[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-151-gadc0c61
Tue Apr 20 16:49:06 PDT 2021
the project "PostGIS".
       via  adc0c61c6b65c11c50f0b490385a7e2070531c78 (commit)
       via  7b6bd02d6c69039a3355161712618608ae503f81 (commit)
      from  7ba7eb4c5a5f9b73198f692c2621e2e136cea3f4 (commit)
revisions in full, below.
commit adc0c61c6b65c11c50f0b490385a7e2070531c78
Merge: 7b6bd02 7ba7eb4
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Apr 20 16:47:59 2021 -0700
    Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis
diff --cc doc/reference_raster.xml
index 0129831,fc838b9..ce8bd9a
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@@ -4955,10 -4955,10 +4955,11 @@@ SELECT x, y, val, ST_AsText(geom
              <refsection>
                  <title>Description</title>
 -                <para>Returns the value of a given band in a given columnx, rowy pixel or at a given geometry point. Band numbers start at 1 and band is assumed to be 1 if not specified.
 -                If <varname>exclude_nodata_value</varname> is set to true, then only non <varname>nodata</varname> pixels are considered.  If <varname>exclude_nodata_value</varname> is set to false, then all pixels are considered.</para>
 +                <para>Returns the value of a given band in a given columnx, rowy pixel or at a given geometry point. Band numbers start at 1 and band is assumed to be 1 if not specified.</para>
 +                <para>If <varname>exclude_nodata_value</varname> is set to true, then only non <varname>nodata</varname> pixels are considered.  If <varname>exclude_nodata_value</varname> is set to false, then all pixels are considered.</para>
 +                <para>The allowed values of the <varname>resample</varname> parameter are "nearest" which performs the default nearest-neighbor resampling, and "bilinear" which performs a <ulink url="https://en.wikipedia.org/wiki/Bilinear_interpolation">bilinear interpolation</ulink> to estimate the value between pixel centers.</para>
+                 <para>Enhanced: 3.2.0 resample optional argument was added.</para>
                  <para>Enhanced: 2.0.0 exclude_nodata_value optional argument was added.</para>
                  </refsection>
diff --cc raster/rt_pg/rtpostgis.sql.in
index c60a348,0c72dbc..7904aee
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@@ -4616,21 -4616,23 +4616,23 @@@ CREATE OR REPLACE FUNCTION st_value(ras
      AS 'MODULE_PATHNAME','RASTER_getPixelValue'
      LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
 -CREATE OR REPLACE FUNCTION st_value(rast raster, x integer, y integer, exclude_nodata_value boolean DEFAULT TRUE)
 -    RETURNS float8
 -    AS $$ SELECT st_value($1, 1, $2, $3, $4) $$
 -    LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
+ -- Changed: 3.2.0 added resample arg
  CREATE OR REPLACE FUNCTION st_value(rast raster, band integer, pt geometry, exclude_nodata_value boolean DEFAULT TRUE, resample text DEFAULT 'nearest')
  	RETURNS float8
  	AS 'MODULE_PATHNAME', 'RASTER_getPixelValueResample'
 +CREATE OR REPLACE FUNCTION st_value(rast raster, x integer, y integer, exclude_nodata_value boolean DEFAULT TRUE)
 +    RETURNS float8
 +    AS $$ SELECT st_value($1, 1::integer, $2, $3, $4) $$
 +    LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
  CREATE OR REPLACE FUNCTION st_value(rast raster, pt geometry, exclude_nodata_value boolean DEFAULT TRUE)
      RETURNS float8
 -    AS $$ SELECT @extschema at .ST_value($1, 1, $2, $3, 'nearest') $$
 +    AS $$ SELECT @extschema at .ST_value($1, 1::integer, $2, $3, 'nearest'::text) $$
+ -- Availability: 3.2.0 added resample arg
  CREATE OR REPLACE FUNCTION st_setz(rast raster, geom geometry, resample text DEFAULT 'nearest', band integer default 1)
  	RETURNS geometry
  	AS 'MODULE_PATHNAME', 'RASTER_getGeometryValues'
commit 7b6bd02d6c69039a3355161712618608ae503f81
Date:   Tue Apr 20 16:44:27 2021 -0700
    Bring documentation into line with .sql functionality so that comments do not complain.
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index b0f5a45..0129831 100644
@@ -4932,6 +4932,7 @@ SELECT x, y, val, ST_AsText(geom)
                     <paramdef><type>integer </type> <parameter>band</parameter></paramdef>
                     <paramdef><type>geometry </type> <parameter>pt</parameter></paramdef>
                     <paramdef choice="opt"><type>boolean </type> <parameter>exclude_nodata_value=true</parameter></paramdef>
+                    <paramdef choice="opt"><type>text </type> <parameter>resample=nearest</parameter></paramdef>
                   </funcprototype>
                   <funcprototype>
                     <funcdef>double precision <function>ST_Value</function></funcdef>
@@ -4954,8 +4955,9 @@ SELECT x, y, val, ST_AsText(geom)
             <refsection>
                 </refsection>
@@ -5269,7 +5271,7 @@ FROM (
             <refsynopsisdiv>
                 <funcsynopsis>
                    <funcprototype>
-                    <funcdef>geometry <function>ST_GetValues</function></funcdef>
+                    <funcdef>geometry <function>ST_SetZ</function></funcdef>
                     <paramdef><type>raster </type> <parameter>rast</parameter></paramdef>
                     <paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
@@ -5342,7 +5344,7 @@ FROM test_raster
             <refsynopsisdiv>
                 <funcsynopsis>
                    <funcprototype>
+                    <funcdef>geometry <function>ST_SetM</function></funcdef>
diff --git a/postgis/lwgeom_geos_clean.c b/postgis/lwgeom_geos_clean.c
index fbec291..db099d6 100644
--- a/postgis/lwgeom_geos_clean.c
+++ b/postgis/lwgeom_geos_clean.c
@@ -48,8 +48,6 @@ Datum ST_MakeValid(PG_FUNCTION_ARGS)
 	in = PG_GETARG_GSERIALIZED_P_COPY(0);
 	lwgeom_in = lwgeom_from_gserialized(in);
-	POSTGIS_DEBUG(1, "ST_MakeValid enter");
 	switch ( lwgeom_in->type )
 	case POINTTYPE:
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index c31e26c..c60a348 100644
@@ -4616,19 +4616,19 @@ CREATE OR REPLACE FUNCTION st_value(rast raster, band integer, x integer, y inte
-    RETURNS float8
 	RETURNS float8
+    RETURNS float8
     RETURNS float8
Summary of changes:
 doc/reference_raster.xml      |  5 +++--
 postgis/lwgeom_geos_clean.c   |  2 --
 raster/rt_pg/rtpostgis.sql.in | 12 ++++++------
 3 files changed, 9 insertions(+), 10 deletions(-)
hooks/post-receive
