[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-19-g99128ad
Mon Nov 30 10:06:54 PST 2020
the project "PostGIS".
       via  99128ad0195da994e0cc82648008103adab75f61 (commit)
      from  4cc9d7adb122726047646648bd75e2972cd6c7b4 (commit)
revisions in full, below.
commit 99128ad0195da994e0cc82648008103adab75f61
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon Nov 30 10:06:35 2020 -0800
    Make Doc Ref Overlay functions gridsize optionality clear
    Signed-off-by: Martin Davis <mtnclimb at gmail.com>
diff --git a/doc/reference_overlay.xml b/doc/reference_overlay.xml
index 6175aa9..4c9f637 100644
--- a/doc/reference_overlay.xml
+++ b/doc/reference_overlay.xml
@@ -88,7 +88,7 @@ SELECT ST_ClipByBox2D(the_geom, ST_MakeEnvelope(0,0,10,10)) FROM mytab;
         <note><para>Order matters. B - A will always return a portion of B</para></note>
             <para>
-If a gridSize argument is provided, the inputs are
+If the optional <code>gridSize</code> argument is provided, the inputs are
 snapped to a grid of the given size and all intersections are computed
 on that same grid. This method requires GEOS-3.9.0 or higher.
             </para>
@@ -190,7 +190,7 @@ Returns a geometry that represents the shared portion of geomA and geomB.
                     </paramdef>
                     <paramdef choice="opt">
                         <type>float8</type>
-                        <parameter>gridSize</parameter>
+                        <parameter>gridSize = -1</parameter>
                     </paramdef>
                 </funcprototype>
                 <funcprototype>
@@ -219,7 +219,7 @@ Returns a geometry that represents the shared portion of geomA and geomB.
                 queries where you only want to return that portion of a geometry that sits in a country or region of interest.</para>
             <para>
             </para>
@@ -596,7 +596,7 @@ GEOMETRYCOLLECTION(
                 <funcdef>setof geometry <function>ST_Subdivide</function></funcdef>
                 <paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
                 <paramdef><type>integer</type> <parameter>max_vertices=256</parameter></paramdef>
-                <paramdef choice="opt"><type>float8</type> <parameter>gridSize</parameter></paramdef>
+                <paramdef choice="opt"><type>float8</type> <parameter>gridSize = -1</parameter></paramdef>
             </funcprototype>
         </funcsynopsis>
     </refsynopsisdiv>
@@ -711,7 +711,7 @@ LINESTRING(44.7994523421035 82.5156766227011,85 85)</screen>
             <funcdef>geometry <function>ST_SymDifference</function></funcdef>
             <paramdef><type>geometry </type> <parameter>geomA</parameter></paramdef>
             <paramdef><type>geometry </type> <parameter>geomB</parameter></paramdef>
-            <paramdef choice="opt"><type>float8 </type> <parameter>gridSize</parameter></paramdef>
+            <paramdef choice="opt"><type>float8 </type> <parameter>gridSize = -1</parameter></paramdef>
           </funcprototype>
         </funcsynopsis>
       </refsynopsisdiv>
@@ -725,7 +725,7 @@ LINESTRING(44.7994523421035 82.5156766227011,85 85)</screen>
             </para>
             <para>
             </para>
@@ -975,7 +975,7 @@ MULTILINESTRING((3 4,4 5),(1 2,3 4))
           <funcprototype>
             <funcdef>geometry <function>ST_UnaryUnion</function></funcdef>
             <paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
           </funcprototype>
         </funcsynopsis>
@@ -1003,7 +1003,7 @@ MULTILINESTRING((3 4,4 5),(1 2,3 4))
         </para>
         <para>
         </para>
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 7d6f3b7..7343169 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -27,7 +27,7 @@ from a geometry.
                     <funcdef>geometry <function>ST_Buffer</function></funcdef>
                     <paramdef><type>geometry </type> <parameter>g1</parameter></paramdef>
                     <paramdef><type>float </type> <parameter>radius_of_buffer</parameter></paramdef>
-                    <paramdef choice="opt"><type>text </type> <parameter>buffer_style_parameters=''</parameter></paramdef>
+                    <paramdef choice="opt"><type>text </type> <parameter>buffer_style_parameters = ''</parameter></paramdef>
                   </funcprototype>
                   <funcprototype>
Summary of changes:
 doc/reference_overlay.xml    | 16 ++++++++--------
 doc/reference_processing.xml |  2 +-
 2 files changed, 9 insertions(+), 9 deletions(-)
hooks/post-receive
