[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-143-gf6e6939
Fri Apr 16 14:12:48 PDT 2021
the project "PostGIS".
       via  f6e693915a819d82471124ef938e3d45167137a4 (commit)
      from  9114db6bf3fdbc2b8050460cf1eaca2c68f8b321 (commit)
revisions in full, below.
commit f6e693915a819d82471124ef938e3d45167137a4
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Apr 16 17:12:42 2021 -0400
    Fix ST_InterpolateRaster example. Mark template_band_num are default 1
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index f7eef4e..e824bf6 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -1472,7 +1472,7 @@ FROM c;</programlisting>
             <paramdef><type>geometry </type><parameter>input_points</parameter></paramdef>
             <paramdef><type>text </type><parameter>algorithm_options</parameter></paramdef>
             <paramdef><type>raster </type><parameter>template</parameter></paramdef>
-            <paramdef><type>integer </type><parameter>template_band_num</parameter></paramdef>
+            <paramdef choice="opt"><type>integer </type><parameter>template_band_num=1</parameter></paramdef>
           </funcprototype>
         </funcsynopsis>
       </refsynopsisdiv>
@@ -1532,8 +1532,8 @@ FROM c;</programlisting>
 <programlisting>SELECT ST_InterpolateRaster(
     'MULTIPOINT(10.5 9.5 1000, 11.5 8.5 1000, 10.5 8.5 500, 11.5 9.5 500)'::geometry,
-    ST_AddBand(ST_MakeEmptyRaster(200, 400, 10, 10, 0.01, -0.005, 0, 0), '16BSI'),
-    'invdist:smoothing:2.0'
+    'invdist:smoothing:2.0',
+    ST_AddBand(ST_MakeEmptyRaster(200, 400, 10, 10, 0.01, -0.005, 0, 0), '16BSI')
 )</programlisting>
         </refsection>
Summary of changes:
 doc/reference_raster.xml | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
