[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.4-20-g3d947448b
    git at osgeo.org
    git at osgeo.org
    Sun Dec 19 07:22:44 PST 2021
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  3d947448b9c939b321bc22b85c719845722ecc3d (commit)
      from  44deec454fabf94e93858234f12c43d98fc56942 (commit)
revisions in full, below.
commit 3d947448b9c939b321bc22b85c719845722ecc3d
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Dec 14 22:54:55 2021 +0100
    Allow upgrades in presence of views using deprecated functions
    Support adding a 'Replaces' comment above functions to improve upgrade
    When a function has a line like the following in in the comments
    above its signature:
      Replaces ST_Intersection(geometry, geometry) deprecated in 3.1.0
    The upgrade script will try to drop the deprecated functions and in case
    of failure leave them behind renamed with a _deprecated_by_postgis_<version>
    suffix, warns the user about such occurrence and gives her hints on
    how to fix.
    The postgis_full_version() will report presence of such deprecated
    functions as an "incomplete upgrade".
    Closes #5033 in 3.1 branch (3.1.5dev)
diff --git a/NEWS b/NEWS
index 91254cd02..7ede9e599 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,8 @@ PostGIS 3.1.5
   - #5018, pgsql2shp basic support for WITH CTE clause (Regina Obe)
   - #5026, fix DropTopology in presence of UPDATE triggers on
            topology layers (Sandro Santilli)
+  - #5033, allow upgrades in presence of views using deprecated
+           functions (Sandro Santilli)
 PostGIS 3.1.4
 2021/09/04
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 9e49473d9..accda4fa7 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2888,7 +2888,10 @@ $$ LANGUAGE 'sql' STABLE;
 -- Changed: 3.0.0 also upgrade postgis_raster if it exists
 CREATE OR REPLACE FUNCTION postgis_extensions_upgrade() RETURNS text
 AS $$
-DECLARE rec record; sql text; var_schema text;
+DECLARE
+	rec record;
+	sql text;
+	var_schema text;
 BEGIN
 	FOR rec IN
@@ -2902,7 +2905,7 @@ BEGIN
 			'postgis_tiger_geocoder'
 		ORDER BY length(name) -- this is to make sure 'postgis' is first !
-	LOOP
+	LOOP --{
 		IF rec.installed_version IS NULL THEN
 			-- If the support installed by available extension
 			-- is found unpackaged, we package it
@@ -2982,7 +2985,7 @@ BEGIN
 			EXECUTE sql;
 		END IF;
-	END LOOP;
+	END LOOP; --}
 	RETURN 'Upgrade completed, run SELECT postgis_full_version(); for details';
@@ -3173,6 +3176,12 @@ BEGIN
 		fullver = fullver || ' (sfcgal procs from "' || sfcgal_scr_ver || '" need upgrade)';
 	END IF;
+	-- Check for the presence of deprecated functions
+	IF EXISTS ( SELECT oid FROM pg_catalog.pg_proc WHERE proname LIKE '%_deprecated_by_postgis_%' )
+	THEN
+		fullver = fullver || ' (deprecated functions exist, upgrade is not complete)';
+	END IF;
 	RETURN fullver;
 END
@@ -3441,6 +3450,7 @@ CREATE OR REPLACE FUNCTION ST_IsValidTrajectory(geometry)
 -- Changed: 3.1.0 to add gridSize default argument
+-- Replaces ST_Intersection(geometry, geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_Intersection(geom1 geometry, geom2 geometry, gridSize float8 DEFAULT -1)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','ST_Intersection'
@@ -3584,6 +3594,7 @@ CREATE OR REPLACE FUNCTION ST_MaximumInscribedCircle(geometry, OUT center geomet
 -- PostGIS equivalent function: ST_difference(geom1 geometry, geom2 geometry)
+-- Replaces ST_Difference(geometry, geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_Difference(geom1 geometry, geom2 geometry, gridSize float8 DEFAULT -1.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','ST_Difference'
@@ -3606,6 +3617,7 @@ CREATE OR REPLACE FUNCTION ST_Points(geometry)
 -- PostGIS equivalent function: symdifference(geom1 geometry, geom2 geometry)
+-- Replaces ST_SymDifference(geometry, geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_SymDifference(geom1 geometry, geom2 geometry, gridSize float8 DEFAULT -1.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','ST_SymDifference'
@@ -3633,6 +3645,7 @@ CREATE OR REPLACE FUNCTION ST_Union(geom1 geometry, geom2 geometry, gridSize flo
 -- Availability: 2.0.0
