[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-38-g3c72b78
Mon Jan 11 03:04:28 PST 2021
the project "PostGIS".
       via  3c72b78a4bee798167aa91c8889d59624efa2e49 (commit)
      from  a1e81a42a92d8077422d368ecf6b1cb28d961308 (commit)
revisions in full, below.
commit 3c72b78a4bee798167aa91c8889d59624efa2e49
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jan 11 12:04:08 2021 +0100
    Drop dead SRID-checking code in topology.ValidateTopology
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index c08f1be..30111cb 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1470,6 +1470,7 @@ BEGIN
     END IF;
+    -- Check edge being simple (ie: not self-intersecting)
     IF NOT ST_IsSimple(rec.geom) THEN
       retrec.error = 'edge not simple';
       retrec.id1 = rec.id1;
@@ -1664,24 +1665,6 @@ BEGIN
   END LOOP;
-#if 0
-  -- Check SRID consistency
-  FOR rec in EXECUTE
-    'SELECT count(*) FROM ( getSRID(geom) FROM '
-    || quote_ident(toponame) || '.edge '
-       ' UNION '
-    'SELECT getSRID(geom) FROM '
-    || quote_ident(toponame) || '.node )'
-  LOOP
-    IF rec.count > 1 THEN
-      retrec.error = 'mixed SRIDs';
-      retrec.id1 = NULL;
-      retrec.id2 = NULL;
-      RETURN NEXT retrec;
-    END IF;
-  END LOOP;
-#endif
   DROP TABLE face_check;
   RETURN;
Summary of changes:
 topology/topology.sql.in | 19 +------------------
 1 file changed, 1 insertion(+), 18 deletions(-)
hooks/post-receive
