[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-141-g49e381b
Thu Apr 15 10:27:12 PDT 2021
the project "PostGIS".
       via  49e381b6b5fb76770ff30af2fedfec766ececd11 (commit)
      from  338783e1d7fde6ae0f71fa9ecb0c3aa6599b8e0d (commit)
revisions in full, below.
commit 49e381b6b5fb76770ff30af2fedfec766ececd11
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Apr 15 10:27:02 2021 -0700
    Update doc ST_AsText
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index dd75bb5..842e601 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -114,7 +114,7 @@ CIRCULARSTRING(220268 150415 1,220227 150505 2,220227 150406 3)
 			  <funcprototype>
 				<funcdef>text <function>ST_AsText</function></funcdef>
 				<paramdef><type>geometry </type> <parameter>g1</parameter></paramdef>
-				<paramdef choice="opt"><type>integer </type> <parameter>maxdecimaldigits=15</parameter></paramdef>
+				<paramdef choice="opt"><type>integer </type> <parameter>maxdecimaldigits = 15</parameter></paramdef>
 			  </funcprototype>
 			  <funcprototype>
@@ -123,7 +123,7 @@ CIRCULARSTRING(220268 150415 1,220227 150505 2,220227 150406 3)
 			  <funcprototype>
 				<paramdef><type>geography </type> <parameter>g1</parameter></paramdef>
 			  </funcprototype>
 			</funcsynopsis>
 		  </refsynopsisdiv>
@@ -131,19 +131,24 @@ CIRCULARSTRING(220268 150415 1,220227 150505 2,220227 150406 3)
 		  <refsection>
 			<title>Description</title>
-			<para>Returns the Well-Known Text representation of the geometry/geography. Optional argument may be used to reduce the maximum number
-			of decimal digits after floating point used in output (defaults to 15).</para>
+			<para>Returns the <link linkend="OpenGISWKBWKT">Well-Known Text</link> (WKT) representation of the geometry/geography.
+            The optional <parameter>maxdecimaldigits</parameter> argument may be used to limit the number
+			of digits after the decimal point in output ordinates (defaults to 15).</para>
+			<para>To perform the inverse conversion of WKT representation to PostGIS geometry
+            use <xref linkend="ST_GeomFromText" />.</para>
 			<note>
-			  <para>The WKT spec does not include the SRID.  To get the SRID as part of the data, use the non-standard
-				PostGIS <xref linkend="ST_AsEWKT" /></para>
+			  <para>The standard OGC WKT representation does not include the SRID.
+              To include the SRID as part of the output representation, use the non-standard
+				PostGIS function <xref linkend="ST_AsEWKT" /></para>
 			</note>
       <warning>
-			<para>WKT format does not maintain precision so to prevent floating truncation, use ST_AsBinary or ST_AsEWKB format for transport.</para>
+			<para>The textual representation of numbers in WKT may not maintain full floating-point precision.
+            To ensure full accuracy for data storage or transport it is best to use
+            <link linkend="OpenGISWKBWKT">Well-Known Binary</link> (WKB) format
+            (see  <xref linkend="ST_AsBinary" /> and <xref linkend="ST_AsEWKB" />).</para>
       </warning>
-			<note>
-			  <para>ST_AsText is the reverse of <xref linkend="ST_GeomFromText" />.  Use <xref linkend="ST_GeomFromText" /> to convert to a postgis geometry from ST_AsText representation.</para>
-			</note>
 			<para>Availability: 1.5 - support for geography was introduced.</para>
 			<para>Enhanced: 2.5 - optional parameter precision introduced.</para>
@@ -160,24 +165,24 @@ CIRCULARSTRING(220268 150415 1,220227 150505 2,220227 150406 3)
 F03F000000000000F03F000000000000F03F000000000000F03
 F000000000000000000000000000000000000000000000000');
-		   st_astext
+    st_astext
  POLYGON((0 0,0 1,1 1,1 0,0 0))
-(1 row)</programlisting>
-			<para>Providing the precision is optional.</para>
+</programlisting>
-			<programlisting>SELECT ST_AsText(GeomFromEWKT('SRID=4326;POINT(111.1111111 1.1111111)'))
-          st_astext
+<para>Full precision output is the default.</para>
+			<programlisting>SELECT ST_AsText('POINT(111.1111111 1.1111111)'));
+    st_astext
+</programlisting>
-			<programlisting>SELECT ST_AsText(GeomFromEWKT('SRID=4326;POINT(111.1111111 1.1111111)'),2)
-st_astext
+<para>The <parameter>maxdecimaldigits</parameter> argument can be used to limit output precision.</para>
+			<programlisting>SELECT ST_AsText('POINT(111.1111111 1.1111111)'), 2);
+    st_astext
-POINT(111.11 1.11)
+ POINT(111.11 1.11)
+</programlisting>
 		  </refsection>
 		  <!-- Optionally add a "See Also" section -->
Summary of changes:
 doc/reference_output.xml | 47 ++++++++++++++++++++++++++---------------------
 1 file changed, 26 insertions(+), 21 deletions(-)
hooks/post-receive
