[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-144-gdabd772
Mon Apr 19 12:35:59 PDT 2021
the project "PostGIS".
       via  dabd7723201a2efed06fd3d3e77c35e5cec7e44b (commit)
      from  f6e693915a819d82471124ef938e3d45167137a4 (commit)
revisions in full, below.
commit dabd7723201a2efed06fd3d3e77c35e5cec7e44b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Apr 19 12:34:21 2021 -0700
    Add functions ST_SetZ()/ST_SetM()
    that fill in z/m coordinates of a geometry using data read
    from a raster. Also adds 'bilinear' interpolation mode
    to ST_Value() to allow sampling between pixes in reading
    values from rasters.
diff --git a/NEWS b/NEWS
index 2d92e2d..bfc48bc 100644
--- a/NEWS
+++ b/NEWS
@@ -10,11 +10,21 @@ PostGIS 3.2.0
            (Sandro Santilli)
   - #4827, Allow NaN coordinates in WKT input (Paul Ramsey)
   - #4870, Allow open options to be passed to GDAL drivers (Paul Ramsey)
+  - ST_Value() accepts resample parameter to add bilinear option (Paul Ramsey)
   - #3778, #4401, ST_Boundary now works for TIN and does not linearize curves (Aliaksandr Kalenik)
  * New features*
   - #4841, FindTopology to quickly get a topology record (Sandro Santilli)
   - #4851, TopoGeom_addTopoGeom function (Sandro Santilli)
+  - ST_InterpolateRaster() fills in raster cells between sample points
+    using one of a number of algorithms (inverse weighted distance, average, etc)
+    using algorithms from GDAL
+    (Paul Ramsey)
+  - ST_Contour() generates contour lines from raster values
+    using algorithms from GDAL (Paul Ramsey)
+  - ST_SetZ()/ST_SetM() fills in z/m coordinates of a geometry using data read
+    from a raster (Paul Ramsey)
 PostGIS 3.1.0
 2020/12/18
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index e824bf6..b0f5a45 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -5260,6 +5260,151 @@ FROM (
         </refentry>
+        <refentry id="RT_ST_SetZ">
+            <refnamediv>
+                <refname>ST_SetZ</refname>
+                <refpurpose>Returns a geometry with the same X/Y coordinates as the input geometry, and values from the raster copied into the Z dimension using the requested resample algorithm.</refpurpose>
+            </refnamediv>
+            <refsynopsisdiv>
+                <funcsynopsis>
+                   <funcprototype>
+                    <funcdef>geometry <function>ST_GetValues</function></funcdef>
+                    <paramdef><type>raster </type> <parameter>rast</parameter></paramdef>
+                    <paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
+                    <paramdef choice="opt"><type>text </type> <parameter>resample=nearest</parameter></paramdef>
+                    <paramdef choice="opt"><type>integer </type> <parameter>band=1</parameter></paramdef>
+                  </funcprototype>
+                </funcsynopsis>
+            </refsynopsisdiv>
+            <refsection>
+                <title>Description</title>
+                <para>Returns a geometry with the same X/Y coordinates as the input geometry, and values from the raster copied into the Z dimensions using the requested resample algorithm.</para>
+                <para>The <varname>resample</varname> parameter can be set to "nearest" to copy the values from the cell each vertex falls within, or "bilinear" to use <ulink url="https://en.wikipedia.org/wiki/Bilinear_interpolation">bilinear interpolation</ulink> to calculate a value that takes neighboring cells into account also.</para>
+            </refsection>
+                <refsection>
+                    <title>Examples</title>
+                    <programlisting>--
+-- 2x2 test raster with values
+-- 10 50
+-- 40 20
+WITH test_raster AS (
+SELECT
+ST_SetValues(
+  ST_AddBand(
+    ST_MakeEmptyRaster(width => 2, height => 2,
+      upperleftx => 0, upperlefty => 2,
+      scalex => 1.0, scaley => -1.0,
+      skewx => 0, skewy => 0, srid => 4326),
