[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-35-g9e68f84
Fri Jan 8 08:16:24 PST 2021
the project "PostGIS".
       via  9e68f84879076487366d03e02dea237976545633 (commit)
       via  ebc52f4017cf8281fb03d51c98a0e57b7920326c (commit)
      from  6f04d19d5356231de82308047cb8ab6b3c5a6803 (commit)
revisions in full, below.
commit 9e68f84879076487366d03e02dea237976545633
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri Jan 8 16:43:24 2021 +0100
    Remove --without-wagyu option
diff --git a/.travis.yml b/.travis.yml
index 2d0e00c..73df152 100644
--- a/.travis.yml
+++ b/.travis.yml
@@ -11,7 +11,6 @@ env:
   - tag=pg13-geos39-gdal31-proj71 mode=coverage
   - tag=pg13-geos39-gdal31-proj71 mode=usan_gcc
   - tag=pg13-clang-geos39-gdal31-proj71 mode=usan_clang
-  - tag=pg13-geos39-gdal31-proj71 mode=nowagyu
   # Run tests with different dependency combinations
   - tag=latest mode=tests
diff --git a/NEWS b/NEWS
index 9edb9f7..57a8de4 100644
--- a/NEWS
+++ b/NEWS
@@ -1,6 +1,8 @@
 PostGIS 3.2.0
 2021/xx/xx
+ * Breaking changes *
+  - Removed `--without-wagyu` build option. Using Wagyu is not mandatory to build with MVT support.
 PostGIS 3.1.0
 2020/12/18
diff --git a/ci/debbie/postgis_doc_translations.sh b/ci/debbie/postgis_doc_translations.sh
index 6fffc1f..178241f 100644
--- a/ci/debbie/postgis_doc_translations.sh
+++ b/ci/debbie/postgis_doc_translations.sh
@@ -36,7 +36,7 @@ CPPFLAGS="-I${PGPATH}/include"  \
 LDFLAGS="-L${PGPATH}/lib"  ./configure \
   --with-pgconfig=${PGPATH}/bin/pg_config \
   --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
-  --without-raster --without-wagyu
+  --without-raster --without-protobuf
 make clean
 cd doc
 make update-pot
diff --git a/ci/debbie/postgis_release_docs.sh b/ci/debbie/postgis_release_docs.sh
index f15a46c..cab5358 100644
--- a/ci/debbie/postgis_release_docs.sh
+++ b/ci/debbie/postgis_release_docs.sh
@@ -35,7 +35,7 @@ CPPFLAGS="-I${PGPATH}/include"  \
 make clean
 # generating postgis_revision.h in case hasn't been generated
diff --git a/ci/travis/run_nowagyu.sh b/ci/travis/run_nowagyu.sh
deleted file mode 100644
index 6855fb9..0000000
--- a/ci/travis/run_nowagyu.sh
+++ /dev/null
@@ -1,18 +0,0 @@
-#!/usr/bin/env bash
-set -e
-WARNINGS="-Werror -Wall -Wextra -Wformat -Werror=format-security"
-WARNINGS_DISABLED="-Wno-unused-parameter -Wno-implicit-fallthrough -Wno-cast-function-type"
-# Build with coverage
-CFLAGS="-g -O0 --coverage -mtune=generic -fno-omit-frame-pointer ${WARNINGS} ${WARNINGS_DISABLED}"
-LDFLAGS="--coverage"
-/usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile -o '-F' start
-./autogen.sh
-# Standard build
-./configure --without-wagyu CFLAGS="${CFLAGS}" CXXFLAGS="${CFLAGS}" LDFLAGS="${LDFLAGS}"
-bash ./ci/travis/logbt -- make -j
-bash ./ci/travis/logbt -- make check RUNTESTFLAGS=--verbose
-(curl -S -f https://codecov.io/bash -o .github/codecov.bash && bash .github/codecov.bash) || echo "Coverage report failed"
diff --git a/configure.ac b/configure.ac
index 1bc6cca..9ac7051 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1462,74 +1462,67 @@ dnl ===========================================================================
