[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-162-g46efb9f
Tue Apr 27 12:06:32 PDT 2021
the project "PostGIS".
       via  46efb9f2d9f5a4bfa64764fc9d6ce5251d86825c (commit)
      from  7e19e671ed87060f933bd2ca8b4233097ead5dc7 (commit)
revisions in full, below.
commit 46efb9f2d9f5a4bfa64764fc9d6ce5251d86825c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Apr 27 12:04:43 2021 -0700
    Add a new ST_MakeValid() signature that takes options to control
    what validity building algorithm (and parameters) to use. Options are
    valid for GEOS 3.10+.
diff --git a/NEWS b/NEWS
index 89ff3c8..54ca637 100644
--- a/NEWS
+++ b/NEWS
@@ -18,6 +18,8 @@ PostGIS 3.2.0
  * New features*
   - #4841, FindTopology to quickly get a topology record (Sandro Santilli)
   - #4851, TopoGeom_addTopoGeom function (Sandro Santilli)
+  - ST_MakeValid(geometry, options) allows alternative validity building
+    algorithms with GEOS 3.10 (Paul Ramsey)
   - ST_InterpolateRaster() fills in raster cells between sample points
     using one of a number of algorithms (inverse weighted distance, average, etc)
     using algorithms from GDAL
diff --git a/doc/reference_validation.xml b/doc/reference_validation.xml
index 9299250..dd4b245 100644
--- a/doc/reference_validation.xml
+++ b/doc/reference_validation.xml
@@ -305,6 +305,11 @@ SELECT ST_IsValidReason('LINESTRING(220227 150406,2220227 150407,222020 150410)'
             <funcdef>geometry <function>ST_MakeValid</function></funcdef>
             <paramdef><type>geometry</type> <parameter>input</parameter></paramdef>
           </funcprototype>
+          <funcprototype>
+            <funcdef>geometry <function>ST_MakeValid</function></funcdef>
+            <paramdef><type>geometry</type> <parameter>input</parameter></paramdef>
+            <paramdef choice="opt"><type>text</type> <parameter>params</parameter></paramdef>
+          </funcprototype>
         </funcsynopsis>
       </refsynopsisdiv>
@@ -331,12 +336,32 @@ SELECT ST_IsValidReason('LINESTRING(220227 150406,2220227 150407,222020 150410)'
     <para>
     Single polygons may become multi-geometries in case of self-intersections.
     </para>
-        <para>Performed by the GEOS module.</para>
+    <para>
+    The <varname>params</varname> argument can be used to supply an options
+    string to select the method to use for building valid geometry.
+    The options string is in the format "key1=value2 key2=value2".
+    </para>
+    <para>The "method" key has two values. "linework" is the original
+        algorithm, and builds valid geometries by first extracting all lines,
+        noding that linework together, then building a value output from the
+        linework. "structure" is an algorithm that distinguishes between
+        interior and exterior rings, building new geometry by unioning
+        exterior rings, and then differencing all interior rings.
+    </para>
+    <para>The "keepcollapsed" is only valid for the "structure" algorithm,
+        and takes a value of "true" or "false". When set to "false",
+        geometry components that collapse to a lower dimensionality,
+        for example a one-point linestring would be dropped.