+    index => 1, pixeltype => '16BSI',
+    initialvalue => 0,
+    nodataval => -999),
+  1,1,1,
+  newvalueset =>ARRAY[ARRAY[10.0::float8, 50.0::float8], ARRAY[40.0::float8, 20.0::float8]]) AS rast
+SELECT
+ST_AsText(
+  ST_SetZ(
+    rast,
+    band => 1,
+    geom => 'SRID=4326;LINESTRING(1.0 1.9, 1.0 0.2)'::geometry,
+    resample => 'bilinear'
+FROM test_raster
+            st_astext
+ LINESTRING Z (1 1.9 38,1 0.2 27)</programlisting>
+            </refsection>
+            <refsection>
+                <title>See Also</title>
+                <para>
+                    <xref linkend="RT_ST_Value" />,
+                    <xref linkend="RT_ST_SetM" />
+                </para>
+            </refsection>
+        </refentry>
+        <refentry id="RT_ST_SetM">
+            <refnamediv>
+                <refname>ST_SetM</refname>
+            </refnamediv>
+            <refsynopsisdiv>
+                <funcsynopsis>
+                   <funcprototype>
+                  </funcprototype>
+                </funcsynopsis>
+            </refsynopsisdiv>
+            <refsection>
+            </refsection>
+                <refsection>
+-- 10 50
+-- 40 20
+SELECT
+ST_SetValues(
+  ST_AddBand(
+  1,1,1,
+SELECT
+ST_AsText(
+  ST_SetM(
+    rast,
+    band => 1,
+FROM test_raster
+            st_astext
+ LINESTRING M (1 1.9 38,1 0.2 27)</programlisting>
+            </refsection>
+            <refsection>
+                <para>
+                    <xref linkend="RT_ST_SetZ" />
+                </para>
+            </refsection>
+        </refentry>
         <refentry id="RT_ST_Neighborhood">
             <refnamediv>
                 <refname>ST_Neighborhood</refname>
diff --git a/raster/rt_core/librtcore.h b/raster/rt_core/librtcore.h
index 97bda9e..8f35f29 100644
--- a/raster/rt_core/librtcore.h
+++ b/raster/rt_core/librtcore.h
@@ -1360,6 +1360,27 @@ rt_errorstate rt_raster_geopoint_to_cell(
 	double *igt
+ * Convert an xw,yw map point to a xr,yr raster point
+ * @param raster : the raster to get info from
+ * @param xw : X ordinate of the geographical point
+ * @param yw : Y ordinate of the geographical point
+ * @param xr : output parameter, the x ordinate in raster space
+ * @param yr : output parameter, the y ordinate in raster space
+ * @param igt : input/output parameter, inverse geotransform matrix
+ * @return ES_NONE if success, ES_ERROR if error
+rt_errorstate rt_raster_geopoint_to_rasterpoint(
+	rt_raster raster,
+	double xw, double yw,
+	double *xr, double *yr,
+	double *igt
  * Get raster's convex hull.
@@ -1397,6 +1418,72 @@ rt_errorstate rt_raster_get_envelope(rt_raster raster, rt_envelope *env);
 rt_errorstate rt_raster_get_envelope_geom(rt_raster raster, LWGEOM **env);
+ * Retrieve a point value from the raster using a world coordinate
+ * and bilinear interpolation.
+ * @param band : the band to read for values
+ * @param xr : x unrounded raster coordinate
+ * @param yr : y unrounded raster coordinate
+ * @param r_value : return pointer for point value
+ * @param r_nodata : return pointer for if this is a nodata
+ * @return ES_ERROR on error, otherwise ES_NONE
+rt_errorstate rt_band_get_pixel_bilinear(
+	rt_band band,
+	double xr, double yr,
+	double *r_value, int *r_nodata
+typedef enum {
+	RT_NEAREST,
+	RT_BILINEAR
+} rt_resample_type;
+ * and selected resampling method.
+ * @param resample : algorithm for reading raster (nearest or bilinear)
+rt_errorstate rt_band_get_pixel_resample(
+	rt_band band,
+	rt_resample_type resample,
+ * Copy values from a raster to the points on a geometry
+ * using the requested interpolation type.
+ * and selected interpolation.
+ * @param raster : the raster to read for values
+ * @param bandnum : the band number to read from
+ * @param dim : the geometry dimension to copy values into 'Z' or 'M'
+ * @param lwgeom_in : the input geometry
+ * @param lwgeom_out : pointer for the output geometry
