[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.0-9-g051978b
Thu Jan 7 05:52:23 PST 2021
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  051978baee30e9a2f1d2c0f7c87f296506a801ad (commit)
      from  22e3168fd3bbce6fbcbc6868b204e6cfa176ba91 (commit)
revisions in full, below.
commit 051978baee30e9a2f1d2c0f7c87f296506a801ad
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Jan 3 00:24:04 2021 +0100
    Avoid listing the same geometry in different collections
    Closes #4823 in 3.1 branch (3.1.1dev)
diff --git a/NEWS b/NEWS
index e4440da..f4b771d 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
-PostGIS 3.1.1
+PostGIS 3.1.1dev
 2021/xx/xx
  * Bug Fixes
@@ -8,6 +8,7 @@ PostGIS 3.1.1
            (Sandro Santilli)
   - #4818, Make the VSICURL synthetic driver work as documented
   - #4825, Unstable results from ST_MakeValid (Sandro Santilli)
+  - #4823, Avoid listing the same geometry in different collections
 PostGIS 3.1.0
diff --git a/liblwgeom/lwgeom_geos_clean.c b/liblwgeom/lwgeom_geos_clean.c
index 878d91b..3c12e25 100644
--- a/liblwgeom/lwgeom_geos_clean.c
+++ b/liblwgeom/lwgeom_geos_clean.c
@@ -322,7 +322,10 @@ lwcollection_make_geos_friendly(LWCOLLECTION* g)
 	uint32_t i, new_ngeoms = 0;
 	LWCOLLECTION* ret;
-	if ( ! g->ngeoms ) return lwcollection_as_lwgeom(g);
+	if ( ! g->ngeoms ) {
+		LWDEBUG(3, "lwcollection_make_geos_friendly: returning input untouched");
+		return lwcollection_as_lwgeom(g);
 	/* enough space for all components */
 	new_geoms = lwalloc(sizeof(LWGEOM*) * g->ngeoms);
@@ -334,7 +337,12 @@ lwcollection_make_geos_friendly(LWCOLLECTION* g)
 	for (i = 0; i < g->ngeoms; i++)
 		LWGEOM* newg = lwgeom_make_geos_friendly(g->geoms[i]);
-		if (newg) new_geoms[new_ngeoms++] = newg;
+		if (!newg) continue;
+		if ( newg != g->geoms[i] ) {
+			new_geoms[new_ngeoms++] = newg;
+		} else {
+			new_geoms[new_ngeoms++] = lwgeom_clone(newg);
 	ret->bbox = NULL; /* recompute later... */
@@ -908,28 +916,20 @@ lwgeom_make_valid(LWGEOM* lwgeom_in)
 	lwgeom_out = lwgeom_make_geos_friendly(lwgeom_in);
 	if (!lwgeom_out) lwerror("Could not make a geos friendly geometry out of input");
+	LWDEBUGF(4, "Input geom %p made GEOS-valid as %p", lwgeom_in, lwgeom_out);
 	geosgeom = LWGEOM2GEOS(lwgeom_out, 1);
+	if ( lwgeom_in != lwgeom_out ) {
+		lwgeom_free(lwgeom_out);
 	if (!geosgeom)
-		LWDEBUGF(4,
-			 "Original geom can't be converted to GEOS (%s)"
-			 " - will try cleaning that up first",
-			 lwgeom_geos_errmsg);
-		/* try again as we did cleanup now */
-		/* TODO: invoke LWGEOM2GEOS directly with autoclean ? */
-		geosgeom = LWGEOM2GEOS(lwgeom_out, 0);
-		if (!geosgeom)
-			lwerror("Couldn't convert POSTGIS geom to GEOS: %s", lwgeom_geos_errmsg);
-			return NULL;
+		lwerror("Couldn't convert POSTGIS geom to GEOS: %s", lwgeom_geos_errmsg);
+		return NULL;
 	else
-		LWDEBUG(4, "original geom converted to GEOS");
-		lwgeom_out = lwgeom_in;
+		LWDEBUG(4, "geom converted to GEOS");
 #if POSTGIS_GEOS_VERSION < 38
Summary of changes:
 NEWS                          |  3 ++-
 liblwgeom/lwgeom_geos_clean.c | 36 ++++++++++++++++++------------------
 2 files changed, 20 insertions(+), 19 deletions(-)
hooks/post-receive
