[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.0-3-g82d84900f
Sun Dec 19 07:21:25 PST 2021
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  82d84900fdd26678767fee72677664f3f76b3db6 (commit)
      from  9f4eff0600e70153c1647f9597e39e34c74c349f (commit)
revisions in full, below.
commit 82d84900fdd26678767fee72677664f3f76b3db6
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Dec 14 22:54:55 2021 +0100
    Allow upgrades in presence of views using deprecated functions
    Support adding a 'Replaces' comment above functions to improve upgrade
    When a function has a line like the following in in the comments
    above its signature:
      Replaces ST_Intersection(geometry, geometry) deprecated in 3.1.0
    The upgrade script will try to drop the deprecated functions and in case
    of failure leave them behind renamed with a _deprecated_by_postgis_<version>
    suffix, warns the user about such occurrence and gives her hints on
    how to fix.
    The postgis_full_version() will report presence of such deprecated
    functions as an "incomplete upgrade".
    References #5033 in 3.2 branch (3.2.1dev)
    Includes regression tests
diff --git a/NEWS b/NEWS
index 454281d12..cedae046c 100644
--- a/NEWS
+++ b/NEWS
@@ -1,3 +1,10 @@
+PostGIS 3.2.1dev
+YYYY/MM/DD
+* Bug Fixes *
+  - #5033, allow upgrades in presence of views using deprecated
+           functions (Sandro Santilli)
 PostGIS 3.2.0 (Olivier Courtin Edition)
 2021/12/17
 This version requires PostgreSQL 9.6 or higher, GEOS 3.6 or higher
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index f54bf20cc..003d8b60f 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2926,7 +2926,10 @@ $$ LANGUAGE 'sql' STABLE;
 -- Changed: 3.0.0 also upgrade postgis_raster if it exists
 CREATE OR REPLACE FUNCTION postgis_extensions_upgrade() RETURNS text
 AS $$
-DECLARE rec record; sql text; var_schema text;
+DECLARE
+	rec record;
+	sql text;
+	var_schema text;
 BEGIN
 	FOR rec IN
@@ -2940,7 +2943,7 @@ BEGIN
 			'postgis_tiger_geocoder'
 		ORDER BY length(name) -- this is to make sure 'postgis' is first !
-	LOOP
+	LOOP --{
 		IF rec.installed_version IS NULL THEN
 			-- If the support installed by available extension
 			-- is found unpackaged, we package it
@@ -3020,7 +3023,7 @@ BEGIN
 			EXECUTE sql;
 		END IF;
-	END LOOP;
+	END LOOP; --}
 	RETURN 'Upgrade completed, run SELECT postgis_full_version(); for details';
@@ -3211,6 +3214,12 @@ BEGIN
 		fullver = fullver || ' (sfcgal procs from "' || sfcgal_scr_ver || '" need upgrade)';
 	END IF;
+	-- Check for the presence of deprecated functions
+	IF EXISTS ( SELECT oid FROM pg_catalog.pg_proc WHERE proname LIKE '%_deprecated_by_postgis_%' )
+	THEN
+		fullver = fullver || ' (deprecated functions exist, upgrade is not complete)';
+	END IF;
 	RETURN fullver;
 END
@@ -3479,6 +3488,7 @@ CREATE OR REPLACE FUNCTION ST_IsValidTrajectory(geometry)
 -- Changed: 3.1.0 to add gridSize default argument
+-- Replaces ST_Intersection(geometry, geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_Intersection(geom1 geometry, geom2 geometry, gridSize float8 DEFAULT -1)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','ST_Intersection'
@@ -3622,6 +3632,7 @@ CREATE OR REPLACE FUNCTION ST_MaximumInscribedCircle(geometry, OUT center geomet
 -- PostGIS equivalent function: ST_difference(geom1 geometry, geom2 geometry)
+-- Replaces ST_Difference(geometry, geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_Difference(geom1 geometry, geom2 geometry, gridSize float8 DEFAULT -1.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','ST_Difference'
@@ -3644,6 +3655,7 @@ CREATE OR REPLACE FUNCTION ST_Points(geometry)
 -- PostGIS equivalent function: symdifference(geom1 geometry, geom2 geometry)
+-- Replaces ST_SymDifference(geometry, geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_SymDifference(geom1 geometry, geom2 geometry, gridSize float8 DEFAULT -1.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','ST_SymDifference'