+rt_errorstate rt_raster_copy_to_geometry(
+	rt_raster raster,
+	uint32_t bandnum,
+	char dim, /* 'Z' or 'M' */
+	const LWGEOM *lwgeom_in,
+	LWGEOM **lwgeom_out
  * Get raster perimeter
  * The perimeter is a 4 vertices (5 to be closed)
diff --git a/raster/rt_core/rt_band.c b/raster/rt_core/rt_band.c
index 60ca2ce..fb6e656 100644
--- a/raster/rt_core/rt_band.c
+++ b/raster/rt_core/rt_band.c
@@ -1206,6 +1206,160 @@ rt_errorstate rt_band_get_pixel_line(
+rt_errorstate
+rt_band_get_pixel_resample(
+	rt_band band,
+	if (resample == RT_BILINEAR) {
+		return rt_band_get_pixel_bilinear(
+			band, xr, yr, r_value, r_nodata
+	else if (resample == RT_NEAREST) {
+		return rt_band_get_pixel(
+			band, floor(xr), floor(yr),
+			r_value, r_nodata
+	else {
+		rtwarn("Invalid resample type requested %d", resample);
+		return ES_ERROR;
+ * @param rast : the raster to read for values
+ * @param bandnum : the band to read for the values
+ * @param xw : x world coordinate in
+ * @param yw : y world coordinate in
+rt_errorstate
+rt_band_get_pixel_bilinear(
+	rt_band band,
+	double *r_value, int *r_nodata)
+	rt_errorstate err;
+	double xcenter, ycenter;
+	double values[2][2];
+	double nodatavalue = 0.0;
+	int   nodatas[2][2];
+	int x[2][2];
+	int y[2][2];
+	int xcell, ycell;
+	int xdir, ydir;
+	int i, j;
+	uint16_t width, height;
+	/* Cell coordinates */
+	xcell = (int)floor(xr);
+	ycell = (int)floor(yr);
+	xcenter = xcell + 0.5;
+	ycenter = ycell + 0.5;
+	/* Raster geometry */
+	width = rt_band_get_width(band);
+	height = rt_band_get_height(band);
+	/* Reject out-of-range sample */
+	if(xcell < 0 || ycell < 0 || xcell >= width || ycell >= height) {
+		rtwarn("Attempting to get pixel value with out of range raster coordinates: (%d, %d)", xcell, ycell);
+		return ES_ERROR;
+	/* Quadrant of 2x2 grid the raster coordinate falls in */
+	xdir = xr < xcenter ? 1 : 0;
+	ydir = yr < ycenter ? 1 : 0;
+	err = rt_band_get_nodata(band, &nodatavalue);
+	if (err != ES_NONE) {
+		nodatavalue = 0.0;
+	/* Read the 2x2 values from the band */
+	for (i = 0; i < 2; i++) {
+		for (j = 0; j < 2; j++) {
+			double value = nodatavalue;
+			int nodata = 0;
+			int xij = xcell + (i - xdir);
+			int yij = ycell + (j - ydir);
+			if(xij < 0 || yij < 0 || xij >= width || yij >= height) {
+				nodata = 1;
+			else {
+				rt_errorstate err = rt_band_get_pixel(
+					band, xij, yij,
+					&value, &nodata
+					nodata = 1;
+			x[i][j] = xij;
+			y[i][j] = yij;
+			values[i][j] = value;
+			nodatas[i][j] = nodata;
+	/* Point falls in nodata cell, just return nodata */
+	if (nodatas[xdir][ydir]) {
+		*r_value = nodatavalue;
+		*r_nodata = 1;
+		return ES_NONE;
+	/* Normalize raster coordinate to the bottom left */
+	/* so we are working on a unit square */
+	xr = xr - (x[0][0] + 0.5);
+	yr = yr - (y[0][0] + 0.5);
+	/* Point is in cell with values, so we take nodata */
+	/* neighbors off the table by matching them to the */
+	/* most controlling cell */
+			if (nodatas[i][j])
+				values[i][j] = values[xdir][ydir];
+	/* Calculate bilinear value */
+	/* https://en.wikipedia.org/wiki/Bilinear_interpolation#Unit_square */
+	*r_nodata = 0;
+	*r_value = values[0][0] * (1-xr) * (1-yr) +
+	           values[1][0] * (1-yr) * xr +
+	           values[0][1] * (1-xr) * yr +
+	           values[1][1] * xr * yr;
+	return ES_NONE;
  * Get pixel value. If band's isnodata flag is TRUE, value returned
  * will be the band's NODATA value
@@ -1637,6 +1791,8 @@ uint32_t rt_band_get_nearest_pixel(
 	return count;
  * Search band for pixel(s) with search values
diff --git a/raster/rt_core/rt_raster.c b/raster/rt_core/rt_raster.c
index e75a89b..7ceecba 100644
--- a/raster/rt_core/rt_raster.c
+++ b/raster/rt_core/rt_raster.c
@@ -789,7 +789,7 @@ rt_raster_cell_to_geopoint(
- * Convert an xw,yw map point to a xr,yr raster point
+ * Convert an xw,yw map point to a xr,yr cell coordinate