 dnl Wagyu will only be necessary if protobuf is present to build MVTs
-HAVE_WAGYU=no
 if test "x$HAVE_PROTOBUF" = "xyes"; then
-    AC_ARG_WITH([wagyu], AC_HELP_STRING([--without-wagyu], [Don't use the wagyu library]), [], [])
-    if test "x$with_wagyu" != xno; then
-            AC_MSG_RESULT([WAGYU: Wagyu usage requested])
-            DEPS_SUBDIR="deps"
-            AC_SUBST([DEPS_SUBDIR])
-            WAGYU_LIB=libwagyu.la
-            AC_SUBST([WAGYU_LIB])
-            dnl ============================================================
-            dnl We force  to use the same compiler as Postgresql
-            CXX_SAVE="$CXX"
-            CC_SAVE="$CC"
-            CFLAGS_SAVE="$CFLAGS"
-            CXXFLAGS_SAVE="$CXXFLAGS"
-            CPPFLAGS_SAVE="$CPPFLAGS"
-            LDFLAGS_SAVE="$LDFLAGS"
-            LIBS_SAVE="$LIBS"
-            WAGYU_CXX=`"$PG_CONFIG" --cc`
-            CPPFLAGS="-x c++"
-            CFLAGS=""
-            LDFLAGS=""
-            LIBS=""
-            CXX="$WAGYU_CXX"
-            AC_PROG_CXX
-            AX_CXX_COMPILE_STDCXX(11, noext, mandatory)
-            WAGYU_CXX="$CXX -x c++"
-            dnl Check if we can declare the c++ stdlib
-            CC="$WAGYU_CXX"
-            AC_CHECK_LIB(c++, main, [HAVE_CPP=yes], [HAVE_CPP=no])
-            AC_CHECK_LIB(stdc++, main, [HAVE_STDCPP=yes], [HAVE_STDCPP=no])
-            if test "x$HAVE_CPP" = "xyes"; then
-                WAGYU_LDFLAGS="-lc++"
-            elif test "x$HAVE_STDCPP" = "xyes"; then
-                WAGYU_LDFLAGS="-lstdc++"
-            else
-                AC_MSG_WARN("Could not find a C++ standard library")
-                WAGYU_LDFLAGS=""
-            fi
-            CXX="$CXX_SAVE"
-            CC="$CC_SAVE"
-            CFLAGS="$CFLAGS_SAVE"
-            CXXFLAGS="$CXXFLAGS_SAVE"
-            CPPFLAGS="$CPPFLAGS_SAVE"
-            LDFLAGS="$LDFLAGS_SAVE"
-            LIBS="$LIBS_SAVE"
-            HAVE_WAGYU=yes
-            AC_DEFINE([HAVE_WAGYU], [1], [Define to 1 if wagyu is being built])
-            AC_SUBST([HAVE_WAGYU])
-            AC_SUBST([WAGYU_CXX])
-            AC_SUBST([WAGYU_LDFLAGS])
-            DEPS_MAKEFILE_LIST="$DEPS_MAKEFILE_LIST
-                    deps/wagyu/Makefile"
+    DEPS_SUBDIR="deps"
+    AC_SUBST([DEPS_SUBDIR])
+    WAGYU_LIB=libwagyu.la
+    AC_SUBST([WAGYU_LIB])
+    dnl ============================================================
+    dnl We force  to use the same compiler as Postgresql
+    CXX_SAVE="$CXX"
+    CC_SAVE="$CC"
+    CFLAGS_SAVE="$CFLAGS"
+    CXXFLAGS_SAVE="$CXXFLAGS"
+    CPPFLAGS_SAVE="$CPPFLAGS"
+    LDFLAGS_SAVE="$LDFLAGS"
+    LIBS_SAVE="$LIBS"
+    WAGYU_CXX=`"$PG_CONFIG" --cc`
+    CPPFLAGS="-x c++"
+    CFLAGS=""
+    LDFLAGS=""
+    LIBS=""
+    CXX="$WAGYU_CXX"
+    AC_PROG_CXX
+    AX_CXX_COMPILE_STDCXX(11, noext, mandatory)
+    WAGYU_CXX="$CXX -x c++"
+    dnl Check if we can declare the c++ stdlib
+    CC="$WAGYU_CXX"
+    AC_CHECK_LIB(c++, main, [HAVE_CPP=yes], [HAVE_CPP=no])
+    AC_CHECK_LIB(stdc++, main, [HAVE_STDCPP=yes], [HAVE_STDCPP=no])
+    if test "x$HAVE_CPP" = "xyes"; then
