[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-174-g28bbc4a
Fri Apr 30 15:02:42 PDT 2021
the project "PostGIS".
       via  28bbc4af43e48e9183a58fc5f221e1a1c42722c2 (commit)
      from  a59187e6015537724fa7de223ea0a6c3e73d84a9 (commit)
revisions in full, below.
commit 28bbc4af43e48e9183a58fc5f221e1a1c42722c2
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Apr 30 15:02:29 2021 -0700
    Improve doc Linear Ref sections
diff --git a/doc/reference_lrs.xml b/doc/reference_lrs.xml
index 9455c2f..8357015 100644
--- a/doc/reference_lrs.xml
+++ b/doc/reference_lrs.xml
@@ -22,14 +22,25 @@
 		  <refsection>
 			<title>Description</title>
-			<para>Returns a point interpolated along a line at a fractional location. First argument
-			must be a LINESTRING. Second argument is a float8 between 0 and 1
-			representing fraction of total linestring length the point has to be located.</para>
+			<para>Returns a point interpolated along a line at a fractional location.
+            First argument must be a LINESTRING.
+            Second argument is a float between 0 and 1
+			representing the fraction of total linestring length
+            where the point is to be located.
+            The Z and M values are interpolated if present.
+            </para>
 			<para>See <xref linkend="ST_LineLocatePoint" /> for
 			computing the line location nearest to a Point.</para>
 			<note>
+			  <para>This function computes points in 2D and then interpolates
+              values for Z and M,
+              while <xref linkend="ST_3DLineInterpolatePoint" /> computes points in 3D
+              and only interpolates the M value.</para>
+			</note>
+			<note>
 			  <para>Since release 1.1.1 this function also interpolates M and
 			  Z values (when present), while prior releases set them to
 			  0.0.</para>
@@ -50,31 +61,40 @@
 				<caption><para>A linestring with the interpolated point at 20% position (0.20) </para></caption>
 			  </mediaobject>
 			</informalfigure>
-			<programlisting>--Return point 20% along 2d line
-SELECT ST_AsEWKT(ST_LineInterpolatePoint(the_line, 0.20))
-	FROM (SELECT ST_GeomFromEWKT('LINESTRING(25 50, 100 125, 150 190)') as the_line) As foo;
+			<programlisting>-- The point 20% along a line
+SELECT ST_AsEWKT(
+    ST_LineInterpolatePoint(
+        'LINESTRING(25 50, 100 125, 150 190)',
+        0.2 ));
    st_asewkt
  POINT(51.5974135047432 76.5974135047432)
 </programlisting>
+<para>The mid-point of a 3D line:</para>
 <programlisting>
---Return point mid-way of 3d line
-SELECT ST_AsEWKT(ST_LineInterpolatePoint(the_line, 0.5))
-	FROM (SELECT ST_GeomFromEWKT('LINESTRING(1 2 3, 4 5 6, 6 7 8)') as the_line) As foo;
+SELECT ST_AsEWKT(
+    ST_LineInterpolatePoint('
+        LINESTRING(1 2 3, 4 5 6, 6 7 8)',
+        0.5 ));
 	st_asewkt
  POINT(3.5 4.5 5.5)
+</programlisting>
+<para>The closest point on a line to a point:</para>
+<programlisting>
+SELECT ST_AsText(
+    ST_LineInterpolatePoint( line.geom,
+        ST_LineLocatePoint( line.geom, 'POINT(4 3)')))
+FROM (SELECT ST_GeomFromText('LINESTRING(1 2, 4 5, 6 7)') As geom) AS line;
---find closest point on a line to a point or other geometry
- SELECT ST_AsText(ST_LineInterpolatePoint(foo.the_line, ST_LineLocatePoint(foo.the_line, ST_GeomFromText('POINT(4 3)'))))
-FROM (SELECT ST_GeomFromText('LINESTRING(1 2, 4 5, 6 7)') As the_line) As foo;
-   st_astext
+ st_astext
  POINT(3 4)
 </programlisting>
 		  </refsection>
@@ -83,13 +103,10 @@ FROM (SELECT ST_GeomFromText('LINESTRING(1 2, 4 5, 6 7)') As the_line) As foo;
 			<title>See Also</title>
 			<para>
-				<xref linkend="ST_AsText" />,
-				<xref linkend="ST_AsEWKT" />,
-				<xref linkend="ST_Length" />,
-				<xref linkend="ST_LineInterpolatePoints" />
-				<xref linkend="ST_3DLineInterpolatePoint" />
+				<xref linkend="ST_LineInterpolatePoints" />,
+				<xref linkend="ST_3DLineInterpolatePoint" />,
-			O</para>
+			</para>
 		  </refsection>
 		</refentry>
@@ -114,13 +131,17 @@ FROM (SELECT ST_GeomFromText('LINESTRING(1 2, 4 5, 6 7)') As the_line) As foo;
 			<para>Returns a point interpolated along a 3D line at a fractional location.