+-- Replaces ST_UnaryUnion(geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_UnaryUnion(geometry, gridSize float8 DEFAULT -1.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','ST_UnaryUnion'
@@ -3661,6 +3674,7 @@ CREATE OR REPLACE FUNCTION ST_ClipByBox2d(geom geometry, box box2d)
 -- Availability: 2.2.0
+-- Replaces ST_Subdivide(geometry, integer) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_Subdivide(geom geometry, maxvertices integer DEFAULT 256, gridSize float8 DEFAULT -1.0)
 	RETURNS setof geometry
 	AS 'MODULE_PATHNAME', 'ST_Subdivide'
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index dcd69aa09..fd104bc8e 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -217,12 +217,6 @@ DROP FUNCTION IF EXISTS st_buffer(geometry, double precision); -- Does not confl
 DROP FUNCTION IF EXISTS ST_CurveToLine(geometry, integer); -- Does not conflict
 DROP FUNCTION IF EXISTS ST_CurveToLine(geometry); -- Does not conflict
-DROP FUNCTION IF EXISTS st_intersection(geometry, geometry); -- replaced in 3.1.0 by 3 args version
-DROP FUNCTION IF EXISTS st_subdivide(geometry, integer); -- replaced in 3.1.0 by 3 args version
-DROP FUNCTION IF EXISTS st_difference(geometry, geometry); -- replaced in 3.1.0 by 3 args version
-DROP FUNCTION IF EXISTS st_symdifference(geometry, geometry); -- replaced in 3.1.0 by 3 args version
-DROP FUNCTION IF EXISTS st_unaryunion(geometry); -- replaced in 3.1.0 by 3 args version
 -- geometry_columns changed parameter types so we verify if it needs to be dropped
 -- We check the catalog to see if the view (geometry_columns) has a column
 -- with name `f_table_schema` and type `character varying(256)` as it was
diff --git a/utils/postgis_proc_upgrade.pl b/utils/postgis_proc_upgrade.pl
index 859641b71..0d804cfa9 100755
--- a/utils/postgis_proc_upgrade.pl
+++ b/utils/postgis_proc_upgrade.pl
@@ -4,7 +4,7 @@
 # PostGIS - Spatial Types for PostgreSQL
 # http://postgis.net
-# Copyright (C) 2014 Sandro Santilli <strk at kbt.io>
+# Copyright (C) 2014-2021 Sandro Santilli <strk at kbt.io>
 # Copyright (C) 2009-2010 Paul Ramsey <pramsey at opengeo.org>
 # Copyright (C) 2005 Refractions Research Inc.
@@ -49,6 +49,25 @@ sub parse_last_updated
     return 0;
+sub parse_replaces
+    my @replaces = ();
+    my $comment = shift;
+    my ($name, $args, $ver);
+    foreach my $line ( split /\n/, $comment )
+        if ( $line =~ m/.*Replaces\s\s*([^\(]*)\(([^\)]*)\)\s\s*deprecated in\s\s*([^\.]*)\.([^.]*)/ )
+            $name = $1;
+            $args = $2;
+            $ver = $3*100 + $4;
+            my @r = ($name, $args, $ver);
+            push @replaces, \@r;
+    return @replaces;
 sub parse_missing
@@ -78,6 +97,8 @@ my $version_from_num = 0;
 my $schema = "";
 $schema = $ARGV[2] if @ARGV > 2;
+my @renamed_deprecated_functions = ();
 die "Unable to open input SQL file $sql_file\n"
   if ( !-f $sql_file );
@@ -168,14 +189,80 @@ while(<INPUT>)
     if (/^create or replace function/i)
-        print $_;
+        my $def .= $_;
+        my @replaced_array = parse_replaces($comment);
         my $endfunc = 0;
         while(<INPUT>)
-            print $_;
+            $def .= $_;
             $endfunc = 1 if /^\s*(\$\$\s*)?LANGUAGE /;
             last if ( $endfunc && /\;/ );
+        foreach my $replaced (@replaced_array)
+            my ($name, $args, $ver) = @$replaced;
+            $name = lc($name); # lowercase the name
+            my $renamed = $name . '_deprecated_by_postgis_' . ${ver};
+            my $replacement = "${renamed}(${args})";
+            push @renamed_deprecated_functions, ${renamed};
+            print <<"EOF";
+-- Rename $name ( $args ) deprecated in PostGIS $ver
+DO LANGUAGE 'plpgsql'
+\$postgis_proc_upgrade\$
+DECLARE
+    replaced_proc regprocedure;
+    rec RECORD;
+    new_view_def TEXT;
+    sql TEXT;
+    detail TEXT;
+BEGIN
+    -- Check if the old function signature, exists
+    BEGIN
+        replaced_proc := '$name($args)'::regprocedure;
+    EXCEPTION
+    -- Catch the "function does not exist"
+    WHEN undefined_function THEN
+        RAISE DEBUG 'Function $name($args) does not exist';
+    WHEN OTHERS THEN
+        GET STACKED DIAGNOSTICS detail := PG_EXCEPTION_DETAIL;
+        RAISE EXCEPTION 'Got % (%)', SQLERRM, SQLSTATE
+            USING DETAIL = detail;
