[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-161-g7e19e67
Tue Apr 27 11:23:51 PDT 2021
the project "PostGIS".
       via  7e19e671ed87060f933bd2ca8b4233097ead5dc7 (commit)
      from  2851cd1908dc138d6a6ec389fdbedc8fc93f5e73 (commit)
revisions in full, below.
commit 7e19e671ed87060f933bd2ca8b4233097ead5dc7
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Apr 27 11:23:33 2021 -0700
    Move test to geos310.sql to avoid different results on different GEOS versions.
diff --git a/regress/core/geos310.sql b/regress/core/geos310.sql
new file mode 100644
index 0000000..e56d10b
--- /dev/null
+++ b/regress/core/geos310.sql
@@ -0,0 +1,6 @@
+-- #168 --
+SELECT '#168', ST_NPoints(g), ST_AsText(g), ST_isValidReason(g)
+FROM ( VALUES
+('01060000C00100000001030000C00100000003000000E3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFF'::geometry)
+) AS v(g);
diff --git a/regress/core/geos310_expected b/regress/core/geos310_expected
index 0000000..f5dc667
--- /dev/null
+++ b/regress/core/geos310_expected
@@ -0,0 +1 @@
+#168|3|MULTIPOLYGON ZM (((4275341.969778511 259186.96699306098 1323.762958283311 -1.797693134862316e+308,4275341.969778511 259186.96699306098 1323.762958283311 -1.797693134862316e+308,4275341.969778511 259186.96699306098 1323.762958283311 -1.797693134862316e+308)))|Too few points in geometry component[4275341.96977851 259186.966993061 1323.76295828331]
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 21b95dc..876dead 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -145,12 +145,17 @@ ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 30800),1)
 endif
 ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 30900),1)
-	# GEOS-3.0 adds stable maximuminscribedcircle implementation
+	# GEOS-3.9 adds stable maximuminscribedcircle implementation
 	TESTS += \
 		$(topsrcdir)/regress/core/geos39 \
 		$(topsrcdir)/regress/core/fixedoverlay
 endif
+ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31000),1)
+	TESTS += \
+		$(topsrcdir)/regress/core/geos310
+endif
 ifeq ($(INTERRUPTTESTS),yes)
 	# Allow CI servers to configure --with-interrupt-tests
 	TESTS += \
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index c4aff1a..4269354 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -109,12 +109,6 @@ FROM ( VALUES
 	( ST_LineToCurve(ST_Boundary(ST_Buffer(ST_Point(1,2), 3))) )
 	) AS v(g);
--- #168 --
-SELECT '#168', ST_NPoints(g), ST_AsText(g), ST_isValidReason(g)
-FROM ( VALUES
-('01060000C00100000001030000C00100000003000000E3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFF'::geometry)
-) AS v(g);
 -- #175 --
 SELECT '#175', ST_AsEWKT(ST_GeomFromEWKT('SRID=26915;POINT(482020 4984378.)'));
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 30b1d58..8f6ac27 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -30,7 +30,6 @@ ERROR:  Invalid hex string, length (267) has to be a multiple of two!
 #157|ST_Polygon|POLYGON
 #157|ST_CurvePolygon|CURVEPOLYGON
 #157|ST_CircularString|CIRCULARSTRING
-#168|3|MULTIPOLYGON ZM (((4275341.969778511 259186.96699306098 1323.762958283311 -1.797693134862316e+308,4275341.969778511 259186.96699306098 1323.762958283311 -1.797693134862316e+308,4275341.969778511 259186.96699306098 1323.762958283311 -1.797693134862316e+308)))|IllegalArgumentException: Invalid number of points in LinearRing found 3 - must be 0 or >= 4
 #175|SRID=26915;POINT(482020 4984378)
 #178a|0
 #178b|5
Summary of changes:
 regress/core/geos310.sql      | 6 ++++++
 regress/core/geos310_expected | 1 +
 regress/core/tests.mk.in      | 7 ++++++-
 regress/core/tickets.sql      | 6 ------
 regress/core/tickets_expected | 1 -
 5 files changed, 13 insertions(+), 8 deletions(-)
 create mode 100644 regress/core/geos310.sql
 create mode 100644 regress/core/geos310_expected
hooks/post-receive