+        WAGYU_LDFLAGS="-lc++"
+    elif test "x$HAVE_STDCPP" = "xyes"; then
+        WAGYU_LDFLAGS="-lstdc++"
+    else
+        AC_MSG_WARN("Could not find a C++ standard library")
+        WAGYU_LDFLAGS=""
     fi
+    CXX="$CXX_SAVE"
+    CC="$CC_SAVE"
+    CFLAGS="$CFLAGS_SAVE"
+    CXXFLAGS="$CXXFLAGS_SAVE"
+    CPPFLAGS="$CPPFLAGS_SAVE"
+    LDFLAGS="$LDFLAGS_SAVE"
+    LIBS="$LIBS_SAVE"
+    HAVE_WAGYU=yes
+    AC_DEFINE([HAVE_WAGYU], [1], [Define to 1 if wagyu is being built])
+    AC_SUBST([HAVE_WAGYU])
+    AC_SUBST([WAGYU_CXX])
+    AC_SUBST([WAGYU_LDFLAGS])
+    DEPS_MAKEFILE_LIST="$DEPS_MAKEFILE_LIST
+            deps/wagyu/Makefile"
 fi
@@ -1653,7 +1646,6 @@ fi
 AC_MSG_RESULT([  PCRE support:         ${HAVE_PCRE}])
 AC_MSG_RESULT([  Perl:                 ${PERL}])
-AC_MSG_RESULT([  Wagyu:                ${HAVE_WAGYU}])
 AC_MSG_RESULT()
 AC_MSG_RESULT([ --------------- Extensions --------------- ])
diff --git a/doc/installation.xml b/doc/installation.xml
index 88d0a88..0c3a60b 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -522,14 +522,6 @@ tar -xvzf postgis-&last_release_version;.tar.gz</programlisting>
 		  </listitem>
 		</varlistentry>
 		<varlistentry>
-		  <term><command>--without-wagyu</command></term>
-		  <listitem>
-			<para>
-			  When building with MVT support, Postgis will use <ulink url="https://github.com/mapbox/wagyu/">Wagyu</ulink> to clip and validate MVT polygons. Wagyu is the fastest alternative and guarantees producing correct values for this specific case, but it requires a C++-11 compiler. With this optional argument you can disable using this library; GEOS will be used instead.
-			</para>
-		  </listitem>
-		</varlistentry>
-		<varlistentry>
 		  <term><command>--without-phony-revision</command></term>
 		  <listitem>
 			<para>
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index 59eb918..9e42c2e 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -53,13 +53,12 @@ ifeq (@HAVE_SPGIST@,yes)
 SPGIST_OBJ= gserialized_spgist_2d.o gserialized_spgist_3d.o gserialized_spgist_nd.o
 endif
+WAGYU_LIBPATH = ../deps/wagyu/@WAGYU_LIB@
 ifeq (@HAVE_PROTOBUF@,yes)
 PROTOBUF_OBJ = vector_tile.pb-c.o geobuf.pb-c.o
 UTHASH_INCLUDE = -I../deps/uthash/include
-endif
-WAGYU_LIBPATH = ../deps/wagyu/@WAGYU_LIB@
-ifeq (@HAVE_WAGYU@,yes)
 WAYGU_INCLUDE = -I../deps/wagyu
 WAYGU_LIB = $(WAGYU_LIBPATH) @WAGYU_LDFLAGS@
 WAGYU_DEP = $(WAGYU_LIBPATH)
diff --git a/postgis/mvt.c b/postgis/mvt.c
index 40757e2..571bbd9 100644
--- a/postgis/mvt.c
+++ b/postgis/mvt.c
@@ -34,6 +34,8 @@
 #ifdef HAVE_LIBPROTOBUF
 #include "utils/jsonb.h"
+#include "lwgeom_wagyu.h"
 #if POSTGIS_PGSQL_VERSION < 110
 /* See trac ticket #3867 */
 # define DatumGetJsonbP DatumGetJsonb
@@ -836,261 +838,34 @@ mvt_unsafe_clip_by_box(LWGEOM *lwg_in, GBOX *clip_box)
 	return geom_clipped;
- * Clips an input geometry using GEOSIntersection
- * It used to try to use GEOSClipByRect (as mvt_unsafe_clip_by_box) but since that produces
- * invalid output when an invalid geometry is given and detecting it resulted to be impossible,
- * we use intersection instead and, upon error, force validation of the input and retry.
