[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-171-g28bd4bb
Fri Apr 30 09:13:27 PDT 2021
the project "PostGIS".
       via  28bd4bbcffb08c9098e2ecc6b8f17b8945ffec31 (commit)
       via  a82a8e77e741ac3be9d541ef02986630f6301ffd (commit)
      from  c9a654c4ee99352371308f58a449fa0d00471fb8 (commit)
revisions in full, below.
commit 28bd4bbcffb08c9098e2ecc6b8f17b8945ffec31
Merge: c9a654c a82a8e7
Author: Daniel Baston <dbaston at gmail.com>
Date:   Fri Apr 30 12:13:04 2021 -0400
    Merge branch 'geos-coordseq-buffer'
diff --cc liblwgeom/lwgeom_geos.c
index 5c95561,7ba4588..a1bed05
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@@ -143,10 -142,13 +143,13 @@@ ptarray_from_GEOSCoordSeq(const GEOSCoo
  	LWDEBUGF(4, " output dimensions: %d", dims);
  	pa = ptarray_construct((dims == 3), 0, size);
+ #if POSTGIS_GEOS_VERSION >= 310
+ 	GEOSCoordSeq_copyToBuffer(cs, (double*) pa->serialized_pointlist, (dims == 3), 0);
+ 	return pa;
+ #else
  	for (i = 0; i < size; i++)
 -#if POSTGIS_GEOS_VERSION < 38
 +#if POSTGIS_GEOS_VERSION < 30800
  		GEOSCoordSeq_getX(cs, i, &(point.x));
  		GEOSCoordSeq_getY(cs, i, &(point.y));
  		if (dims >= 3) GEOSCoordSeq_getZ(cs, i, &(point.z));
commit a82a8e77e741ac3be9d541ef02986630f6301ffd
Date:   Fri Apr 2 21:08:51 2021 -0400
    Improve performance of LWGEOM-GEOS conversion
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index 647de60..7ba4588 100644
@@ -142,7 +142,10 @@ ptarray_from_GEOSCoordSeq(const GEOSCoordSequence* cs, uint8_t want3d)
+#if POSTGIS_GEOS_VERSION >= 310
+	return pa;
+#else
@@ -159,6 +162,7 @@ ptarray_from_GEOSCoordSeq(const GEOSCoordSequence* cs, uint8_t want3d)
 	return pa;
+#endif
 /* Return an LWGEOM from a Geometry */
@@ -270,7 +274,18 @@ ptarray_to_GEOSCoordSeq(const POINTARRAY* pa, uint8_t fix_ring)
-	if (!(sq = GEOSCoordSeq_create(pa->npoints + append_points, dims)))
+	if (append_points == 0) {
+		sq = GEOSCoordSeq_copyFromBuffer((const double*) pa->serialized_pointlist, pa->npoints, FLAGS_GET_Z(pa->flags), FLAGS_GET_M(pa->flags));
+		if (!sq)
+			lwerror("Error creating GEOS Coordinate Sequence");
+			return NULL;
+		return sq;
+#else
+        if (!(sq = GEOSCoordSeq_create(pa->npoints + append_points, dims)))
 		return NULL;
@@ -326,6 +341,7 @@ ptarray_to_GEOSCoordSeq(const POINTARRAY* pa, uint8_t fix_ring)
 	return sq;
+#endif
 static inline GEOSGeometry*
Summary of changes:
 liblwgeom/lwgeom_geos.c | 20 ++++++++++++++++++--
 1 file changed, 18 insertions(+), 2 deletions(-)
hooks/post-receive