@@ -807,8 +807,51 @@ rt_raster_geopoint_to_cell(
 	double *igt
-	double _igt[6] = {0};
 	double rnd = 0;
+	err = rt_raster_geopoint_to_rasterpoint(raster, xw, yw, xr, yr, igt);
+		return err;
+	rnd = ROUND(*xr, 0);
+	if (FLT_EQ(rnd, *xr))
+		*xr = rnd;
+	else
+		*xr = floor(*xr);
+	rnd = ROUND(*yr, 0);
+	if (FLT_EQ(rnd, *yr))
+		*yr = rnd;
+	else
+		*yr = floor(*yr);
+	RASTER_DEBUGF(4, "Corrected GDALApplyGeoTransform (g -> c) for (%f, %f) = (%f, %f)",
+		xw, yw, *xr, *yr);
+	return ES_NONE;
+rt_errorstate
+rt_raster_geopoint_to_rasterpoint(
+	rt_raster raster,
+	double *igt
+	double _igt[6] = {0};
 	assert(NULL != raster);
 	assert(NULL != xr && NULL != yr);
@@ -835,24 +878,10 @@ rt_raster_geopoint_to_cell(
 	RASTER_DEBUGF(4, "GDALApplyGeoTransform (g -> c) for (%f, %f) = (%f, %f)",
 		xw, yw, *xr, *yr);
-	rnd = ROUND(*xr, 0);
-	if (FLT_EQ(rnd, *xr))
-		*xr = rnd;
-	else
-		*xr = floor(*xr);
-	rnd = ROUND(*yr, 0);
-	if (FLT_EQ(rnd, *yr))
-		*yr = rnd;
-	else
-		*yr = floor(*yr);
-	RASTER_DEBUGF(4, "Corrected GDALApplyGeoTransform (g -> c) for (%f, %f) = (%f, %f)",
-		xw, yw, *xr, *yr);
 	return ES_NONE;
 * rt_raster_get_envelope()
@@ -1574,6 +1603,97 @@ rt_raster_clone(rt_raster raster, uint8_t deep) {
+* rt_raster_copy_to_geometry()
+rt_errorstate
+rt_raster_copy_to_geometry(
+	rt_raster raster,
+	uint32_t bandnum,
+	char dim,
+	int has_z = lwgeom_has_z(lwgeom_in);
+	int has_m = lwgeom_has_m(lwgeom_in);
+	LWGEOM *lwgeom;
+	LWPOINTITERATOR* it;
+	POINT4D p;
+	double igt[6] = {0};
+	rt_band band = NULL;
+	/* Get the band reference and read the nodatavalue */
+	band = rt_raster_get_band(raster, bandnum);
+	if (!band) {
+		rterror("unable to read requested band");
+		return ES_ERROR;
+	rt_band_get_nodata(band, &nodatavalue);
+	/* Fluff up geometry to have space for our new dimension */
+	if (dim == 'z') {
+		if (has_z)
+			lwgeom = lwgeom_clone(lwgeom_in);
+		else if (has_m)
+			lwgeom = lwgeom_force_4d(lwgeom_in, nodatavalue, nodatavalue);
+		else
+			lwgeom = lwgeom_force_3dz(lwgeom_in, nodatavalue);
+	else if (dim == 'm') {
+		if (has_m)
+		if (has_z)
+		else
+			lwgeom = lwgeom_force_3dm(lwgeom_in, nodatavalue);
+	else {
+		rterror("unknown value for dim");
+		return ES_ERROR;
+	/* Read every point in the geometry */
+	it = lwpointiterator_create_rw(lwgeom);
+	while (lwpointiterator_has_next(it))
+		int nodata;
+		double xr, yr, value;
+		lwpointiterator_peek(it, &p);
+		/* Convert X/Y world coordinates into raster coordinates */
+		err = rt_raster_geopoint_to_rasterpoint(raster, p.x, p.y, &xr, &yr, igt);
+		if (err != ES_NONE) continue;
+		/* Read the raster value for this point */
+		err = rt_band_get_pixel_resample(
+			band,
+			xr, yr,
+			resample,
+			&value, &nodata
+		/* Copy in the raster value */
+		if (dim == 'z')
+			p.z = value;
+		if (dim == 'm')
+			p.m = value;
+		lwpointiterator_modify_next(it, &p);
+	lwpointiterator_destroy(it);
+	if (lwgeom_out)
+		*lwgeom_out = lwgeom;
+	return ES_NONE;
 * rt_raster_to_gdal()
diff --git a/raster/rt_pg/rtpg_pixel.c b/raster/rt_pg/rtpg_pixel.c
index 6fdae07..f07fab8 100644
--- a/raster/rt_pg/rtpg_pixel.c
+++ b/raster/rt_pg/rtpg_pixel.c
@@ -32,6 +32,8 @@
 #include "utils/lsyscache.h" /* for get_typlenbyvalalign */
 #include <funcapi.h>
 #include "utils/array.h" /* for ArrayType */
+#include "utils/builtins.h" /* for text_to_cstring */
+#include "utils/formatting.h" /* for asc_tolower */
 #include "catalog/pg_type.h" /* for INT2OID, INT4OID, FLOAT4OID, FLOAT8OID and TEXTOID */
 #include "../../postgis_config.h"
@@ -46,12 +48,14 @@
 /* Get pixel value */
 Datum RASTER_getPixelValue(PG_FUNCTION_ARGS);
+Datum RASTER_getPixelValueResample(PG_FUNCTION_ARGS);
 Datum RASTER_dumpValues(PG_FUNCTION_ARGS);
 /* Set pixel value(s) */
 Datum RASTER_setPixelValue(PG_FUNCTION_ARGS);
 Datum RASTER_setPixelValuesArray(PG_FUNCTION_ARGS);
 Datum RASTER_setPixelValuesGeomval(PG_FUNCTION_ARGS);
+Datum RASTER_getGeometryValues(PG_FUNCTION_ARGS);
