[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-147-g0a9809b
Mon Apr 19 12:51:25 PDT 2021
the project "PostGIS".
       via  0a9809b7978b77e09f173ce256ec696a04071b30 (commit)
       via  3ecd0fb05e37de06a6e3e1354bfee961cddef7f5 (commit)
       via  8b80c4bd848ff3d71b998dc8a4bd42627ed72581 (commit)
      from  dabd7723201a2efed06fd3d3e77c35e5cec7e44b (commit)
revisions in full, below.
commit 0a9809b7978b77e09f173ce256ec696a04071b30
Merge: dabd772 3ecd0fb
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Apr 19 12:51:16 2021 -0700
    Merge branch 'ffontaine-master'
commit 3ecd0fb05e37de06a6e3e1354bfee961cddef7f5
Merge: dabd772 8b80c4b
Date:   Mon Apr 19 12:37:56 2021 -0700
    Merge branch 'master' of https://github.com/ffontaine/postgis into ffontaine-master
commit 8b80c4bd848ff3d71b998dc8a4bd42627ed72581
Author: Fabrice Fontaine <fontaine.fabrice at gmail.com>
Date:   Sat Apr 17 11:58:19 2021 +0200
    configure.ac: fix cross-compilation with protobuf-c
    Try to retrieve the version from pkg-config to avoid the following
    error:
    checking protobuf-c version... configure: error: in `/home/fabrice/buildroot/output/build/postgis-3.1.1':
    configure: error: cannot run test program while cross compiling
    Signed-off-by: Fabrice Fontaine <fontaine.fabrice at gmail.com>
diff --git a/configure.ac b/configure.ac
index 48ba070..df75fe6 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1004,6 +1004,7 @@ if test "$CHECK_PROTOBUF" != "no"; then
 		PKG_CHECK_MODULES([PROTOBUFC], [libprotobuf-c >= 1.1.0], [
 				PROTOBUF_CPPFLAGS="$PROTOBUFC_CFLAGS";
 				PROTOBUF_LDFLAGS="$PROTOBUFC_LIBS";
+				PROTOC_VERSION=`$PKG_CONFIG libprotobuf-c --modversion | sed 's/\([[0-9]]\).*\([[0-9]]\).*\([[0-9]]\)/\100\200\3/'`
 				AC_MSG_RESULT([libprotobuf-c not found in pkg-config])
@@ -1054,7 +1055,10 @@ if test "$CHECK_PROTOBUF" != "no"; then
 	AC_MSG_CHECKING([protobuf-c version])
-	AC_PROTOBUFC_VERSION([PROTOC_VERSION])
+	dnl Return the protobuf-c version number if not detected by pkg-config
+	if test "x$PROTOC_VERSION" = "x"; then
+		AC_PROTOBUFC_VERSION([PROTOC_VERSION])
+	fi
         if test ! "$PROTOC_VERSION" -ge 1001000; then
                 AC_MSG_ERROR("Old protobuf-c release found but 1.1.0 is required. You can disable MVT and Geobuf support using --without-protobuf")
         fi
Summary of changes:
 configure.ac | 6 +++++-
 1 file changed, 5 insertions(+), 1 deletion(-)
hooks/post-receive