+    END;
+    IF replaced_proc IS NULL THEN
+        $def
+        RETURN;
+    END IF;
+    -- Old function signature exists
+    -- Rename old function, to avoid ambiguities and eventually drop
+    ALTER FUNCTION $name( $args ) RENAME TO ${renamed};
+    -- Drop the function from any extension it is part of
+    -- so dump/reloads still work
+    FOR rec IN
+        SELECT e.extname
+        FROM
+            pg_extension e,
+            pg_depend d
+        WHERE
+            d.refclassid = 'pg_catalog.pg_extension'::pg_catalog.regclass AND
+            d.refobjid = e.oid AND
+            d.classid = 'pg_proc'::regclass AND
+            d.objid = replaced_proc::oid
+    LOOP
+        RAISE DEBUG 'Unpackaging ${renamed} from extension %', rec.extname;
+        sql := format('ALTER EXTENSION %I DROP FUNCTION ${renamed}(${args})', rec.extname);
+        EXECUTE sql;
+    END LOOP;
+END;
+\$postgis_proc_upgrade\$;
+EOF
+        print $def;
     if (/^create type (\w+)/i)
@@ -509,6 +596,91 @@ EOF
     $comment = '';
+# If any deprecated function still exist, drop it now
+my $deprecated_names = '{' . ( join ',', @renamed_deprecated_functions) . '}';
+print <<"EOF";
+-- Drop deprecated functions if possible
+DECLARE
+    deprecated_functions regprocedure[];
+    rec RECORD;
+    sql TEXT;
+    detail TEXT;
+    hint TEXT;
+BEGIN
+    -- Fetch a list of deprecated functions
+    SELECT array_agg(oid::regprocedure)
+    FROM pg_catalog.pg_proc
+    WHERE proname = ANY ('${deprecated_names}'::name[])
+    INTO deprecated_functions;
+    -- Rewrite views using deprecated functions
+    -- to improve the odds of being able to drop them
+    FOR rec IN
+        SELECT n.nspname AS schemaname,
+            c.relname AS viewname,
+            pg_get_userbyid(c.relowner) AS viewowner,
+            pg_get_viewdef(c.oid) AS definition,
+            CASE
+                WHEN 'check_option=cascaded' = ANY (c.reloptions) THEN 'WITH CASCADED CHECK OPTION'
+                WHEN 'check_option=local' = ANY (c.reloptions) THEN 'WITH LOCAL CHECK OPTION'
+                ELSE ''
+            END::text AS check_option
+        FROM pg_class c
+        LEFT JOIN pg_namespace n ON n.oid = c.relnamespace
+        WHERE c.relkind = 'v'
+        AND pg_get_viewdef(c.oid) ~ 'deprecated_by_postgis'
+    LOOP
+        sql := format('CREATE OR REPLACE VIEW %I.%I AS %s %s',
+            rec.schemaname,
+            rec.viewname,
+            regexp_replace(rec.definition, '_deprecated_by_postgis_[^(]*', '', 'g'),
+            rec.check_option
+        RAISE NOTICE 'Updating view % to not use deprecated signatures', rec.viewname;
+        BEGIN
+            EXECUTE sql;
+        EXCEPTION
+        WHEN OTHERS THEN
+                RAISE WARNING 'Could not rewrite view % using deprecated functions', rec.viewname
+                        USING DETAIL = format('%s: %s', SQLERRM, detail);
+        END;
+    END LOOP;
+    -- Try to drop all deprecated functions, raising a warning
+    -- for each one which cannot be drop
+    FOR rec IN SELECT unnest(deprecated_functions) as proc
+    LOOP --{
+        sql := format('DROP FUNCTION %s', rec.proc);
+        --RAISE DEBUG 'SQL: %', sql;
+        BEGIN
+            EXECUTE sql;
+        EXCEPTION
+        WHEN OTHERS THEN
+            hint = 'Resolve the issue';
+            IF detail LIKE '%view % depends%' THEN
+                hint = format(
+                    'Replace the view changing all occurrences of %s in its definition with %s',
+                    rec.proc,
+                    regexp_replace(rec.proc::text, '_deprecated_by_postgis[^(]*', '')
+            END IF;
+            hint = hint || ' and upgrade again';
+            RAISE WARNING 'Deprecated function % left behind: %', rec.proc, SQLERRM
+            USING DETAIL = detail, HINT = hint;
+        END;
+    END LOOP; --}
+END
+EOF
 close(INPUT);
 print "DROP TABLE _postgis_upgrade_info;\n";
Summary of changes:
 NEWS                               |   2 +
 postgis/postgis.sql.in             |  20 ++++-
 postgis/postgis_before_upgrade.sql |   6 --
 utils/postgis_proc_upgrade.pl      | 178 ++++++++++++++++++++++++++++++++++++-
 4 files changed, 194 insertions(+), 12 deletions(-)
hooks/post-receive