 /* Get pixels of value */
 Datum RASTER_pixelOfValue(PG_FUNCTION_ARGS);
@@ -72,69 +76,264 @@ Datum RASTER_neighborhood(PG_FUNCTION_ARGS);
 PG_FUNCTION_INFO_V1(RASTER_getPixelValue);
-    rt_pgraster *pgraster = NULL;
-    rt_raster raster = NULL;
-    rt_band band = NULL;
-    double pixvalue = 0;
-    int32_t bandindex = 0;
-    int32_t x = 0;
-    int32_t y = 0;
-    int result = 0;
-    bool exclude_nodata_value = TRUE;
+	rt_pgraster *pgraster = NULL;
+	rt_raster raster = NULL;
+	double pixvalue = 0;
+	int32_t bandindex = 0;
+	int32_t x = 0;
+	int32_t y = 0;
+	int result = 0;
+	bool exclude_nodata_value = TRUE;
 		int isnodata = 0;
-    /* Index is 1-based */
-    bandindex = PG_GETARG_INT32(1);
-    if ( bandindex < 1 ) {
-        elog(NOTICE, "Invalid band index (must use 1-based). Returning NULL");
-        PG_RETURN_NULL();
-    x = PG_GETARG_INT32(2);
-    y = PG_GETARG_INT32(3);
-    exclude_nodata_value = PG_GETARG_BOOL(4);
-    POSTGIS_RT_DEBUGF(3, "Pixel coordinates (%d, %d)", x, y);
-    /* Deserialize raster */
-    if (PG_ARGISNULL(0)) PG_RETURN_NULL();
-    pgraster = (rt_pgraster *)PG_DETOAST_DATUM(PG_GETARG_DATUM(0));
-    raster = rt_raster_deserialize(pgraster, FALSE);
-    if (!raster) {
-        PG_FREE_IF_COPY(pgraster, 0);
-        elog(ERROR, "RASTER_getPixelValue: Could not deserialize raster");
-        PG_RETURN_NULL();
-    /* Fetch Nth band using 0-based internal index */
-    band = rt_raster_get_band(raster, bandindex - 1);
-    if (! band) {
-        elog(NOTICE, "Could not find raster band of index %d when getting pixel "
-                "value. Returning NULL", bandindex);
-        rt_raster_destroy(raster);
-        PG_RETURN_NULL();
-    /* Fetch pixel using 0-based coordinates */
-    result = rt_band_get_pixel(band, x - 1, y - 1, &pixvalue, &isnodata);
-    /* If the result is -1 or the value is nodata and we take nodata into account
-     * then return nodata = NULL */
-    if (result != ES_NONE || (exclude_nodata_value && isnodata)) {
-        PG_RETURN_NULL();
-    PG_RETURN_FLOAT8(pixvalue);
+	/* Index is 1-based */
+	bandindex = PG_GETARG_INT32(1);
+	if ( bandindex < 1 ) {
+		elog(NOTICE, "Invalid band index (must use 1-based). Returning NULL");
+		PG_RETURN_NULL();
+	x = PG_GETARG_INT32(2);
+	y = PG_GETARG_INT32(3);
+	exclude_nodata_value = PG_GETARG_BOOL(4);
+	POSTGIS_RT_DEBUGF(3, "Pixel coordinates (%d, %d)", x, y);
+	/* Deserialize raster */
+	if (PG_ARGISNULL(0)) PG_RETURN_NULL();
+	pgraster = (rt_pgraster *)PG_DETOAST_DATUM(PG_GETARG_DATUM(0));
+	raster = rt_raster_deserialize(pgraster, FALSE);
+	if (!raster) {
+		PG_FREE_IF_COPY(pgraster, 0);
+		elog(ERROR, "RASTER_getPixelValue: Could not deserialize raster");
+		PG_RETURN_NULL();
+	/* Fetch Nth band using 0-based internal index */
+	band = rt_raster_get_band(raster, bandindex - 1);
+	if (! band) {
+		elog(NOTICE, "Could not find raster band of index %d when getting pixel "
+				"value. Returning NULL", bandindex);
+		rt_raster_destroy(raster);
+		PG_RETURN_NULL();
+	/* Fetch pixel using 0-based coordinates */
+	result = rt_band_get_pixel(band, x - 1, y - 1, &pixvalue, &isnodata);
+	/* If the result is -1 or the value is nodata and we take nodata into account
+	 * then return nodata = NULL */
+	if (result != ES_NONE || (exclude_nodata_value && isnodata)) {
+		PG_RETURN_NULL();
+	PG_RETURN_FLOAT8(pixvalue);
+static rt_resample_type resample_text_to_type(text *txt)
+	char *resample = asc_tolower(VARDATA(txt), VARSIZE_ANY_EXHDR(txt));
+	if (strncmp(resample, "bilinear", 8) == 0)
+		return RT_BILINEAR;
+	else if (strncmp(resample, "nearest", 7) == 0)
+		return RT_NEAREST;
+	else {
+		elog(ERROR, "Unknown resample type '%s' requested", resample);
+	pfree(resample);
+* ST_Value(
+*   rast raster,
+*   band integer,
+*   pt geometry,
+*   exclude_nodata_value boolean DEFAULT TRUE,
+*   resample text DEFAULT 'nearest'