@@ -3671,6 +3683,7 @@ CREATE OR REPLACE FUNCTION ST_Union(geom1 geometry, geom2 geometry, gridSize flo
 -- Availability: 2.0.0
+-- Replaces ST_UnaryUnion(geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_UnaryUnion(geometry, gridSize float8 DEFAULT -1.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','ST_UnaryUnion'
@@ -3699,6 +3712,7 @@ CREATE OR REPLACE FUNCTION ST_ClipByBox2d(geom geometry, box box2d)
 -- Availability: 2.2.0
+-- Replaces ST_Subdivide(geometry, integer) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_Subdivide(geom geometry, maxvertices integer DEFAULT 256, gridSize float8 DEFAULT -1.0)
 	RETURNS setof geometry
 	AS 'MODULE_PATHNAME', 'ST_Subdivide'
@@ -4147,6 +4161,7 @@ CREATE AGGREGATE ST_MakeLine (geometry) (
 -- Availability: 2.3.0
 -- Changed: 3.2.0 added max_radius parameter
+-- Replaces ST_ClusterKMeans(geometry, integer) deprecated in 3.2.0
 CREATE OR REPLACE FUNCTION ST_ClusterKMeans(geom geometry, k integer, max_radius float8 default null)
 	RETURNS integer
 	AS 'MODULE_PATHNAME', 'ST_ClusterKMeans'
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index 9c1a06829..fd104bc8e 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -217,13 +217,6 @@ DROP FUNCTION IF EXISTS st_buffer(geometry, double precision); -- Does not confl
 DROP FUNCTION IF EXISTS ST_CurveToLine(geometry, integer); -- Does not conflict
 DROP FUNCTION IF EXISTS ST_CurveToLine(geometry); -- Does not conflict
-DROP FUNCTION IF EXISTS st_intersection(geometry, geometry); -- replaced in 3.1.0 by 3 args version
-DROP FUNCTION IF EXISTS st_subdivide(geometry, integer); -- replaced in 3.1.0 by 3 args version
-DROP FUNCTION IF EXISTS st_difference(geometry, geometry); -- replaced in 3.1.0 by 3 args version
-DROP FUNCTION IF EXISTS st_symdifference(geometry, geometry); -- replaced in 3.1.0 by 3 args version
-DROP FUNCTION IF EXISTS st_unaryunion(geometry); -- replaced in 3.1.0 by 3 args version
-DROP FUNCTION IF EXISTS ST_ClusterKMeans(geometry, integer); -- replaced in 3.2.0 by 3 args version
 -- geometry_columns changed parameter types so we verify if it needs to be dropped
 -- We check the catalog to see if the view (geometry_columns) has a column
 -- with name `f_table_schema` and type `character varying(256)` as it was
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index 459f80249..d7fb108a7 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -1,2 +1,5 @@
-DROP VIEW IF EXISTS upgrade_view_test;
+DROP VIEW IF EXISTS upgrade_view_test_overlay;
+DROP VIEW IF EXISTS upgrade_view_test_unaryunion;
+DROP VIEW IF EXISTS upgrade_view_test_subdivide;
+DROP VIEW IF EXISTS upgrade_view_test_union;
 DROP TABLE upgrade_test;
diff --git a/regress/hooks/hook-before-upgrade.sql b/regress/hooks/hook-before-upgrade.sql
index d4bcb8cd6..de661643d 100644
--- a/regress/hooks/hook-before-upgrade.sql
+++ b/regress/hooks/hook-before-upgrade.sql
@@ -19,8 +19,31 @@ BEGIN
 	IF vernum >= 120000
 	THEN
 		RAISE DEBUG '12+ server (%)', vernum;
-    CREATE VIEW upgrade_view_test AS
+    CREATE VIEW upgrade_view_test_union AS
     SELECT ST_Union(g1) FROM upgrade_test;
 	END IF;
 END;
 $BODY$ LANGUAGE 'plpgsql';
+-- Add view using overlay functions
+CREATE VIEW upgrade_view_test_overlay AS
+SELECT
+	ST_Intersection(g1, g1) as geometry_intersection,
+	ST_Intersection(g2, g2) as geography_intersection,
+	ST_Difference(g1, g1) as geometry_difference,
+	ST_SymDifference(g1, g1) as geometry_symdifference
+FROM upgrade_test;
+-- Add view using unaryunion function
+-- NOTE: 2.0.0 introduced ST_UnaryUnion
+CREATE VIEW upgrade_view_test_unaryunion AS
+SELECT
+	ST_UnaryUnion(g1) as geometry_unaryunion
+FROM upgrade_test;
+-- NOTE: 2.2.0 introduced ST_Subdivide
+CREATE VIEW upgrade_view_test_subdivide AS
+SELECT
+	ST_Subdivide(g1, 256) as geometry_subdivide
+FROM upgrade_test;