+    </para>
+    <para>Performed by the GEOS module.</para>
     <para>Availability: 2.0.0</para>
     <para>Enhanced: 2.0.1, speed improvements</para>
     <para>Enhanced: 2.1.0, added support for GEOMETRYCOLLECTION and MULTIPOINT.</para>
     <para>Enhanced: 3.1.0, added removal of Coordinates with NaN values.</para>
+    <para>Enhanced: 3.2.0, added algorithm options, 'linework' and 'structure'.</para>
     <para>&Z_support;</para>
@@ -403,6 +428,27 @@ FROM (SELECT 'MULTIPOLYGON(((186 194,187 194,188 195,189 195,190 195,
     </tgroup>
 </informaltable>
 </refsection>
+<refsection>
+<title>Examples</title>
+<programlisting>SELECT ST_AsText(ST_MakeValid(
+    'LINESTRING(0 0, 0 0)',
+    'method=structure keepcollapsed=true'
+ st_astext
+ POINT(0 0)
+SELECT ST_AsText(ST_MakeValid(
+    'method=structure keepcollapsed=false'
+    st_astext
+ LINESTRING EMPTY</programlisting>
+</refsection>
           <refsection>
             <title>See Also</title>
             <para>
diff --git a/liblwgeom/Makefile.in b/liblwgeom/Makefile.in
index 5470f9a..0d42eef 100644
--- a/liblwgeom/Makefile.in
+++ b/liblwgeom/Makefile.in
@@ -51,6 +51,7 @@ LEX=@LEX@
 # Standalone LWGEOM objects
 SA_OBJS = \
 	stringbuffer.o \
+	optionlist.o \
 	bytebuffer.o \
 	measures.o \
 	measures3d.o \
diff --git a/liblwgeom/cunit/cu_misc.c b/liblwgeom/cunit/cu_misc.c
index 8cb483e..37deb74 100644
--- a/liblwgeom/cunit/cu_misc.c
+++ b/liblwgeom/cunit/cu_misc.c
@@ -15,6 +15,7 @@
 #include "CUnit/Basic.h"
 #include "liblwgeom_internal.h"
+#include "optionlist.h"
 #include "cu_tester.h"
@@ -233,7 +234,30 @@ static void test_gbox_serialized_size(void)
 	CU_ASSERT_EQUAL(gbox_serialized_size(flags),24);
+static void test_optionlist(void)
+	const char* value;
+	// zero out all the pointers so our list ends up null-terminated
+	char *olist[OPTION_LIST_SIZE];
+	char input[128];
+	memset(olist, 0, sizeof(olist));
+	// input string needs to be writeable because we are inserting nulls
+	strcpy(input, "key1=value1  key2=value2");
+	option_list_parse(input, olist);
+	value = option_list_search(olist, "key1");
+	// printf("value: %s\n", value);
+	CU_ASSERT_STRING_EQUAL("value1", value);
+	value = option_list_search(olist, "key2");
+	CU_ASSERT_STRING_EQUAL("value2", value);
+	value = option_list_search(olist, "key3");
+	CU_ASSERT_EQUAL(NULL, value);
+	strcpy(input, "  ");
 ** Used by the test harness to register the tests in this file.
@@ -251,4 +275,5 @@ void misc_suite_setup(void)
 	PG_ADD_TEST(suite, test_clone);
 	PG_ADD_TEST(suite, test_lwmpoint_from_lwgeom);
 	PG_ADD_TEST(suite, test_gbox_serialized_size);
+	PG_ADD_TEST(suite, test_optionlist);
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 30d2646..bbacc19 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -2488,6 +2488,7 @@ LWGEOM* lwgeom_buildarea(const LWGEOM *geom) ;
  * Attempts to make an invalid geometries valid w/out losing points.
 LWGEOM* lwgeom_make_valid(LWGEOM* geom);
+LWGEOM* lwgeom_make_valid_params(LWGEOM* geom, char *make_valid_params);
  * Split (multi)polygon by line; (multi)line by (multi)line,
diff --git a/liblwgeom/lwgeom_geos_clean.c b/liblwgeom/lwgeom_geos_clean.c
index 7b720a0..fdbe3e8 100644
--- a/liblwgeom/lwgeom_geos_clean.c
+++ b/liblwgeom/lwgeom_geos_clean.c
@@ -29,6 +29,7 @@
 #include "lwgeom_geos.h"
 #include "lwgeom_log.h"
 #include <string.h>
 #include <stdlib.h>
@@ -897,6 +898,13 @@ LWGEOM_GEOS_makeValid(const GEOSGeometry* gin)
 LWGEOM*
 lwgeom_make_valid(LWGEOM* lwgeom_in)
+	return lwgeom_make_valid_params(lwgeom_in, NULL);
+/* Exported. Uses GEOS internally */
+LWGEOM*
+lwgeom_make_valid_params(LWGEOM* lwgeom_in, char* make_valid_params)
 	int is3d;
 	GEOSGeom geosgeom;
 	GEOSGeometry* geosout;
@@ -934,8 +942,56 @@ lwgeom_make_valid(LWGEOM* lwgeom_in)
 #if POSTGIS_GEOS_VERSION < 30800
 	geosout = LWGEOM_GEOS_makeValid(geosgeom);
-#else
+#elif POSTGIS_GEOS_VERSION < 31000
 	geosout = GEOSMakeValid(geosgeom);
+#else
+	if (!make_valid_params) {
+		geosout = GEOSMakeValid(geosgeom);