+PG_FUNCTION_INFO_V1(RASTER_getPixelValueResample);
+	rt_pgraster *pgraster = (rt_pgraster *)PG_DETOAST_DATUM(PG_GETARG_DATUM(0));
+	int32_t bandnum = PG_GETARG_INT32(1);
+	GSERIALIZED *gser;
+	LWPOINT *lwpoint;
+	LWGEOM *lwgeom;
+	bool exclude_nodata_value = PG_GETARG_BOOL(3);
+	rt_resample_type resample_type = RT_NEAREST;
+	double x, y, xr, yr;
+	double pixvalue = 0.0;
+	int isnodata = 0;
+	if (bandnum < 1) {
+		PG_RETURN_NULL();
+	gser = (GSERIALIZED*)PG_DETOAST_DATUM(PG_GETARG_DATUM(2));
+	if (gserialized_get_type(gser) != POINTTYPE || gserialized_is_empty(gser)) {
+		elog(ERROR, "Attempting to get the value of a pixel with a non-point geometry");
+		PG_RETURN_NULL();
+	if (!raster) {
+		PG_RETURN_NULL();
+	if (gserialized_get_srid(gser) != rt_raster_get_srid(raster)) {
+		elog(ERROR, "Raster and geometry do not have the same SRID");
+		PG_RETURN_NULL();
+	if (PG_NARGS() > 4) {
+		text *resample_text = PG_GETARG_TEXT_P(4);
+		resample_type = resample_text_to_type(resample_text);
+	band = rt_raster_get_band(raster, bandnum - 1);
+	if (!band) {
+		elog(ERROR, "Could not find raster band of index %d when getting pixel "
+					"value. Returning NULL", bandnum);
+		PG_RETURN_NULL();
+	/* Get the X/Y coordinates */
+	lwgeom = lwgeom_from_gserialized(gser);
+	lwpoint = lwgeom_as_lwpoint(lwgeom);
+	x = lwpoint_get_x(lwpoint);
+	y = lwpoint_get_y(lwpoint);
+	err = rt_raster_geopoint_to_rasterpoint(raster, x, y, &xr, &yr, NULL);
+		elog(ERROR, "Could not convert world coordinate to raster coordinate");
+		PG_RETURN_NULL();
+	/* Use appropriate resample algorithm */
+		band,
+		xr, yr,
+		resample_type,
+		&pixvalue, &isnodata
+	lwgeom_free(lwgeom);
+	if (err != ES_NONE || (exclude_nodata_value && isnodata)) {
+		PG_RETURN_NULL();
+* ST_SetZ(
+*   rast raster,
+*   pt geometry,
+*   resample text DEFAULT 'nearest' ),
+*   band integer default 1,
+*   dimension text default 'z'
+PG_FUNCTION_INFO_V1(RASTER_getGeometryValues);
+	LWGEOM *lwgeom_in, *lwgeom_out;
+	char dimension;
+	const char *func_name;
+	uint16_t num_bands;
+	int32_t band;
+	text *resample_text = PG_GETARG_TEXT_P(2);
+	/* Dimension depends on the name of calling SQL function */
+	/* ST_SetZ()? or ST_SetM()? */
+	func_name = get_func_name(fcinfo->flinfo->fn_oid);
+	if (strcmp(func_name, "st_setz") == 0)
+		dimension = 'z';
+	else if (strcmp(func_name, "st_setm") == 0)
+		dimension = 'm';
+	else
+		elog(ERROR, "%s called from unexpected SQL signature", __func__);
+	/* Geometry */
+	gser = (GSERIALIZED*)PG_DETOAST_DATUM(PG_GETARG_DATUM(1));
+	if (gserialized_is_empty(gser)) {
+		elog(ERROR, "Cannot copy value into an empty geometry");
+		PG_RETURN_NULL();
+	/* Raster */
+	num_bands = rt_raster_get_num_bands(raster);
+	if (!raster) {
+		elog(ERROR, "Could not deserialize raster");
+		PG_RETURN_NULL();
+	/* Bandnidex is 1-based */
+	band = PG_GETARG_INT32(3);
+	if (band < 1 || band > num_bands) {
+		elog(NOTICE, "Invalid band index %d. Must be between 1 and %u", band, num_bands);
+		PG_RETURN_NULL();
+	/* SRID consistency */
+		PG_RETURN_NULL();
+	/* Process arguments */
+	/* Get the geometry */
+	lwgeom_in = lwgeom_from_gserialized(gser);
+	/* Run the sample */
+	err = rt_raster_copy_to_geometry(
+		raster,
+		band - 1,      /* rtcore uses 0-based band number */
+		dimension,     /* 'z' or 'm' */
+		resample_type, /* bilinear or nearest */
+		lwgeom_in,
+		&lwgeom_out
+	lwgeom_free(lwgeom_in);
+	if (err != ES_NONE || !lwgeom_out) {
+		PG_RETURN_NULL();
+	PG_RETURN_POINTER(gserialized_from_lwgeom(lwgeom_out, NULL));
 /*  ST_DumpValues function                                          */
diff --git a/raster/rt_pg/rtpg_utility.c b/raster/rt_pg/rtpg_utility.c
index 017d265..4e1e920 100644
--- a/raster/rt_pg/rtpg_utility.c
+++ b/raster/rt_pg/rtpg_utility.c
@@ -146,4 +146,3 @@ Datum RASTER_memsize(PG_FUNCTION_ARGS)
   PG_RETURN_INT32(size);
diff --git a/raster/rt_pg/rtpostgis.h b/raster/rt_pg/rtpostgis.h