-            First argument must be a LINESTRING. Second argument is a float8 between 0 and 1
+            First argument must be a LINESTRING. Second argument is a float between 0 and 1
+			representing the fraction of linestring length
+            The M value is interpolated if present.
+            </para>
 			<note>
-			  <para><xref linkend="ST_LineInterpolatePoint" /> computes resulting point in 2D and then interpolates
-			  value for Z and M, while ST_3DLineInterpolatePoint computes directly point in 3D and only M value
-			  is interpolated then.</para>
+			  <para><xref linkend="ST_LineInterpolatePoint" /> computes points in 2D
+              and then interpolates the values for Z and M,
+              while this function computes points in 3D
 			</note>
 			<para>Availability: 3.0.0</para>
@@ -132,11 +153,13 @@ FROM (SELECT ST_GeomFromText('LINESTRING(1 2, 4 5, 6 7)') As the_line) As foo;
 			<para>Return point 20% along 3D line</para>
 			<programlisting>
-SELECT ST_AsEWKT(ST_3DLineInterpolatePoint(the_line, 0.20))
-	FROM (SELECT ST_GeomFromEWKT('LINESTRING(25 50 70, 100 125 90, 150 190 200)') as the_line) As foo;
-   st_asewkt
+SELECT ST_AsText(
+    ST_3DLineInterpolatePoint('LINESTRING(25 50 70, 100 125 90, 150 190 200)',
+        0.20));
+   st_asetext
- POINT(59.0675892910822 84.0675892910822 79.0846904776219)
+ POINT Z (59.0675892910822 84.0675892910822 79.0846904776219)
 </programlisting>
 		  </refsection>
@@ -145,11 +168,8 @@ SELECT ST_AsEWKT(ST_3DLineInterpolatePoint(the_line, 0.20))
 			<para>
-				<xref linkend="ST_LineInterpolatePoint" />
+				<xref linkend="ST_LineInterpolatePoint" />,
 			</para>
 		  </refsection>
@@ -412,9 +432,9 @@ WHERE n*100.00/length < 1;
 		<funcsynopsis>
 		  <funcprototype>
 			<funcdef>geometry <function>ST_LocateAlong</function></funcdef>
-			<paramdef><type>geometry </type> <parameter>ageom_with_measure</parameter></paramdef>
-			<paramdef><type>float8 </type> <parameter>a_measure</parameter></paramdef>
-			<paramdef choice="opt"><type>float8 </type> <parameter>offset</parameter></paramdef>
+			<paramdef><type>geometry </type> <parameter>geom_with_measure</parameter></paramdef>
+			<paramdef><type>float8 </type> <parameter>measure</parameter></paramdef>
+			<paramdef choice="opt"><type>float8 </type> <parameter>offset = 0</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
@@ -422,21 +442,20 @@ WHERE n*100.00/length < 1;
 	  <refsection>
-		<para>Returns the locations along a geometry (as a Point or MultiPoint)
-		that match the given measure. Polygonal elements are not
-		supported.</para>
+		<para>Returns the locations along a measured geometry (as a Point or MultiPoint)
+		that match a measure value.
+        Polygonal elements are not supported.</para>
+		<para>If the <varname>offset</varname> is provided, the result
+        is offset to the left or right of the input line by the specified distance.