diff --git a/utils/postgis_proc_upgrade.pl b/utils/postgis_proc_upgrade.pl
index 23cd81266..54071f2d3 100755
--- a/utils/postgis_proc_upgrade.pl
+++ b/utils/postgis_proc_upgrade.pl
@@ -4,7 +4,7 @@
 # PostGIS - Spatial Types for PostgreSQL
 # http://postgis.net
-# Copyright (C) 2014 Sandro Santilli <strk at kbt.io>
+# Copyright (C) 2014-2021 Sandro Santilli <strk at kbt.io>
 # Copyright (C) 2009-2010 Paul Ramsey <pramsey at opengeo.org>
 # Copyright (C) 2005 Refractions Research Inc.
@@ -49,6 +49,25 @@ sub parse_last_updated
     return 0;
+sub parse_replaces
+    my @replaces = ();
+    my $comment = shift;
+    my ($name, $args, $ver);
+    foreach my $line ( split /\n/, $comment )
+        if ( $line =~ m/.*Replaces\s\s*([^\(]*)\(([^\)]*)\)\s\s*deprecated in\s\s*([^\.]*)\.([^.]*)/ )
+            $name = $1;
+            $args = $2;
+            $ver = $3*100 + $4;
+            my @r = ($name, $args, $ver);
+            push @replaces, \@r;
+    return @replaces;
 sub parse_missing
@@ -78,6 +97,8 @@ my $version_from_num = 0;
 my $schema = "";
 $schema = $ARGV[2] if @ARGV > 2;
+my @renamed_deprecated_functions = ();
 die "Unable to open input SQL file $sql_file\n"
   if ( !-f $sql_file );
@@ -168,14 +189,80 @@ while(<INPUT>)
     if (/^create or replace function/i)
-        print $_;
+        my $def .= $_;
+        my @replaced_array = parse_replaces($comment);
         my $endfunc = 0;
         while(<INPUT>)
-            print $_;
+            $def .= $_;
             $endfunc = 1 if /^\s*(\$\$\s*)?LANGUAGE /;
             last if ( $endfunc && /\;/ );
+        foreach my $replaced (@replaced_array)
+            my ($name, $args, $ver) = @$replaced;
+            $name = lc($name); # lowercase the name
+            my $renamed = $name . '_deprecated_by_postgis_' . ${ver};
+            my $replacement = "${renamed}(${args})";
+            push @renamed_deprecated_functions, ${renamed};
+            print <<"EOF";
+-- Rename $name ( $args ) deprecated in PostGIS $ver
+DO LANGUAGE 'plpgsql'
+\$postgis_proc_upgrade\$
+DECLARE
+    replaced_proc regprocedure;
+    rec RECORD;
+    new_view_def TEXT;
+    sql TEXT;
+    detail TEXT;
+BEGIN
+    -- Check if the old function signature, exists
+    BEGIN
+        replaced_proc := '$name($args)'::regprocedure;
+    EXCEPTION
+    -- Catch the "function does not exist"
+    WHEN undefined_function THEN
+        RAISE DEBUG 'Function $name($args) does not exist';
+    WHEN OTHERS THEN
+        GET STACKED DIAGNOSTICS detail := PG_EXCEPTION_DETAIL;
+        RAISE EXCEPTION 'Got % (%)', SQLERRM, SQLSTATE
+            USING DETAIL = detail;
+    END;
+    IF replaced_proc IS NULL THEN
+        $def
+        RETURN;
+    END IF;
+    -- Old function signature exists
+    -- Rename old function, to avoid ambiguities and eventually drop
+    ALTER FUNCTION $name( $args ) RENAME TO ${renamed};
+    -- Drop the function from any extension it is part of
+    -- so dump/reloads still work
+    FOR rec IN
+        SELECT e.extname
+        FROM
+            pg_extension e,
+            pg_depend d
+        WHERE
+            d.refclassid = 'pg_catalog.pg_extension'::pg_catalog.regclass AND
+            d.refobjid = e.oid AND
+            d.classid = 'pg_proc'::regclass AND
+            d.objid = replaced_proc::oid
+    LOOP
+        RAISE DEBUG 'Unpackaging ${renamed} from extension %', rec.extname;
+        sql := format('ALTER EXTENSION %I DROP FUNCTION ${renamed}(${args})', rec.extname);
