[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-173-ga59187e
git at osgeo.org
git at osgeo.org
Fri Apr 30 13:19:16 PDT 2021
the project "PostGIS".
via a59187e6015537724fa7de223ea0a6c3e73d84a9 (commit)
from 7e03bb102c46f4b55c7bdaac17f939edd05e333e (commit)
revisions in full, below.
commit a59187e6015537724fa7de223ea0a6c3e73d84a9
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri Apr 30 13:19:09 2021 -0700
Improve doc linear ref functions
diff --git a/doc/reference_lrs.xml b/doc/reference_lrs.xml
index 54ba9bb..9455c2f 100644
--- a/doc/reference_lrs.xml
+++ b/doc/reference_lrs.xml
@@ -6,8 +6,7 @@
<refnamediv>
<refname>ST_LineInterpolatePoint</refname>
- <refpurpose>Returns a point interpolated along a line. Second argument is a float8 between 0 and 1
- representing fraction of total length of linestring the point has to be located.</refpurpose>
+ <refpurpose>Returns a point interpolated along a line at a fractional location.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -23,7 +22,7 @@
<refsection>
<title>Description</title>
- <para>Returns a point interpolated along a line. First argument
+ <para>Returns a point interpolated along a line at a fractional location. First argument
must be a LINESTRING. Second argument is a float8 between 0 and 1
representing fraction of total linestring length the point has to be located.</para>
@@ -98,8 +97,7 @@ FROM (SELECT ST_GeomFromText('LINESTRING(1 2, 4 5, 6 7)') As the_line) As foo;
<refnamediv>
<refname>ST_3DLineInterpolatePoint</refname>
- <refpurpose>Returns a point interpolated along a line in 3D. Second argument is a float8 between 0 and 1
+ <refpurpose>Returns a point interpolated along a 3D line at a fractional location.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -115,8 +113,8 @@ FROM (SELECT ST_GeomFromText('LINESTRING(1 2, 4 5, 6 7)') As the_line) As foo;
<refsection>
- must be a LINESTRING. Second argument is a float8 between 0 and 1
+ <para>Returns a point interpolated along a 3D line at a fractional location.
+ First argument must be a LINESTRING. Second argument is a float8 between 0 and 1
<note>
@@ -162,7 +160,7 @@ SELECT ST_AsEWKT(ST_3DLineInterpolatePoint(the_line, 0.20))
<refname>ST_LineInterpolatePoints</refname>
<refpurpose>
- Returns one or more points interpolated along a line.
+ Returns points interpolated along a line at a fractional interval.
</refpurpose>
</refnamediv>
@@ -180,7 +178,8 @@ SELECT ST_AsEWKT(ST_3DLineInterpolatePoint(the_line, 0.20))
<refsection>
- <para>Returns one or more points interpolated along a line. First argument
+ <para>Returns one or more points interpolated along a line at a fractional interval.
+ First argument
representing the spacing between the points as a fraction of total
LineString length. If the third argument is false, at most one point
@@ -230,9 +229,8 @@ SELECT ST_AsText(ST_LineInterpolatePoints('LINESTRING(25 50, 100 125, 150 190)',
<refnamediv>
<refname>ST_LineLocatePoint</refname>
- <refpurpose>Returns a float between 0 and 1 representing the location of
- the closest point on LineString to the given Point, as a fraction
- of total 2d line length.</refpurpose>
+ <refpurpose>Returns the fractional location of
+ the closest point on a line to a point.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -249,7 +247,7 @@ SELECT ST_AsText(ST_LineInterpolatePoints('LINESTRING(25 50, 100 125, 150 190)',
<para>Returns a float between 0 and 1 representing the location of
+ the closest point on a LineString to the given Point, as a fraction
of total <link linkend="ST_Length2D">2d line</link> length.</para>
<para>You can use the returned location to extract a Point (<xref linkend="ST_LineInterpolatePoint" />) or
@@ -311,10 +309,7 @@ FROM (SELECT ST_GeomFromText('LINESTRING(1 2, 4 5, 6 7)') As the_line) As foo;
<refnamediv>
<refname>ST_LineSubstring</refname>
- <refpurpose>Return a linestring being a substring of the input one
- starting and ending at the given fractions of total 2d length.