+        A positive offset will be to the left, and a negative one to the right.</para>
-		<para>If an offset is provided, the result will be offset to the
-		left or right of the input line by the specified number of units.
-		A positive offset will be to the left, and a negative one to the
-		right.</para>
+		<note><para>Use this function only for geometries with an M component</para></note>
-		<para>Semantic is specified by: ISO/IEC CD 13249-3:200x(E) - Text
-		for Continuation CD Editing Meeting</para>
+		<para>The semantic is specified by the <emphasis>ISO/IEC 13249-3 SQL/MM Spatial</emphasis> standard.</para>
 		<para>Availability: 1.1.0 by old name ST_Locate_Along_Measure. </para>
 		<para>Changed: 2.0.0 in prior versions this used to be called ST_Locate_Along_Measure.</para>
-		<note><para>Use this function only for geometries with an M component</para></note>
 		<para>&M_support;</para>
 	  </refsection>
@@ -444,37 +463,23 @@ WHERE n*100.00/length < 1;
 	  <refsection>
 		<title>Examples</title>
-		<programlisting>SELECT ST_AsText(the_geom)
-		FROM
-		(SELECT ST_LocateAlong(
-			ST_GeomFromText('MULTILINESTRINGM((1 2 3, 3 4 2, 9 4 3),
-		(1 2 3, 5 4 5))'),3) As the_geom) As foo;
-						 st_asewkt
- MULTIPOINT M (1 2 3)
---Geometry collections are difficult animals so dump them
---to make them more digestable
-SELECT ST_AsText((ST_Dump(the_geom)).geom)
-	FROM
-   st_asewkt
- POINTM(1 2 3)
- POINTM(9 4 3)
- POINTM(1 2 3)
-	</programlisting>
+<programlisting>
+SELECT ST_AsText(
+  ST_LocateAlong(
+    'MULTILINESTRINGM((1 2 3, 3 4 2, 9 4 3),(1 2 3, 5 4 5))'::geometry,
+    3 ));
+            st_astext
+ MULTIPOINT M (1 2 3,9 4 3,1 2 3)
+</programlisting>
 	  </refsection>
 	  <!-- Optionally add a "See Also" section -->
 	  <refsection>
-		<para><xref linkend="ST_Dump" />, <xref linkend="ST_LocateBetween" />, <xref linkend="ST_LocateBetweenElevations" /></para>
+		<para><xref linkend="ST_LocateBetween" />, <xref linkend="ST_LocateBetweenElevations" /></para>
 	  </refsection>
 	</refentry>
@@ -492,7 +497,7 @@ SELECT ST_AsText((ST_Dump(the_geom)).geom)
 			<paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
 			<paramdef><type>float8 </type> <parameter>measure_start</parameter></paramdef>
 			<paramdef><type>float8 </type> <parameter>measure_end</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
@@ -501,17 +506,16 @@ SELECT ST_AsText((ST_Dump(the_geom)).geom)
 	  <refsection>
-		<para>Return a geometry collection with elements that match the specified range of
-		measures inclusively.</para>
+		<para>Return a geometry (collection) with the portions of the input measured geometry
+        that match the specified measure range (inclusively).</para>
-		<para>Clipping a non-convex POLYGON may produce invalid geometry.</para>
-		<para>If an offset is provided, the resultant will be offset to the left or right of the
-		input line by the specified number of units. A positive offset will be to the left, and
-                a negative one to the right.</para>
+		<para>Clipping a non-convex POLYGON may produce invalid geometry.</para>
-		<para>Semantic is specified by: ISO/IEC CD 13249-3:200x(E) - Text for Continuation
-		CD Editing Meeting</para>