+	else {
+		* Set up a parameters object for this
+		* make valid operation before calling
+		* it
+		const char *value;
+		char *param_list[OPTION_LIST_SIZE];
+		char param_list_text[OPTION_LIST_SIZE];
+		strncpy(param_list_text, make_valid_params, OPTION_LIST_SIZE);
+		memset(param_list, 0, sizeof(param_list));
+		option_list_parse(param_list_text, param_list);
+		GEOSMakeValidParams *params = GEOSMakeValidParams_create();
+		value = option_list_search(param_list, "method");
+		if (value) {
+			if (strcasecmp(value, "linework") == 0) {
+				GEOSMakeValidParams_setMethod(params, GEOS_MAKE_VALID_LINEWORK);
+			else if (strcasecmp(value, "structure") == 0) {
+				GEOSMakeValidParams_setMethod(params, GEOS_MAKE_VALID_STRUCTURE);
+			else
+				GEOSMakeValidParams_destroy(params);
+				lwerror("Unsupported value for 'method', '%s'. Use 'linework' or 'structure'.", value);
+		value = option_list_search(param_list, "keepcollapsed");
+		if (value) {
+			if (strcasecmp(value, "true") == 0) {
+				GEOSMakeValidParams_setKeepCollapsed(params, 1);
+			else if (strcasecmp(value, "false") == 0) {
+				GEOSMakeValidParams_setKeepCollapsed(params, 0);
+			else
+				lwerror("Unsupported value for 'keepcollapsed', '%s'. Use 'true' or 'false'", value);
+		geosout = GEOSMakeValidWithParams(geosgeom, params);
 #endif
 	GEOSGeom_destroy(geosgeom);
 	if (!geosout) return NULL;
diff --git a/liblwgeom/optionlist.c b/liblwgeom/optionlist.c
new file mode 100644
index 0000000..bd25678
--- /dev/null
+++ b/liblwgeom/optionlist.c
@@ -0,0 +1,95 @@
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * PostGIS is free software: you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation, either version 2 of the License, or
+ * (at your option) any later version.
+ * PostGIS is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with PostGIS.  If not, see <http://www.gnu.org/licenses/>.
+ * Copyright 2021 Paul Ramsey <pramsey at cleverelephant.ca>
+#include "liblwgeom_internal.h"
+#include <ctype.h>  // tolower
+#include <string.h> // strtok
+static void
+option_list_string_to_lower(char* key)
+	if (!key) return;
+	while (*key) {
+		*key = tolower(*key);
+		key++;
+	return;
+const char*
+option_list_search(char** olist, const char* key)
+	size_t i = 0;
+	if (!olist) return NULL;
+	if (!key) return NULL;
+	while (olist[i]) {
+		// Even entries are keys
+		if (!(i % 2)) {
+			// Does this key match ours?
+			if (strcmp(olist[i], key) == 0) {
+				return olist[i+1];
+		i++;
+	return NULL;
+void
+option_list_parse(char* input, char **olist)
+	const char *toksep = " ";
+	const char kvsep = '=';
+	char *key, *val;
+	if (!input) return;
+	size_t i = 0, sz;
+	/* strtok nulls out the space between each token */
+	for (key = strtok(input, toksep); key; key = strtok(NULL, toksep)) {
+		if (i >= OPTION_LIST_SIZE) return;
+		olist[i] = key;
+		i += 2;
+	sz = i;
+	/* keys are every second entry in the olist */
+	for (i = 0; i < sz; i += 2) {
+		key = olist[i];
+		/* find the key/value separator */
+		val = strchr(key, kvsep);
+		if (!val) {
+			lwerror("Option string entry '%s' lacks separator '%c'", key, kvsep);
+		/* null out the separator */
+		*val = '\0';
+		/* point value entry to just after separator */
+		olist[i+1] = ++val;
+		/* all keys forced to lower case */
+		option_list_string_to_lower(key);
diff --git a/liblwgeom/optionlist.h b/liblwgeom/optionlist.h
index 0000000..c9df6de
--- /dev/null
+++ b/liblwgeom/optionlist.h
@@ -0,0 +1,64 @@
+#ifndef _OPTIONLIST_H
+#define _OPTIONLIST_H 1
+#define OPTION_LIST_SIZE 128
+* option_list is a null-terminated list of strings, where every odd
+* string is a key and every even string is a value. To avoid lots of
+* memory allocations, we use the input string as the backing store
+* and fill in the olist with pointers to the start of the key and
+* value strings, with keys in the even slots and values in the
+* odd slots. The input needs to be writeable because we write a
+* '\0' into the string at the break between token separators.
