[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-6-g7678d927d
Sun Dec 19 13:40:12 PST 2021
the project "PostGIS".
       via  7678d927de8c1822a9b655966c3d2eb58ad1ae59 (commit)
      from  092a15f9f4b15cafd9b3e654920219bdf2154fe0 (commit)
revisions in full, below.
commit 7678d927de8c1822a9b655966c3d2eb58ad1ae59
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Dec 19 19:38:19 2021 +0100
    Allow upgrades from <3.1 when using ST_Force{3D,3DM,3DZ,4D} in views
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 003d8b60f..0beca01aa 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1382,6 +1382,7 @@ CREATE OR REPLACE FUNCTION ST_Force2D(geometry)
 -- Availability: 2.1.0
 -- Changed: 3.1.0 - add zvalue=0.0 parameter
+-- Replaces ST_Force3DZ(geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_Force3DZ(geom geometry, zvalue float8 default 0.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_3dz'
@@ -1390,6 +1391,7 @@ CREATE OR REPLACE FUNCTION ST_Force3DZ(geom geometry, zvalue float8 default 0.0)
+-- Replaces ST_Force3D(geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_Force3D(geom geometry, zvalue float8 default 0.0)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_Force3DZ($1, $2)'
@@ -1398,6 +1400,7 @@ CREATE OR REPLACE FUNCTION ST_Force3D(geom geometry, zvalue float8 default 0.0)
 -- Changed: 3.1.0 - add mvalue=0.0 parameter
+-- Replaces ST_Force3DM(geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_Force3DM(geom geometry, mvalue float8 default 0.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_3dm'
@@ -1406,6 +1409,7 @@ CREATE OR REPLACE FUNCTION ST_Force3DM(geom geometry, mvalue float8 default 0.0)
 -- Changed: 3.1.0 - add zvalue=0.0 and mvalue=0.0 parameters
+-- Replaces ST_Force4D(geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_Force4D(geom geometry, zvalue float8 default 0.0, mvalue float8 default 0.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_4d'
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index fd104bc8e..3ba6956bf 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -194,13 +194,6 @@ SELECT _postgis_drop_function_if_needed
     'zoom integer, x integer, y integer, bounds geometry DEFAULT ''0102000020110F00000200000052107C45F81B73C152107C45F81B73C152107C45F81B734152107C45F81B7341''::geometry'
--- FUNCTION ST_Force3D, ST_Force3DZ, ST_Force3DM, ST_Force4DZ changed to add defaults in 3.1
--- These signatures were superseeded
-DROP FUNCTION IF EXISTS ST_Force3D(geometry); -- Does not conflict
-DROP FUNCTION IF EXISTS ST_Force3DZ(geometry); -- Does not conflict
-DROP FUNCTION IF EXISTS ST_Force3DM(geometry); -- Does not conflict
-DROP FUNCTION IF EXISTS ST_Force4D(geometry); -- Does not conflict
 -- FUNCTION st_askml changed to add defaults in 3.0 / r17357
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index d7fb108a7..daf31951d 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -2,4 +2,5 @@ DROP VIEW IF EXISTS upgrade_view_test_overlay;
 DROP VIEW IF EXISTS upgrade_view_test_unaryunion;
 DROP VIEW IF EXISTS upgrade_view_test_subdivide;
 DROP VIEW IF EXISTS upgrade_view_test_union;
+DROP VIEW IF EXISTS upgrade_view_test_force_dims;
 DROP TABLE upgrade_test;
diff --git a/regress/hooks/hook-before-upgrade.sql b/regress/hooks/hook-before-upgrade.sql
index de661643d..07c54dda1 100644
--- a/regress/hooks/hook-before-upgrade.sql
+++ b/regress/hooks/hook-before-upgrade.sql
@@ -47,3 +47,14 @@ CREATE VIEW upgrade_view_test_subdivide AS
 SELECT
 	ST_Subdivide(g1, 256) as geometry_subdivide
 FROM upgrade_test;
+-- Add view using ST_ForceX function
+-- NOTE: 3.1.0 changed them from taking only geometry
+--       to also take optional zvalue/mvalue params
+CREATE VIEW upgrade_view_test_force_dims AS
+SELECT
+	ST_Force3D(g1) as geometry_force3d,
+	ST_Force3DZ(g1) as geometry_force3dz,
+	ST_Force3DM(g1) as geometry_force3dm,
+	ST_Force4D(g1) as geometry_force4d
+FROM upgrade_test;
Summary of changes:
 postgis/postgis.sql.in                |  4 ++++
 postgis/postgis_before_upgrade.sql    |  7 -------
 regress/hooks/hook-after-upgrade.sql  |  1 +
 regress/hooks/hook-before-upgrade.sql | 11 +++++++++++
 4 files changed, 16 insertions(+), 7 deletions(-)
hooks/post-receive
