[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-142-g9114db6
Thu Apr 15 21:39:32 PDT 2021
the project "PostGIS".
       via  9114db6bf3fdbc2b8050460cf1eaca2c68f8b321 (commit)
      from  49e381b6b5fb76770ff30af2fedfec766ececd11 (commit)
revisions in full, below.
commit 9114db6bf3fdbc2b8050460cf1eaca2c68f8b321
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Apr 16 00:39:24 2021 -0400
    Add a What's new in 3.2 section
diff --git a/doc/xsl/postgis_aggs_mm.xml.xsl b/doc/xsl/postgis_aggs_mm.xml.xsl
index 150dbc9..27273ee 100644
--- a/doc/xsl/postgis_aggs_mm.xml.xsl
+++ b/doc/xsl/postgis_aggs_mm.xml.xsl
@@ -1,9 +1,11 @@
 <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
-	 Copyright 2010, Regina Obe
+	 Copyright 2010-2021, Regina Obe
 	 License: BSD
-	 Purpose: This is an xsl transform that generates index listing of aggregate functions and mm /sql compliant functions xml section from reference_new.xml to then
+	 Purpose: This is an xsl transform that generates file postgis_aggs_mm.xml which
+	 includes index listing of aggregate functions and mm /sql compliant functions as well as what is new in each release
+	 It uses xml reference sections from reference.xml to then
 	 be processed by doc book
 	<xsl:output method="xml" indent="yes" encoding="utf-8" />
@@ -483,6 +485,106 @@
 	   <sect1 id="NewFunctions">
 			<title>New, Enhanced or changed PostGIS Functions</title>
+			<sect2 id="NewFunctions_3_2">
+				<title>PostGIS Functions new or enhanced in 3.2</title>
+				<para>The functions given below are PostGIS functions that were added or enhanced.</para>
+        <xsl:if test="//para[contains(text(),'Availability: 3.2')]">
+				<para>Functions new in PostGIS 3.2</para>
+				<itemizedlist>
+				<!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment  -->
+					<xsl:for-each select='//refentry'>
+						<xsl:sort select="refnamediv/refname"/>
+						<xsl:variable name='comment'>
+							<xsl:value-of select="normalize-space(translate(translate(refnamediv/refpurpose,'&#x0d;&#x0a;', ' '), '	', ' '))"/>
+						</xsl:variable>
+						<xsl:variable name="refid">
+							<xsl:value-of select="@id" />
+						</xsl:variable>
+						<xsl:variable name="refname">
+							<xsl:value-of select="refnamediv/refname" />
+						</xsl:variable>
+				<!-- For each section if there is note about availability in this version -->
+							<xsl:for-each select="refsection">
+								<xsl:for-each select="para | */para">
+									<xsl:choose>
+										<xsl:when test="contains(.,'Availability: 3.2')">
+											<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="." /><xsl:text> </xsl:text> <xsl:value-of select="$comment" /></simpara></listitem>
+										</xsl:when>
+									</xsl:choose>
+								</xsl:for-each>
+							</xsl:for-each>
+					</xsl:for-each>
+				</itemizedlist>
+        </xsl:if>
+				<xsl:if test="//para[contains(text(),'Enhanced: 3.2')]">
+				<para>Functions enhanced in PostGIS 3.2</para>
+				<itemizedlist>
+						</xsl:variable>
+						</xsl:variable>
+						</xsl:variable>
+									<xsl:choose>
+										<xsl:when test="contains(.,'Enhanced: 3.2')">
+										</xsl:when>
+									</xsl:choose>
+								</xsl:for-each>
+							</xsl:for-each>
+					</xsl:for-each>
+				</itemizedlist>
+			</xsl:if>
+			<para>Functions changed in PostGIS 3.2</para>
+				<xsl:if test="//para[contains(text(),'Changed: 3.2')]">
+				<itemizedlist>
+						</xsl:variable>
+						</xsl:variable>
+						</xsl:variable>
+									<xsl:choose>
+										<xsl:when test="contains(.,'Changed: 3.2')">
+										</xsl:when>
+									</xsl:choose>
+								</xsl:for-each>
+							</xsl:for-each>
+					</xsl:for-each>
+				</itemizedlist>
+				</xsl:if>
+			</sect2>
 			<sect2 id="NewFunctions_3_1">
 				<title>PostGIS Functions new or enhanced in 3.1</title>
@@ -583,7 +685,7 @@
 				</itemizedlist>
 				</xsl:if>
 			</sect2>
 			<sect2 id="NewFunctions_3_0">
 				<title>PostGIS Functions new or enhanced in 3.0</title>
Summary of changes:
 doc/xsl/postgis_aggs_mm.xml.xsl | 108 ++++++++++++++++++++++++++++++++++++++--
 1 file changed, 105 insertions(+), 3 deletions(-)
hooks/post-receive