index 7577d2e..ef9f281 100644
--- a/raster/rt_pg/rtpostgis.h
+++ b/raster/rt_pg/rtpostgis.h
@@ -75,4 +75,5 @@ typedef struct rt_raster_serialized_t rt_pgraster;
 #define MAX_DBL_CHARLEN (3 + DBL_MANT_DIG - DBL_MIN_EXP)
 #define MAX_INT_CHARLEN 32
 #endif /* RTPOSTGIS_H_INCLUDED */
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index 95412f6..c31e26c 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -4621,39 +4621,26 @@ CREATE OR REPLACE FUNCTION st_value(rast raster, x integer, y integer, exclude_n
     AS $$ SELECT st_value($1, 1, $2, $3, $4) $$
     LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
-CREATE OR REPLACE FUNCTION st_value(rast raster, band integer, pt geometry, exclude_nodata_value boolean DEFAULT TRUE)
-    RETURNS float8 AS
-    DECLARE
-        x float8;
-        y float8;
-        gtype text;
-    BEGIN
-        gtype := @extschema at .ST_GeometryType(pt);
-        IF ( gtype != 'ST_Point' ) THEN
-            RAISE EXCEPTION 'Attempting to get the value of a pixel with a non-point geometry';
-        END IF;
-				IF @extschema at .ST_SRID(pt) != @extschema at .ST_SRID(rast) THEN
-            RAISE EXCEPTION 'Raster and geometry do not have the same SRID';
-				END IF;
-        x := @extschema at .ST_x(pt);
-        y := @extschema at .ST_y(pt);
-        RETURN @extschema at .ST_value(rast,
-                        band,
-                        @extschema at .ST_worldtorastercoordx(rast, x, y),
-                        @extschema at .ST_worldtorastercoordy(rast, x, y),
-                        exclude_nodata_value);
-    END;
-    LANGUAGE 'plpgsql' IMMUTABLE STRICT PARALLEL SAFE;
+CREATE OR REPLACE FUNCTION st_value(rast raster, band integer, pt geometry, exclude_nodata_value boolean DEFAULT TRUE, resample text DEFAULT 'nearest')
+	RETURNS float8
+	AS 'MODULE_PATHNAME', 'RASTER_getPixelValueResample'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
-CREATE OR REPLACE FUNCTION ST_Value(rast raster, pt geometry, exclude_nodata_value boolean DEFAULT TRUE)
+CREATE OR REPLACE FUNCTION st_value(rast raster, pt geometry, exclude_nodata_value boolean DEFAULT TRUE)
     RETURNS float8
-    AS $$ SELECT @extschema at .ST_value($1, 1, $2, $3) $$
+    AS $$ SELECT @extschema at .ST_value($1, 1, $2, $3, 'nearest') $$
+CREATE OR REPLACE FUNCTION st_setz(rast raster, geom geometry, resample text DEFAULT 'nearest', band integer default 1)
+	RETURNS geometry
+	AS 'MODULE_PATHNAME', 'RASTER_getGeometryValues'
+CREATE OR REPLACE FUNCTION st_setm(rast raster, geom geometry, resample text DEFAULT 'nearest', band integer default 1)
+	RETURNS geometry
 -- ST_PixelOfValue()
diff --git a/raster/rt_pg/rtpostgis_drop.sql.in b/raster/rt_pg/rtpostgis_drop.sql.in
index 259692c..0fe6986 100644
--- a/raster/rt_pg/rtpostgis_drop.sql.in
+++ b/raster/rt_pg/rtpostgis_drop.sql.in
@@ -120,3 +120,7 @@ DROP FUNCTION IF EXISTS st_approxquantile(rastertable text, rastercolumn text, n
 DROP FUNCTION IF EXISTS st_approxquantile(rastertable text, rastercolumn text, sample_percent double precision, quantile double precision);
 DROP FUNCTION IF EXISTS st_approxquantile(rastertable text, rastercolumn text, exclude_nodata_value boolean, quantile double precision);
 DROP FUNCTION IF EXISTS st_approxquantile(rastertable text, rastercolumn text, quantile double precision);
+DROP FUNCTION IF EXISTS st_value(rast raster, band integer, pt geometry, exclude_nodata_value boolean);
diff --git a/raster/test/cunit/cu_raster_geometry.c b/raster/test/cunit/cu_raster_geometry.c
index 1836441..65a6021 100644
--- a/raster/test/cunit/cu_raster_geometry.c
+++ b/raster/test/cunit/cu_raster_geometry.c
@@ -573,6 +573,69 @@ static void test_raster_pixel_as_polygon() {
 	cu_free_raster(rast);
+static void test_raster_get_pixel_bilinear() {
+	uint32_t width = 2;
+	uint32_t height = 2;
+	double ul_x = 0.0;
+	double ul_y = 0.0;
+	double scale_x = 1;
+	double scale_y = 1;
