULL &&
+		    strstr(srtext_horizontal, "GEOCCS[") == NULL )
+			/* If there is no axis definition, then due to how GDAL < 3
+			* generated the WKT, this means that the axis order is not
+			* GIS friendly */
+			is_axis_order_gis_friendly = 0;
+		else if( strstr(srtext_horizontal,
+		           "AXIS[\"Latitude\",NORTH],AXIS[\"Longitude\",EAST]") != NULL )
+		           "AXIS[\"Northing\",NORTH],AXIS[\"Easting\",EAST]") != NULL )
+		           "AXIS[\"geodetic latitude (Lat)\",north,ORDER[1]") != NULL )
+		free(srtext_horizontal);
 	SPI_finish();
-	return is_planar;
+	return is_axis_order_gis_friendly;
@@ -425,10 +463,10 @@ gml_is_srid_planar(int32_t srid)
 static void parse_gml_srs(xmlNodePtr xnode, gmlSrs *srs)
 	char *p;
-	int is_planar;
+	int is_axis_order_gis_friendly;
 	xmlNodePtr node;
 	xmlChar *srsname;
-	bool latlon = false;
+	bool honours_authority_axis_order = false;
 	char sep = ':';
 	node = xnode;
@@ -466,20 +504,20 @@ static void parse_gml_srs(xmlNodePtr xnode, gmlSrs *srs)
 		if (!strncmp((char *) srsname, "EPSG:", 5))
 			sep = ':';
-			latlon = false;
+			honours_authority_axis_order = false;
 		else if (!strncmp((char *) srsname, "urn:ogc:def:crs:EPSG:", 21)
 		         || !strncmp((char *) srsname, "urn:x-ogc:def:crs:EPSG:", 23)
 		         || !strncmp((char *) srsname, "urn:EPSG:geographicCRS:", 23))
 			sep = ':';
-			latlon = true;
+			honours_authority_axis_order = true;
 		                  "http://www.opengis.net/gml/srs/epsg.xml#", 40))
 			sep = '#';
-			latlon = false;
 		else gml_lwpgerror("unknown spatial reference system", 4);
@@ -491,12 +529,14 @@ static void parse_gml_srs(xmlNodePtr xnode, gmlSrs *srs)
 		srs->srid = atoi(++p);
 		/* Check into spatial_ref_sys that this SRID really exist */
-		is_planar = gml_is_srid_planar(srs->srid);
-		if (srs->srid == SRID_UNKNOWN || is_planar == -1)
+		is_axis_order_gis_friendly = gml_is_srs_axis_order_gis_friendly(srs->srid);
+		if (srs->srid == SRID_UNKNOWN || is_axis_order_gis_friendly == -1)
 			gml_lwpgerror("unknown spatial reference system", 6);
-		/* About lat/lon issue, Cf: http://tinyurl.com/yjpr55z */
-		srs->reverse_axis = !is_planar && latlon;
+		/* Reverse axis order if the srsName is meant to honour the axis
+		   order defined by the authority and if that axis order is not
+		   the GIS friendly one. */
+		srs->reverse_axis = !is_axis_order_gis_friendly && honours_authority_axis_order;
 		xmlFree(srsname);
 		return;
diff --git a/regress/core/in_gml.sql b/regress/core/in_gml.sql
index 3b0dec6..0c6867c 100644
--- a/regress/core/in_gml.sql
+++ b/regress/core/in_gml.sql
@@ -636,6 +636,30 @@ SELECT 'srs_16', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="EPSG:-1"><gml:pos
 -- Reverse axis with all kind of simples geometry types
 SELECT 'srs_17', ST_AsEWKT(ST_GeomFromGML('<gml:MultiGeometry srsName="urn:ogc:def:crs:EPSG::4326"><gml:geometryMember><gml:Point><gml:pos srsDimension="2">1 2</gml:pos></gml:Point></gml:geometryMember><gml:geometryMember><gml:LineString><gml:posList srsDimension="2">3 4 5 6</gml:posList></gml:LineString></gml:geometryMember><gml:geometryMember><gml:Curve><gml:segments><gml:LineStringSegment><gml:posList srsDimension="2">7 8 9 10</gml:posList></gml:LineStringSegment></gml:segments></gml:Curve></gml:geometryMember><gml:geometryMember><gml:Polygon><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">11 12 13 14 15 16 11 12</gml:posList></gml:LinearRing></gml:exterior><gml:interior><gml:LinearRing><gml:posList srsDimension="2">17 18 19 20 21 22 17 18</gml:posList></gml:LinearRing></gml:interior></gml:Polygon></gml:geometryMember><gml:geometryMember><gml:Surface><gml:patches><gml:PolygonPatch><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">23 24 25 26 27 28 23 24</gml
