[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-40-gd6fd952
Mon Jan 11 06:40:28 PST 2021
the project "PostGIS".
       via  d6fd9521b664be6e94102d1e4c778eaa85a2fb05 (commit)
      from  2039722000192f082a29a32dce47dd4f899edb93 (commit)
revisions in full, below.
commit d6fd9521b664be6e94102d1e4c778eaa85a2fb05
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jan 11 13:07:02 2021 +0100
    Have ValidateTopology check for node containing_face
    Includes automated testcase
    Closes #3233
diff --git a/NEWS b/NEWS
index 57a8de4..318c8ad 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,9 @@ PostGIS 3.2.0
  * Breaking changes *
   - Removed `--without-wagyu` build option. Using Wagyu is not mandatory to build with MVT support.
+ * Enhancements *
+  - #3233, ValidateTopology check for node's containing_face (Sandro Santilli)
 PostGIS 3.1.0
 2020/12/18
diff --git a/topology/test/regress/validatetopology.sql b/topology/test/regress/validatetopology.sql
index 4c5e57c..b528aa4 100644
--- a/topology/test/regress/validatetopology.sql
+++ b/topology/test/regress/validatetopology.sql
@@ -22,3 +22,25 @@ SELECT '#1797', '---', null, null ORDER BY 1,2,3,4;
 select null from ( select topology.DropTopology('t') ) as dt;
+-- Test correctness of node.containing_face
+-- See https://trac.osgeo.org/postgis/ticket/3233
+SELECT null from ( select topology.CreateTopology('t') ) as ct;
+SELECT null from ( select TopoGeo_addPolygon('t', 'POLYGON((0 0,10 0,10 10,0 10,0 0))') ) af;
+SELECT null from ( select TopoGeo_addPoint('t', 'POINT(5 5)') ) ap;
+SELECT '#3233.0', (ValidateTopology('t')).* UNION
+SELECT '#3233.0', '---', null, null ORDER BY 1,2,3,4;
+-- 1. Set wrong containing_face for isolated node
+UPDATE t.node SET containing_face = 0 WHERE ST_Equals(geom, 'POINT(5 5)');
+SELECT '#3233.1', (ValidateTopology('t')).* UNION
+SELECT '#3233.1', '---', null, null ORDER BY 1,2,3,4;
+-- 2. Set null containing_face for isolated node
+UPDATE t.node SET containing_face = NULL WHERE ST_Equals(geom, 'POINT(5 5)');
+SELECT '#3233.2', (ValidateTopology('t')).* UNION
+SELECT '#3233.2', '---', null, null ORDER BY 1,2,3,4;
+-- 3. Set containing_face for non-isolated node
+UPDATE t.node SET containing_face = 1 WHERE ST_Equals(geom, 'POINT(5 5)');
+UPDATE t.node SET containing_face = 0 WHERE NOT ST_Equals(geom, 'POINT(5 5)');
+SELECT '#3233.3', (ValidateTopology('t')).* UNION
+SELECT '#3233.3', '---', null, null ORDER BY 1,2,3,4;
+SELECT null from ( select topology.DropTopology('t') ) as dt;
diff --git a/topology/test/regress/validatetopology_expected b/topology/test/regress/validatetopology_expected
index c3de174..2a97b04 100644
--- a/topology/test/regress/validatetopology_expected
+++ b/topology/test/regress/validatetopology_expected
@@ -1,2 +1,9 @@
 #1789|---||
 #1797|---||
+#3233.0|---||
+#3233.1|---||
+#3233.1|isolated node has wrong containing_face|2|
+#3233.2|---||
+#3233.2|isolated node has wrong containing_face|2|
+#3233.3|---||
+#3233.3|not-isolated node has not-null containing_face|1|
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 03b4370..e1d60bc 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1668,6 +1668,34 @@ BEGIN
   END LOOP;
+  -- Check nodes have correct containing_face (#3233)
+  FOR rec IN EXECUTE format(
+    $SQL$
+      SELECT n.node_id, f.face_id, e.edge_id
+      FROM %1$I.node n
+      LEFT JOIN face_check f ON ( ST_Contains(f.geom, n.geom) )
+      LEFT JOIN %1$I.edge e ON (
+        ST_Equals(ST_StartPoint(e.geom), n.geom) OR
+        ST_Equals(ST_EndPoint(e.geom), n.geom)
+      WHERE
+       n.containing_face != f.face_id
+        OR
+       ( n.containing_face IS NULL AND f.face_id IS NOT NULL )
+        OR
+       ( n.containing_face IS NOT NULL AND e.edge_id IS NOT NULL )
+    $SQL$, toponame)
+  LOOP
+    IF rec.edge_id IS NOT NULL THEN
+      retrec.error := 'not-isolated node has not-null containing_face';
+    ELSE
+      retrec.error := 'isolated node has wrong containing_face';
+    END IF;
+    retrec.id1 := rec.node_id;
+    retrec.id2 := NULL; -- TODO: write expected containing_face here ?
+    RETURN NEXT retrec;
+  END LOOP;
   DROP TABLE face_check;
   RETURN;
Summary of changes:
 NEWS                                            |  3 +++
 topology/test/regress/validatetopology.sql      | 22 +++++++++++++++++++
 topology/test/regress/validatetopology_expected |  7 +++++++
 topology/topology.sql.in                        | 28 +++++++++++++++++++++++++
 4 files changed, 60 insertions(+)
hooks/post-receive