+        EXECUTE sql;
+    END LOOP;
+END;
+\$postgis_proc_upgrade\$;
+EOF
+        print $def;
     if (/^create type (\w+)/i)
@@ -509,6 +596,91 @@ EOF
     $comment = '';
+# If any deprecated function still exist, drop it now
+my $deprecated_names = '{' . ( join ',', @renamed_deprecated_functions) . '}';
+print <<"EOF";
+-- Drop deprecated functions if possible
+DECLARE
+    deprecated_functions regprocedure[];
+    rec RECORD;
+    sql TEXT;
+    detail TEXT;
+    hint TEXT;
+BEGIN
+    -- Fetch a list of deprecated functions
+    SELECT array_agg(oid::regprocedure)
+    FROM pg_catalog.pg_proc
+    WHERE proname = ANY ('${deprecated_names}'::name[])
+    INTO deprecated_functions;
+    -- Rewrite views using deprecated functions
+    -- to improve the odds of being able to drop them
+    FOR rec IN
+        SELECT n.nspname AS schemaname,
+            c.relname AS viewname,
+            pg_get_userbyid(c.relowner) AS viewowner,
+            pg_get_viewdef(c.oid) AS definition,
+            CASE
+                WHEN 'check_option=cascaded' = ANY (c.reloptions) THEN 'WITH CASCADED CHECK OPTION'
+                WHEN 'check_option=local' = ANY (c.reloptions) THEN 'WITH LOCAL CHECK OPTION'
+                ELSE ''
+            END::text AS check_option
+        FROM pg_class c
+        LEFT JOIN pg_namespace n ON n.oid = c.relnamespace
+        WHERE c.relkind = 'v'
+        AND pg_get_viewdef(c.oid) ~ 'deprecated_by_postgis'
+    LOOP
+        sql := format('CREATE OR REPLACE VIEW %I.%I AS %s %s',
+            rec.schemaname,
+            rec.viewname,
+            regexp_replace(rec.definition, '_deprecated_by_postgis_[^(]*', '', 'g'),
+            rec.check_option
+        RAISE NOTICE 'Updating view % to not use deprecated signatures', rec.viewname;
+        BEGIN
+            EXECUTE sql;
+        EXCEPTION
+        WHEN OTHERS THEN
+                RAISE WARNING 'Could not rewrite view % using deprecated functions', rec.viewname
+                        USING DETAIL = format('%s: %s', SQLERRM, detail);
+        END;
+    END LOOP;
+    -- Try to drop all deprecated functions, raising a warning
+    -- for each one which cannot be drop
+    FOR rec IN SELECT unnest(deprecated_functions) as proc
+    LOOP --{
+        sql := format('DROP FUNCTION %s', rec.proc);
+        --RAISE DEBUG 'SQL: %', sql;
+        BEGIN
+            EXECUTE sql;
+        EXCEPTION
+        WHEN OTHERS THEN
+            hint = 'Resolve the issue';
+            IF detail LIKE '%view % depends%' THEN
+                hint = format(
+                    'Replace the view changing all occurrences of %s in its definition with %s',
+                    rec.proc,
+                    regexp_replace(rec.proc::text, '_deprecated_by_postgis[^(]*', '')
+            END IF;
+            hint = hint || ' and upgrade again';
+            RAISE WARNING 'Deprecated function % left behind: %', rec.proc, SQLERRM
+            USING DETAIL = detail, HINT = hint;
+        END;
+    END LOOP; --}
+END
+EOF
 close(INPUT);
 print "DROP FUNCTION _postgis_upgrade_info();\n";
Summary of changes:
 NEWS                                  |   7 ++
 postgis/postgis.sql.in                |  21 +++-
 postgis/postgis_before_upgrade.sql    |   7 --
 regress/hooks/hook-after-upgrade.sql  |   5 +-
 regress/hooks/hook-before-upgrade.sql |  25 ++++-
 utils/postgis_proc_upgrade.pl         | 178 +++++++++++++++++++++++++++++++++-
 6 files changed, 228 insertions(+), 15 deletions(-)
hooks/post-receive