- * Might return NULL
-static LWGEOM *
-mvt_safe_clip_polygon_by_box(LWGEOM *lwg_in, GBOX *clip_box)
-	LWGEOM *geom_clipped, *envelope;
-	GBOX geom_box;
-	GEOSGeometry *geos_input, *geos_box, *geos_result;
-	gbox_init(&geom_box);
-	FLAGS_SET_GEODETIC(geom_box.flags, 0);
-	lwgeom_calculate_gbox(lwg_in, &geom_box);
-	if (!gbox_overlaps_2d(&geom_box, clip_box))
-		POSTGIS_DEBUG(3, "mvt_geom: geometry outside clip box");
-		return NULL;
-	if (gbox_contains_2d(clip_box, &geom_box))
-		POSTGIS_DEBUG(3, "mvt_geom: geometry contained fully inside the box");
-		return lwg_in;
-	initGEOS(lwnotice, lwgeom_geos_error);
-	if (!(geos_input = LWGEOM2GEOS(lwg_in, 1)))
-		return NULL;
-	envelope = (LWGEOM *)lwpoly_construct_envelope(
-	    lwg_in->srid, clip_box->xmin, clip_box->ymin, clip_box->xmax, clip_box->ymax);
-	geos_box = LWGEOM2GEOS(envelope, 1);
-	lwgeom_free(envelope);
-	if (!geos_box)
-		GEOSGeom_destroy(geos_input);
-		return NULL;
-	geos_result = GEOSIntersection(geos_input, geos_box);
-	if (!geos_result)
-		POSTGIS_DEBUG(3, "mvt_geom: no geometry after intersection. Retrying after validation");
-		lwg_in = lwgeom_make_valid(lwg_in);
-			GEOSGeom_destroy(geos_box);
-			return NULL;
-		if (!geos_result)
-			return NULL;
-	GEOSSetSRID(geos_result, lwg_in->srid);
-	geom_clipped = GEOS2LWGEOM(geos_result, 0);
-	GEOSGeom_destroy(geos_result);
-	if (!geom_clipped || lwgeom_is_empty(geom_clipped))
-		POSTGIS_DEBUG(3, "mvt_geom: no geometry after clipping");
-		return NULL;
-	return geom_clipped;
- * Clips the geometry using GEOSIntersection in a "safe way", cleaning the input
- * if necessary and clipping MULTIPOLYGONs separately to reduce the impact
- * of using invalid input in GEOS
-static LWGEOM *
-mvt_iterate_clip_by_box_geos(LWGEOM *lwgeom, GBOX *clip_gbox, uint8_t basic_type)
-	if (basic_type != POLYGONTYPE)
-		return mvt_unsafe_clip_by_box(lwgeom, clip_gbox);
-	if (lwgeom->type != MULTIPOLYGONTYPE || ((LWMPOLY *)lwgeom)->ngeoms == 1)
-		return mvt_safe_clip_polygon_by_box(lwgeom, clip_gbox);
-	else
-		GBOX geom_box;
-		uint32_t i;
-		LWCOLLECTION *lwmg;
-		LWCOLLECTION *res;
-		lwgeom_calculate_gbox(lwgeom, &geom_box);
-		lwmg = ((LWCOLLECTION *)lwgeom);
-		res = lwcollection_construct_empty(
-		    MULTIPOLYGONTYPE, lwgeom->srid, FLAGS_GET_Z(lwgeom->flags), FLAGS_GET_M(lwgeom->flags));
-		for (i = 0; i < lwmg->ngeoms; i++)
