[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-169-gc9a654c
Thu Apr 29 21:32:13 PDT 2021
the project "PostGIS".
       via  c9a654c4ee99352371308f58a449fa0d00471fb8 (commit)
       via  5d1579c988e2cec06938c92d2543588471bfb909 (commit)
       via  754e01cdd100b3ed2989188a49c60cf0e4c0fdc3 (commit)
       via  13569c18081b9aa77f3c6bf2d949ef6b79aea1c5 (commit)
      from  02b6fd4581524d5b8608cdde03cc474b2a2385ac (commit)
revisions in full, below.
commit c9a654c4ee99352371308f58a449fa0d00471fb8
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Apr 30 00:32:06 2021 -0400
    shp2pgsql option to disable ANALYZE. Closes #4628  Closes https://github.com/postgis/postgis/pull/610 for PostGIS 3.2.0
diff --git a/NEWS b/NEWS
index 54ca637..2f7d515 100644
--- a/NEWS
+++ b/NEWS
@@ -14,6 +14,7 @@ PostGIS 3.2.0
   - #3778, #4401, ST_Boundary now works for TIN and does not linearize curves (Aliaksandr Kalenik)
   - #4881, #4884, Store sign of edge_id for lineal TopoGeometry in relation table
            to retain direction (Sandro Santilli)
+  - #4628, Add an option to disable ANALYZE when loading shapefiles (Stefan Corneliu Petrea)
  * New features*
   - #4841, FindTopology to quickly get a topology record (Sandro Santilli)
commit 5d1579c988e2cec06938c92d2543588471bfb909
Author: Stefan Petrea <stefan.petrea at gmail.com>
Date:   Fri Apr 30 07:22:24 2021 +0300
    updated docs
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index be48bb9..52264ef 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -1677,6 +1677,16 @@ AVERYLONGCOLUMNNAME DBFFIELD2</programlisting>
         </para>
       </listitem>
     </varlistentry>
+    <varlistentry>
+      <term>-Z</term>
+      <listitem>
+        <para>
+          When used, this flag will prevent the generation of <code>ANALYZE</code> statements.
+          Without the -Z flag (default behaviour), the <code>ANALYZE</code> statements will
+          be generated.
+        </para>
+      </listitem>
+    </varlistentry>
   </variablelist>
   <para>
commit 754e01cdd100b3ed2989188a49c60cf0e4c0fdc3
Date:   Fri Apr 30 06:21:41 2021 +0300
    updating test with -Z switch
diff --git a/regress/loader/PointWithSchema.opts b/regress/loader/PointWithSchema.opts
index eac9db9..f9e761f 100644
--- a/regress/loader/PointWithSchema.opts
+++ b/regress/loader/PointWithSchema.opts
@@ -1,2 +1,2 @@
 # Test loading a table with a schema.
--g the_geom {regdir}/loader/PointWithSchema pgreg.loadedshp
+-Z -g the_geom {regdir}/loader/PointWithSchema pgreg.loadedshp
commit 13569c18081b9aa77f3c6bf2d949ef6b79aea1c5
Date:   Fri Apr 30 03:46:46 2021 +0300
    added -Z option to prevent tables from being  analyzed
diff --git a/loader/shp2pgsql-cli.c b/loader/shp2pgsql-cli.c
index efaae13..149ed55 100644
--- a/loader/shp2pgsql-cli.c
+++ b/loader/shp2pgsql-cli.c
@@ -68,6 +68,7 @@ usage()
 	printf(_( "  -X <tablespace> Specify the tablespace for the table's indexes.\n"
                   "      This applies to the primary key, and the spatial index if\n"
                   "      the -I flag is used.\n" ));
+	printf(_( "  -Z  Prevent tables from being analyzed.\n" ));
 	printf(_( "  -?  Display this help screen.\n" ));
 	printf( "\n" );
 	printf(_( "  An argument of `--' disables further option processing.\n" ));
@@ -102,7 +103,7 @@ main (int argc, char **argv)
 	set_loader_config_defaults(config);
 	/* Keep the flag list alphabetic so it's easy to see what's left. */
-	while ((c = pgis_getopt(argc, argv, "-acdeg:ikm:nps:t:wDGIN:ST:W:X:")) != EOF)
+	while ((c = pgis_getopt(argc, argv, "-acdeg:ikm:nps:t:wDGIN:ST:W:X:Z")) != EOF)
 		// can not do this inside the switch case
 		if ('-' == c)
@@ -125,6 +126,10 @@ main (int argc, char **argv)
 			config->geography = 1;
 			break;
+		case 'Z':
+			config->analyze = 0;
+			break;
 		case 'S':
 			config->simple_geometries = 1;
 			break;
diff --git a/loader/shp2pgsql-core.c b/loader/shp2pgsql-core.c
index b6963cd..f292f21 100644
--- a/loader/shp2pgsql-core.c
+++ b/loader/shp2pgsql-core.c
@@ -763,6 +763,7 @@ set_loader_config_defaults(SHPLOADERCONFIG *config)
 	config->quoteidentifiers = 0;
 	config->forceint4 = 0;
 	config->createindex = 0;
+	config->analyze = 1;
 	config->readshape = 1;
 	config->force_output = FORCE_OUTPUT_DISABLE;
 	config->encoding = strdup(ENCODING_DEFAULT);
@@ -1925,13 +1926,17 @@ ShpLoaderGetSQLFooter(SHPLOADERSTATE *state, char **strfooter)
 		stringbuffer_aprintf(sb, "COMMIT;\n");
-	/* Always ANALYZE the resulting table, for better stats */
-	stringbuffer_aprintf(sb, "ANALYZE ");
-	if (state->config->schema)
+	if(state->config->analyze)
-		stringbuffer_aprintf(sb, "\"%s\".", state->config->schema);
+		/* Always ANALYZE the resulting table, for better stats */
+		stringbuffer_aprintf(sb, "ANALYZE ");
+		if (state->config->schema)
+			stringbuffer_aprintf(sb, "\"%s\".", state->config->schema);
+		stringbuffer_aprintf(sb, "\"%s\";\n", state->config->table);
-	stringbuffer_aprintf(sb, "\"%s\";\n", state->config->table);
 	/* Copy the string buffer into a new string, destroying the string buffer */
 	ret = (char *)malloc(strlen((char *)stringbuffer_getstring(sb)) + 1);
diff --git a/loader/shp2pgsql-core.h b/loader/shp2pgsql-core.h
index d00a979..905f922 100644
--- a/loader/shp2pgsql-core.h
+++ b/loader/shp2pgsql-core.h
@@ -114,6 +114,9 @@ typedef struct shp_loader_config
 	/* 0 = no index, 1 = create index after load */
 	int createindex;
+    /* 0 = don't analyze tables , 1 = analyze tables */
+	int analyze;
 	/* 0 = load DBF file only, 1 = load everything */
 	int readshape;
Summary of changes:
 NEWS                                |  1 +
 doc/using_postgis_dataman.xml       | 10 ++++++++++
 loader/shp2pgsql-cli.c              |  7 ++++++-
 loader/shp2pgsql-core.c             | 15 ++++++++++-----
 loader/shp2pgsql-core.h             |  3 +++
 regress/loader/PointWithSchema.opts |  2 +-
 6 files changed, 31 insertions(+), 7 deletions(-)
hooks/post-receive