+* // array of char*
+* char *olist[OPTION_LIST_SIZE];
+* // zero out all the pointers so our list ends up null-terminated
+* memset(olist, 0, sizeof(olist));
+* char input[OPTION_LIST_SIZE];
+* strcpy(input, "key1=value1 key2=value2"); // writeable
+* option_list_parse(input, olist);
+* char* key = "key2";
+* const char* value = option_list_search(olist, key);
+* printf("value of '%s' is '%s'\n", key, value);
+extern void option_list_parse(char* input, char **olist);
+* Returns null if the key cannot be found. Only
+* use fully lowercase keys, because we lowercase
+* keys when we parse the olist
+extern const char* option_list_search(char** olist, const char* key);
+#endif
diff --git a/postgis/lwgeom_geos_clean.c b/postgis/lwgeom_geos_clean.c
index db099d6..4f49616 100644
--- a/postgis/lwgeom_geos_clean.c
+++ b/postgis/lwgeom_geos_clean.c
@@ -26,6 +26,7 @@
 #include "postgres.h"
 #include "fmgr.h"
 #include "funcapi.h"
+#include "utils/builtins.h"
 #include "../postgis_config.h"
@@ -66,7 +67,14 @@ Datum ST_MakeValid(PG_FUNCTION_ARGS)
 		break;
-	lwgeom_out = lwgeom_make_valid(lwgeom_in);
+	if(PG_NARGS() > 1 && ! PG_ARGISNULL(1)) {
+		char *make_valid_params_str = text_to_cstring(PG_GETARG_TEXT_P(1));
+		lwgeom_out = lwgeom_make_valid_params(lwgeom_in, make_valid_params_str);
+	else {
+		lwgeom_out = lwgeom_make_valid(lwgeom_in);
 	if ( ! lwgeom_out )
 		PG_FREE_IF_COPY(in, 0);
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 9e49473..1ef5d29 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3691,6 +3691,12 @@ CREATE OR REPLACE FUNCTION ST_MakeValid(geometry)
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_HIGH;
+CREATE OR REPLACE FUNCTION ST_MakeValid(geom geometry, params text)
+	RETURNS geometry
+	AS 'MODULE_PATHNAME', 'ST_MakeValid'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	_COST_HIGH;
 -- ST_CleanGeometry(in geometry)
 -- Make input:
Summary of changes:
 NEWS                          |  2 +
 doc/reference_validation.xml  | 48 +++++++++++++++++++++-
 liblwgeom/Makefile.in         |  1 +
 liblwgeom/cunit/cu_misc.c     | 27 +++++++++++-
 liblwgeom/liblwgeom.h.in      |  1 +
 liblwgeom/lwgeom_geos_clean.c | 58 +++++++++++++++++++++++++-
 liblwgeom/optionlist.c        | 95 +++++++++++++++++++++++++++++++++++++++++++
 liblwgeom/optionlist.h        | 64 +++++++++++++++++++++++++++++
 postgis/lwgeom_geos_clean.c   | 10 ++++-
 postgis/postgis.sql.in        |  6 +++
 10 files changed, 308 insertions(+), 4 deletions(-)
 create mode 100644 liblwgeom/optionlist.c
 create mode 100644 liblwgeom/optionlist.h
hooks/post-receive