-			LWGEOM *clipped = mvt_safe_clip_polygon_by_box(lwcollection_getsubgeom(lwmg, i), clip_gbox);
-			if (clipped)
-				clipped = lwgeom_to_basic_type(clipped, POLYGONTYPE);
-				if (!lwgeom_is_empty(clipped) &&
-				    (clipped->type == POLYGONTYPE || clipped->type == MULTIPOLYGONTYPE))
-					if (!lwgeom_is_collection(clipped))
-						lwcollection_add_lwgeom(res, clipped);
-					else
-						uint32_t j;
-						for (j = 0; j < ((LWCOLLECTION *)clipped)->ngeoms; j++)
-							    res, lwcollection_getsubgeom((LWCOLLECTION *)clipped, j));
-		return lwcollection_as_lwgeom(res);
- * Given a geometry, it uses GEOS operations to make sure that it's valid according
- * to the MVT spec and that all points are snapped into int coordinates
- * It iterates several times if needed, if it fails, returns NULL
-static LWGEOM *
-mvt_grid_and_validate_geos(LWGEOM *ng, uint8_t basic_type)
-	gridspec grid = {0, 0, 0, 0, 1, 1, 0, 0};
-	ng = lwgeom_to_basic_type(ng, basic_type);
-		/* Make sure there is no pending float values (clipping can do that) */
-		lwgeom_grid_in_place(ng, &grid);
-	else
-		/* For polygons we have to both snap to the integer grid and force validation.
-		 * The problem with this procedure is that snapping to the grid can create
-		 * an invalid geometry and making it valid can create float values; so
-		 * we iterate several times (up to 3) to generate a valid geom with int coordinates
-		GEOSGeometry *geo;
-		uint32_t iterations = 0;
-		static const uint32_t max_iterations = 3;
-		bool valid = false;
-		/* Grid to int */
-		initGEOS(lwgeom_geos_error, lwgeom_geos_error);
-		geo = LWGEOM2GEOS(ng, 0);
-		if (!geo)
-			return NULL;
-		valid = GEOSisValid(geo) == 1;
-		while (!valid && iterations < max_iterations)
-#if POSTGIS_GEOS_VERSION < 38
-			GEOSGeometry *geo_valid = LWGEOM_GEOS_makeValid(geo);
-#else
-			GEOSGeometry *geo_valid = GEOSMakeValid(geo);
-#endif
-			GEOSGeom_destroy(geo);
-			if (!geo_valid)
-				return NULL;
-			ng = GEOS2LWGEOM(geo_valid, 0);
-			GEOSGeom_destroy(geo_valid);
-			if (!ng)
-				return NULL;
-			iterations++;
-		if (!valid)
-			POSTGIS_DEBUG(1, "mvt_geom: Could not transform into a valid MVT geometry");
-			return NULL;
-		/* In image coordinates CW actually comes out a CCW, so we reverse */
-		lwgeom_force_clockwise(ng);
-		lwgeom_reverse_in_place(ng);
-	return ng;
-/* Clips and validates a geometry for MVT using GEOS
+/* Clips a geometry for MVT using GEOS.