+	double xr, yr;
+	double igt[6];
+	rt_raster rast = rt_raster_new(width, height);
+	rt_raster_set_offsets(rast, ul_x, ul_y);
+	rt_raster_set_scale(rast, scale_x, scale_y);
+	double xw = 1.5, yw = 0.5;
+	rt_raster_generate_new_band(
+		rast,    // rt_raster raster,
+		PT_64BF, // rt_pixtype pixtype,
+		1.0,    // double initialvalue,
+		1,       // uint32_t hasnodata,
+		-99.0,   // double nodatavalue,
+		0        // int index
+	rt_raster_geopoint_to_rasterpoint(
+		rast,
+		xw, yw,
+		&xr, &yr, igt);
+	printf("xw = %g, yw = %g, xr = %g, yr = %g\n", xw, yw, xr, yr);
+	// err = rt_raster_cell_to_geopoint(
+	// 	rast,
+	// 	xr, yr,
+	// 	&xw, &yw, igt);
+	// printf("xw = %g, yw = %g, xr = %g, yr = %g\n", xw, yw, xr, yr);
+	rt_band band = rt_raster_get_band(rast, 0);
+	rt_band_set_pixel(band, 0, 0, 10.0, NULL);
+	rt_band_set_pixel(band, 0, 1, 10.0, NULL);
+	rt_band_set_pixel(band, 1, 0, 20.0, NULL);
+	rt_band_set_pixel(band, 1, 1, 40.0, NULL);
+	double value;
+	int nodata;
+	rt_band_get_pixel_bilinear(
+		band,
+		xw, yw, // double xw, double yw,
+		&value, &nodata // double *r_value, int *r_nodata)
+	printf("xw = %g, yw = %g, value = %g, nodata = %d\n", xr, yr, value, nodata);
 /* register tests */
 void raster_geometry_suite_setup(void);
@@ -584,5 +647,6 @@ void raster_geometry_suite_setup(void)
 	PG_ADD_TEST(suite, test_raster_surface);
 	PG_ADD_TEST(suite, test_raster_perimeter);
 	PG_ADD_TEST(suite, test_raster_pixel_as_polygon);
+	PG_ADD_TEST(suite, test_raster_get_pixel_bilinear);
diff --git a/raster/test/regress/rt_pixelvalue.sql b/raster/test/regress/rt_pixelvalue.sql
index 4229937..fb9c053 100644
--- a/raster/test/regress/rt_pixelvalue.sql
+++ b/raster/test/regress/rt_pixelvalue.sql
@@ -327,3 +327,32 @@ SELECT 'test 4.4', id
     WHERE st_value(st_setvalue(st_setbandnodatavalue(rast, NULL), 1, 1, 1, NULL), 1, 1, 1) != b1val;
 DROP TABLE rt_band_properties_test;
+-- Test 5 - st_setvalue(rast raster, band integer, geometry, resample)
+WITH r AS (
+SELECT
+ST_SetValues(
+  ST_AddBand(
+  1,1,1,
+SELECT
+'Test 5',
+round(ST_Value(rast, 1, 'SRID=4326;POINT(1.5 1.5)'::geometry, resample => 'nearest')) as nearest_15_15,
+round(ST_Value(rast, 1, 'SRID=4326;POINT(0.5 0.5)'::geometry, resample => 'nearest')) as nearest_05_05,
+round(ST_Value(rast, 1, 'SRID=4326;POINT(1.0 1.0)'::geometry, resample => 'bilinear')) as nearest_10_10,
+round(ST_Value(rast, 1, 'SRID=4326;POINT(1.0 0.1)'::geometry, resample => 'bilinear')) as nearest_10_00,
+round(ST_Value(rast, 1, 'SRID=4326;POINT(1.0 1.9)'::geometry, resample => 'bilinear')) as nearest_10_20
+FROM r
diff --git a/raster/test/regress/rt_pixelvalue_expected b/raster/test/regress/rt_pixelvalue_expected
index 4880f48..49194c7 100644
--- a/raster/test/regress/rt_pixelvalue_expected
+++ b/raster/test/regress/rt_pixelvalue_expected
@@ -8,3 +8,4 @@ NOTICE:  Raster do not have a nodata value defined. Set band nodata value first.
 NOTICE:  Raster do not have a nodata value defined. Set band nodata value first. Nodata value not set. Returning original raster
+Test 5|50|40|30|26|38
Summary of changes:
 NEWS                                       |  10 +
 doc/reference_raster.xml                   | 145 +++++++++++++
 raster/rt_core/librtcore.h                 |  87 ++++++++
 raster/rt_core/rt_band.c                   | 156 ++++++++++++++
 raster/rt_core/rt_raster.c                 | 154 ++++++++++++--
 raster/rt_pg/rtpg_pixel.c                  | 317 +++++++++++++++++++++++------
 raster/rt_pg/rtpg_utility.c                |   1 -
 raster/rt_pg/rtpostgis.h                   |   1 +
 raster/rt_pg/rtpostgis.sql.in              |  45 ++--
 raster/rt_pg/rtpostgis_drop.sql.in         |   4 +
 raster/test/cunit/cu_raster_geometry.c     |  64 ++++++
 raster/test/regress/rt_pixelvalue.sql      |  29 +++
 raster/test/regress/rt_pixelvalue_expected |   1 +
 13 files changed, 908 insertions(+), 106 deletions(-)
hooks/post-receive
