[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-39-g2039722
Mon Jan 11 03:27:13 PST 2021
the project "PostGIS".
       via  2039722000192f082a29a32dce47dd4f899edb93 (commit)
      from  3c72b78a4bee798167aa91c8889d59624efa2e49 (commit)
revisions in full, below.
commit 2039722000192f082a29a32dce47dd4f899edb93
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jan 11 12:21:17 2021 +0100
    Simplify queries in ValidateTopology to avoid EXECUTE
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 30111cb..03b4370 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1616,9 +1616,9 @@ BEGIN
        'face_check (face_id);';
   -- Scan the table looking for NULL geometries
-  FOR rec IN EXECUTE
-    'SELECT f1.face_id FROM '
-       'face_check f1 WHERE f1.geom IS NULL OR ST_IsEmpty(f1.geom)'
+  FOR rec IN
+    SELECT face_id FROM face_check
+    WHERE geom IS NULL OR ST_IsEmpty(geom)
   LOOP
     -- Face missing !
     retrec.error := 'face has no rings';
@@ -1629,14 +1629,17 @@ BEGIN
   -- Scan the table looking for overlap or containment
   -- TODO: also check for MBR consistency
-    'SELECT f1.geom, f1.face_id as id1, f2.face_id as id2, '
-       ' ST_Relate(f1.geom, f2.geom) as im'
-       ' FROM '
-       'face_check f1, '
-       'face_check f2 '
-       'WHERE f1.face_id < f2.face_id'
-       ' AND f1.geom && f2.geom'
+  FOR rec IN
+    SELECT
+      f1.geom,
+      f1.face_id as id1,
+      f2.face_id as id2,
+      ST_Relate(f1.geom, f2.geom) as im
+    FROM
+      face_check f1,
+      face_check f2
+      WHERE f1.face_id < f2.face_id
+      AND f1.geom && f2.geom
   LOOP
     -- Face overlap
Summary of changes:
 topology/topology.sql.in | 25 ++++++++++++++-----------
 1 file changed, 14 insertions(+), 11 deletions(-)
hooks/post-receive