+ * Does NOT work for polygons
  * Might return NULL
 static LWGEOM *
 mvt_clip_and_validate_geos(LWGEOM *lwgeom, uint8_t basic_type, uint32_t extent, uint32_t buffer, bool clip_geom)
 	LWGEOM *ng = lwgeom;
+	assert(lwgeom->type != POLYGONTYPE);
+	assert(lwgeom->type != MULTIPOLYGONTYPE);
 	if (clip_geom)
+		gridspec grid = {0, 0, 0, 0, 1, 1, 0, 0};
 		GBOX bgbox;
-		gbox_init(&bgbox);
 		bgbox.xmax = bgbox.ymax = (double)extent + (double)buffer;
 		bgbox.xmin = bgbox.ymin = -(double)buffer;
 		FLAGS_SET_GEODETIC(bgbox.flags, 0);
-		ng = mvt_iterate_clip_by_box_geos(lwgeom, &bgbox, basic_type);
-		if (!ng || lwgeom_is_empty(ng))
-			POSTGIS_DEBUG(3, "mvt_geom: no geometry after clip");
-			return NULL;
+		ng = mvt_unsafe_clip_by_box(ng, &bgbox);
-	ng = mvt_grid_and_validate_geos(ng, basic_type);
-	/* Make sure we return the expected type */
-	if (!ng || basic_type != lwgeom_get_basic_type(ng))
-		/* Drop type changes to play nice with MVT renderers */
-		POSTGIS_DEBUG(1, "mvt_geom: Dropping geometry after type change");
-		return NULL;
+		/* Make sure there is no pending float values (clipping can do that) */
+		lwgeom_grid_in_place(ng, &grid);
 	return ng;
-#ifdef HAVE_WAGYU
-#include "lwgeom_wagyu.h"
 static LWGEOM *
 mvt_clip_and_validate(LWGEOM *lwgeom, uint8_t basic_type, uint32_t extent, uint32_t buffer, bool clip_geom)
@@ -1120,15 +895,6 @@ mvt_clip_and_validate(LWGEOM *lwgeom, uint8_t basic_type, uint32_t extent, uint3
 	return clipped_lwgeom;
-#else /* ! HAVE_WAGYU */
-static LWGEOM *
-mvt_clip_and_validate(LWGEOM *lwgeom, uint8_t basic_type, uint32_t extent, uint32_t buffer, bool clip_geom)
-	return mvt_clip_and_validate_geos(lwgeom, basic_type, extent, buffer, clip_geom);
-#endif
  * Transform a geometry into vector tile coordinate space.
diff --git a/postgis/postgis_libprotobuf.c b/postgis/postgis_libprotobuf.c
index 6bc95e0..3ba7bde 100644
--- a/postgis/postgis_libprotobuf.c
+++ b/postgis/postgis_libprotobuf.c
@@ -5,9 +5,6 @@
 #include <protobuf-c/protobuf-c.h>
-#endif
-#ifdef HAVE_WAGYU
 #endif
@@ -26,9 +23,9 @@ Datum postgis_libprotobuf_version(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(postgis_wagyu_version);
 Datum postgis_wagyu_version(PG_FUNCTION_ARGS)
-#ifndef HAVE_WAGYU
+#ifndef HAVE_LIBPROTOBUF
 	PG_RETURN_NULL();
-#else /* HAVE_WAGYU  */
+#else /* HAVE_LIBPROTOBUF  */
 	const char *ver = libwagyu_version();
 	text *result = cstring_to_text(ver);
 	PG_RETURN_POINTER(result);
diff --git a/postgis/postgis_module.c b/postgis/postgis_module.c
index 1cccc88..2ebc7a3 100644
--- a/postgis/postgis_module.c
+++ b/postgis/postgis_module.c
@@ -35,7 +35,7 @@
 #include "lwgeom_pg.h"
 #include "geos_c.h"
-#ifdef HAVE_WAGYU
+#ifdef HAVE_LIBPROTOBUF
 #endif
@@ -97,7 +97,7 @@ handleInterrupt(int sig)
   GEOS_interruptRequest();
-#ifdef HAVE_WAGYU
   lwgeom_wagyu_interruptRequest();
 #endif
diff --git a/postgis_config.h.in b/postgis_config.h.in
index 18d6b70..a439f55 100644
--- a/postgis_config.h.in
+++ b/postgis_config.h.in
@@ -71,9 +71,6 @@
 /* Define to 1 if you have the <unistd.h> header file. */
 #undef HAVE_UNISTD_H
-/* Define to 1 if wagyu is being built */
