[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-149-g7ba7eb4
Tue Apr 20 16:00:58 PDT 2021
the project "PostGIS".
       via  7ba7eb4c5a5f9b73198f692c2621e2e136cea3f4 (commit)
      from  4f8241765fe8cf3d323cc68ba2642b225bde749b (commit)
revisions in full, below.
commit 7ba7eb4c5a5f9b73198f692c2621e2e136cea3f4
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Apr 20 18:43:54 2021 -0400
    Correct proto defs in docs and put in availability and changed notes.  Hopefully makes CI bots happy again.
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index b0f5a45..fc838b9 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -4932,6 +4932,7 @@ SELECT x, y, val, ST_AsText(geom)
                     <paramdef><type>integer </type> <parameter>band</parameter></paramdef>
                     <paramdef><type>geometry </type> <parameter>pt</parameter></paramdef>
                     <paramdef choice="opt"><type>boolean </type> <parameter>exclude_nodata_value=true</parameter></paramdef>
+                    <paramdef choice="opt"><type>text </type> <parameter>resample='nearest'</parameter></paramdef>
                   </funcprototype>
                   <funcprototype>
                     <funcdef>double precision <function>ST_Value</function></funcdef>
@@ -4957,6 +4958,7 @@ SELECT x, y, val, ST_AsText(geom)
                 <para>Returns the value of a given band in a given columnx, rowy pixel or at a given geometry point. Band numbers start at 1 and band is assumed to be 1 if not specified.
                 If <varname>exclude_nodata_value</varname> is set to true, then only non <varname>nodata</varname> pixels are considered.  If <varname>exclude_nodata_value</varname> is set to false, then all pixels are considered.</para>
+                <para>Enhanced: 3.2.0 resample optional argument was added.</para>
                 <para>Enhanced: 2.0.0 exclude_nodata_value optional argument was added.</para>
                 </refsection>
@@ -5269,7 +5271,7 @@ FROM (
             <refsynopsisdiv>
                 <funcsynopsis>
                    <funcprototype>
-                    <funcdef>geometry <function>ST_GetValues</function></funcdef>
+                    <funcdef>geometry <function>ST_SetZ</function></funcdef>
                     <paramdef><type>raster </type> <parameter>rast</parameter></paramdef>
                     <paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
                     <paramdef choice="opt"><type>text </type> <parameter>resample=nearest</parameter></paramdef>
@@ -5283,6 +5285,8 @@ FROM (
                 <para>Returns a geometry with the same X/Y coordinates as the input geometry, and values from the raster copied into the Z dimensions using the requested resample algorithm.</para>
                 <para>The <varname>resample</varname> parameter can be set to "nearest" to copy the values from the cell each vertex falls within, or "bilinear" to use <ulink url="https://en.wikipedia.org/wiki/Bilinear_interpolation">bilinear interpolation</ulink> to calculate a value that takes neighboring cells into account also.</para>
+                <para>Availability: 3.2.0</para>
             </refsection>
                 <refsection>
@@ -5342,7 +5346,7 @@ FROM test_raster
             <refsynopsisdiv>
                 <funcsynopsis>
                    <funcprototype>
+                    <funcdef>geometry <function>ST_SetM</function></funcdef>
@@ -5356,6 +5360,8 @@ FROM test_raster
             </refsection>
                 <refsection>
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index c31e26c..0c72dbc 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -4621,6 +4621,7 @@ CREATE OR REPLACE FUNCTION st_value(rast raster, x integer, y integer, exclude_n
     AS $$ SELECT st_value($1, 1, $2, $3, $4) $$
     LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
+-- Changed: 3.2.0 added resample arg
 CREATE OR REPLACE FUNCTION st_value(rast raster, band integer, pt geometry, exclude_nodata_value boolean DEFAULT TRUE, resample text DEFAULT 'nearest')
 	RETURNS float8
 	AS 'MODULE_PATHNAME', 'RASTER_getPixelValueResample'
@@ -4631,11 +4632,13 @@ CREATE OR REPLACE FUNCTION st_value(rast raster, pt geometry, exclude_nodata_val
     AS $$ SELECT @extschema at .ST_value($1, 1, $2, $3, 'nearest') $$
+-- Availability: 3.2.0 added resample arg
 CREATE OR REPLACE FUNCTION st_setz(rast raster, geom geometry, resample text DEFAULT 'nearest', band integer default 1)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'RASTER_getGeometryValues'
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
 CREATE OR REPLACE FUNCTION st_setm(rast raster, geom geometry, resample text DEFAULT 'nearest', band integer default 1)
 	RETURNS geometry
Summary of changes:
 doc/reference_raster.xml      | 10 ++++++++--
 raster/rt_pg/rtpostgis.sql.in |  3 +++
 2 files changed, 11 insertions(+), 2 deletions(-)
hooks/post-receive