 :posList></gml:LinearRing></gml:exterior><gml:interior><gml:LinearRing><gml:posList srsDimension="2">25 26 27 28 29 30 25 26</gml:posList></gml:LinearRing></gml:interior></gml:PolygonPatch></gml:patches></gml:Surface></gml:geometryMember></gml:MultiGeometry>'));
+-- Projected CRS with AXIS["Easting",EAST],AXIS["Northing",NORTH]. No coordinate swapping
+SELECT 'srs_18', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::32631"><gml:pos>500000 0</gml:pos></gml:Point>'));
+-- Projected CRS with northing, easting axis order, but with no explicit AXIS (EPSG 2393: KKJ / Finland Uniform Coordinate System). We must swap the coordinates
+SELECT 'srs_19', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::2393"><gml:pos>6000000 3500000</gml:pos></gml:Point>'));
+-- Geocentric CRS with explicit geocentric AXIS (WGS 84 geocentric). No coordinate swapping
+SELECT 'srs_20', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::4978"><gml:pos srsDimension="3">1 2 3</gml:pos></gml:Point>'));
+-- Geographic 3D CRS with AXIS["geodetic latitude (Lat)",north,ORDER[1],...] (WGS 84 with ellipsoidal height). We must swap coordinates
+SELECT 'srs_21', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::4979"><gml:pos srsDimension="3">49 2 3</gml:pos></gml:Point>'));
+-- BoundCRS of a Geographic 2D CRS with AXIS["latitude",north,ORDER[1],...] (EPSG 4985: WGS 72 BE). We must swap coordinates
+SELECT 'srs_22', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::4985"><gml:pos>49 2</gml:pos></gml:Point>'));
+-- Projected CRS with empty srtext (EPSG 8857 : WGS 84 / Equal Earth Greenwich). We assume GIS friendly order (which is the case here)
+SELECT 'srs_23', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::8857"><gml:pos>1 2</gml:pos></gml:Point>'));
+-- CompoundCRS of a Geographic CRS (EPSG 8360 : ETRS89 + Baltic 1957 height). We must swap coordinates
+SELECT 'srs_24', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::8360"><gml:pos srsDimension="3">49 2 3</gml:pos></gml:Point>'));
+-- Projected CRS with AXIS["Northing",NORTH],AXIS["Easting",EAST] in its definition (EPSG 8433 : Macao 1920 / Macao Grid). We must swap coordinates
+SELECT 'srs_25', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::8433"><gml:pos>2 1</gml:pos></gml:Point>'));
 -- Reverse axis with severals multi geometry types
 -- TODO
diff --git a/regress/core/in_gml_expected b/regress/core/in_gml_expected
index 9c88d5a..ecf9ae9 100644
--- a/regress/core/in_gml_expected
+++ b/regress/core/in_gml_expected
@@ -215,6 +215,14 @@ ERROR:  unknown spatial reference system
 srs_17|SRID=4326;GEOMETRYCOLLECTION(POINT(2 1),LINESTRING(4 3,6 5),LINESTRING(8 7,10 9),POLYGON((12 11,14 13,16 15,12 11),(18 17,20 19,22 21,18 17)),POLYGON((24 23,26 25,28 27,24 23),(26 25,28 27,30 29,26 25)))
+srs_18|SRID=32631;POINT(500000 0)
+srs_19|SRID=2393;POINT(3500000 6000000)
+srs_20|SRID=4978;POINT(1 2 3)
+srs_21|SRID=4979;POINT(2 49 3)
+srs_22|SRID=4985;POINT(2 49)
+srs_23|SRID=8857;POINT(1 2)
+srs_24|SRID=8360;POINT(2 49 3)
+srs_25|SRID=8433;POINT(1 2)
 ns_1|POINT(1 2)
 ns_2|POINT(1 2)
 ns_3|POINT(1 2)
Summary of changes:
 postgis/lwgeom_in_gml.c      | 82 ++++++++++++++++++++++++++++++++------------
 regress/core/in_gml.sql      | 24 +++++++++++++
 regress/core/in_gml_expected |  8 +++++
 3 files changed, 93 insertions(+), 21 deletions(-)
hooks/post-receive