-#undef HAVE_WAGYU
 /* Define to 1 if sfcgal is being built */
 #undef HAVE_SFCGAL
diff --git a/regress/core/mvt.sql b/regress/core/mvt.sql
index c813d84..a4c29e4 100644
--- a/regress/core/mvt.sql
+++ b/regress/core/mvt.sql
@@ -727,10 +727,10 @@ SELECT '#4348Crash', COALESCE(ST_Npoints(ST_AsMVTGeom(
 )), 0) BETWEEN 0 AND 100;
 WITH geom AS (
-	SELECT 'TRIANGLE((0 0, 1 1, 0 1, 0 0))'::geometry geom
+	SELECT 1 as id, 'TRIANGLE((0 0, 1 1, 0 1, 0 0))'::geometry geom
 	union all
-	SELECT 'TIN(((0 0, 1 1, 0 1, 0 0)))'::geometry geom
+	SELECT 2 as id, 'TIN(((0 0, 1 1, 0 1, 0 0)))'::geometry geom
 	union all
-	SELECT 'TRIANGLE EMPTY'::geometry geom
+	SELECT 3 as id, 'TRIANGLE EMPTY'::geometry geom
-select '#4399', 'ST_AsMVTGeom', ST_AsMVTGeom(geom, ST_MakeBox2D(ST_Point(0, 0), ST_Point(32, 32)))::text from geom;
+select '#4399', id, 'ST_AsMVTGeom', ST_AsText(ST_AsMVTGeom(geom, ST_MakeBox2D(ST_Point(0, 0), ST_Point(32, 32))))::text from geom order by id asc;
diff --git a/regress/core/mvt_expected b/regress/core/mvt_expected
index ece6d12..bcbcc1c 100644
--- a/regress/core/mvt_expected
+++ b/regress/core/mvt_expected
@@ -142,6 +142,6 @@ Ag==
 #4348Reversed2|t
 #4348Point|t
 #4348Crash|t
-#4399|ST_AsMVTGeom|011100000001000000040000000000000000000000000000000000B0400000000000000000000000000000AF400000000000006040000000000000AF400000000000000000000000000000B040
+#4399|1|ST_AsMVTGeom|TRIANGLE((0 4096,128 3968,0 3968,0 4096))
+#4399|2|ST_AsMVTGeom|TRIANGLE((0 4096,128 3968,0 3968,0 4096))
+#4399|3|ST_AsMVTGeom|
commit ebc52f4017cf8281fb03d51c98a0e57b7920326c
Date:   Fri Jan 8 16:09:31 2021 +0100
    USAN Clang build: Update to clang 11
diff --git a/ci/travis/run_usan_clang.sh b/ci/travis/run_usan_clang.sh
index f50f158..ac03e40 100644
--- a/ci/travis/run_usan_clang.sh
+++ b/ci/travis/run_usan_clang.sh
@@ -10,7 +10,7 @@ export ASAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
 export MSAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
 #Run postgres preloading sanitizer libs
-LD_PRELOAD=/usr/lib/clang/9/lib/linux/libclang_rt.asan-x86_64.so \
+LD_PRELOAD=/usr/lib/clang/11/lib/linux/libclang_rt.asan-x86_64.so \
 /usr/local/pgsql/bin/pg_ctl -c -o '-F' -l /tmp/logfile start
Summary of changes:
 .travis.yml                           |   1 -
 NEWS                                  |   2 +
 ci/debbie/postgis_doc_translations.sh |   2 +-
 ci/debbie/postgis_release_docs.sh     |   2 +-
 ci/travis/run_nowagyu.sh              |  18 ---
 ci/travis/run_usan_clang.sh           |   2 +-
 configure.ac                          | 126 ++++++++---------
 doc/installation.xml                  |   8 --
 postgis/Makefile.in                   |   5 +-
 postgis/mvt.c                         | 254 ++--------------------------------
 postgis/postgis_libprotobuf.c         |   7 +-
 postgis/postgis_module.c              |   4 +-
 postgis_config.h.in                   |   3 -
 regress/core/mvt.sql                  |   8 +-
 regress/core/mvt_expected             |   6 +-
 15 files changed, 87 insertions(+), 361 deletions(-)
 delete mode 100644 ci/travis/run_nowagyu.sh
hooks/post-receive