- Second and third arguments are float8 values between 0 and
- 1.</refpurpose>
+ <refpurpose>Returns the part of a line between two fractional locations.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -331,7 +326,7 @@ FROM (SELECT ST_GeomFromText('LINESTRING(1 2, 4 5, 6 7)') As the_line) As foo;
<refsection>
- <para>Return a linestring being a substring of the input one
+ <para>Returns a linestring being a substring of the input one
1. This only works with LINESTRINGs.
@@ -410,9 +405,7 @@ WHERE n*100.00/length < 1;
<refnamediv>
<refname>ST_LocateAlong</refname>
- <refpurpose>Return a derived geometry collection value with elements
- that match the specified measure. Polygonal elements are not
- supported.</refpurpose>
+ <refpurpose>Returns the point(s) on a geometry that match a measure value.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -429,11 +422,11 @@ WHERE n*100.00/length < 1;
<refsection>
- <para>Return a derived geometry collection value with elements
+ <para>Returns the locations along a geometry (as a Point or MultiPoint)
+ that match the given measure. Polygonal elements are not
supported.</para>
- <para>If an offset is provided, the resultant will be offset to the
+ <para>If an offset is provided, the result will be offset to the
left or right of the input line by the specified number of units.
A positive offset will be to the left, and a negative one to the
right.</para>
@@ -489,8 +482,7 @@ SELECT ST_AsText((ST_Dump(the_geom)).geom)
<refnamediv>
<refname>ST_LocateBetween</refname>
- that match the specified range of measures inclusively.</refpurpose>
+ <refpurpose>Returns the portions of a geometry that match a measure range.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -509,7 +501,7 @@ SELECT ST_AsText((ST_Dump(the_geom)).geom)
<refsection>
- <para>Return a derived geometry collection with elements that match the specified range of
+ <para>Return a geometry collection with elements that match the specified range of
measures inclusively.</para>
<para>Clipping a non-convex POLYGON may produce invalid geometry.</para>
@@ -574,8 +566,8 @@ FROM (
<refnamediv>
<refname>ST_LocateBetweenElevations</refname>
- <refpurpose>Return a derived geometry (collection) value with elements
- that intersect the specified range of elevations inclusively.</refpurpose>
+ that intersect an elevation range.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -593,7 +585,7 @@ FROM (
<refsection>
- <para>Return a derived geometry (collection) value with elements
+ <para>Returns a geometry (collection) value with elements
that intersect the specified range of elevations inclusively.</para>
@@ -645,7 +637,7 @@ LINESTRING(6.1 7.1 6,7 8 9)
<refnamediv>
<refname>ST_InterpolatePoint</refname>
- <refpurpose>Return the value of the measure dimension of a geometry at the point closed to the provided point.</refpurpose>
+ <refpurpose>Returns the interpolated measure of a geometry closest to a point.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -662,7 +654,7 @@ LINESTRING(6.1 7.1 6,7 8 9)
<refsection>
- <para>Return the value of the measure dimension of a geometry at the point closed to the provided point.</para>
+ <para>Returns the value of the measure dimension of a geometry at the point closed to the provided point.</para>
<para>Availability: 2.0.0</para>
@@ -692,7 +684,7 @@ LINESTRING(6.1 7.1 6,7 8 9)
<refnamediv>
<refname>ST_AddMeasure</refname>
- <refpurpose>Return a derived geometry with measure elements linearly interpolated between the start and end points.</refpurpose>
+ <refpurpose>Interpolates measures along a linear geometry.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -710,7 +702,7 @@ LINESTRING(6.1 7.1 6,7 8 9)
<refsection>
- <para>Return a derived geometry with measure elements linearly interpolated between the start and end points. If the geometry has no measure dimension, one is added. If the geometry has a measure dimension, it is over-written with new values. Only LINESTRINGS and MULTILINESTRINGS are supported.</para>
+ <para>Return a derived geometry with measure values linearly interpolated between the start and end points. If the geometry has no measure dimension, one is added. If the geometry has a measure dimension, it is over-written with new values. Only LINESTRINGS and MULTILINESTRINGS are supported.</para>
<para>Availability: 1.5.0</para>
Summary of changes:
doc/reference_lrs.xml | 60 ++++++++++++++++++++++-----------------------------
1 file changed, 26 insertions(+), 34 deletions(-)
hooks/post-receive