 		<para>Availability: 1.1.0 by old name ST_Locate_Between_Measures. </para>
 		<para>Changed: 2.0.0 - in prior versions this used to be called ST_Locate_Between_Measures.</para>
@@ -523,42 +527,24 @@ SELECT ST_AsText((ST_Dump(the_geom)).geom)
 	  <refsection>
-		<programlisting>
-SELECT ST_AsText(the_geom)
-FROM (
-    SELECT ST_LocateBetween(
-       'MULTILINESTRING M ((1 2 3, 3 4 2, 9 4 3),(1 2 3, 5 4 5))'),
+<programlisting>
+SELECT ST_AsText(
+  ST_LocateBetween(
+       'MULTILINESTRING M ((1 2 3, 3 4 2, 9 4 3),(1 2 3, 5 4 5))':: geometry,
        1.5,
-       3
-    ) as the_geom
-) As foo;
+       3 ));
 							 st_asewkt
  GEOMETRYCOLLECTION M (LINESTRING M (1 2 3,3 4 2,9 4 3),POINT M (1 2 3))
-FROM (
-	1.5,
-	3
-    ) As the_geom
-) As foo;
-		   st_asewkt
- LINESTRING M (1 2 3,3 4 2,9 4 3)
- POINT M (1 2 3)</programlisting>
+</programlisting>
 	  </refsection>
 	  <refsection>
-		<para><xref linkend="ST_Dump" />, <xref linkend="ST_LocateAlong" />, <xref linkend="ST_LocateBetweenElevations" /></para>
+		<para><xref linkend="ST_LocateAlong" />, <xref linkend="ST_LocateBetweenElevations" /></para>
 	  </refsection>
 	</refentry>
@@ -567,7 +553,7 @@ FROM (
 		<refname>ST_LocateBetweenElevations</refname>
 		<refpurpose>Returns the portions of a geometry
-			that intersect an elevation range.</refpurpose>
+			that lie in an elevation (Z) range.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
@@ -585,8 +571,8 @@ FROM (
 	  <refsection>
-		<para>Returns a geometry (collection) value with elements
-		that intersect the specified range of elevations inclusively.</para>
+		<para>Returns a geometry (collection) with the portions of a geometry
+		that lie in an elevations (Z) range.</para>
@@ -599,28 +585,23 @@ FROM (
 	  <refsection>
-		<programlisting>SELECT ST_AsEWKT(ST_LocateBetweenElevations(
-			ST_GeomFromEWKT('LINESTRING(1 2 3, 4 5 6)'), 2, 4)) As ewelev;
-								   ewelev
-	MULTILINESTRING((1 2 3,2 3 4))
+<programlisting>SELECT ST_AsText(
+  ST_LocateBetweenElevations(
+    'LINESTRING(1 2 3, 4 5 6)'::geometry,
+    2, 4 ));
-SELECT ST_AsEWKT(ST_LocateBetweenElevations('LINESTRING(1 2 6, 4 5 -1, 7 8 9)', 6, 9)) As ewelev;
+             st_astext
+ MULTILINESTRING Z ((1 2 3,2 3 4))
-				ewelev
-GEOMETRYCOLLECTION(POINT(1 2 6),LINESTRING(6.1 7.1 6,7 8 9))
+SELECT ST_AsText(
+      'LINESTRING(1 2 6, 4 5 -1, 7 8 9)',
+      6, 9)) As ewelev;
--- Geometry collections are difficult animals so dump them
--- to make them more digestable
-SELECT ST_AsEWKT((ST_Dump(the_geom)).geom)
-	FROM
-	(SELECT ST_LocateBetweenElevations('LINESTRING(1 2 6, 4 5 -1, 7 8 9)', 6, 9) as the_geom) As foo;
-		   st_asewkt
-POINT(1 2 6)
-LINESTRING(6.1 7.1 6,7 8 9)
+                                ewelev
+ GEOMETRYCOLLECTION Z (POINT Z (1 2 6),LINESTRING Z (6.1 7.1 6,7 8 9))
 </programlisting>
 	  </refsection>
@@ -667,7 +648,7 @@ LINESTRING(6.1 7.1 6,7 8 9)
 			<programlisting>SELECT ST_InterpolatePoint('LINESTRING M (0 0 0, 10 0 20)', 'POINT(5 5)');
  st_interpolatepoint
-			            10
+         10
 	</programlisting>
 		  </refsection>
Summary of changes:
 doc/reference_lrs.xml | 243 +++++++++++++++++++++++---------------------------
 1 file changed, 112 insertions(+), 131 deletions(-)
hooks/post-receive
