[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-41-g1708888
Mon Jan 11 07:36:16 PST 2021
the project "PostGIS".
       via  17088887c6df99a0e94f362f11371c92aada8720 (commit)
      from  d6fd9521b664be6e94102d1e4c778eaa85a2fb05 (commit)
revisions in full, below.
commit 17088887c6df99a0e94f362f11371c92aada8720
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jan 11 16:34:15 2021 +0100
    Fix ValidateTopology check for node containing_face
    Update pre-existing testcase which did contain an invalid
    node's containing_face
    References #3233
diff --git a/topology/test/regress/legacy_invalid_expected b/topology/test/regress/legacy_invalid_expected
index 5fc633a..e47d167 100644
--- a/topology/test/regress/legacy_invalid_expected
+++ b/topology/test/regress/legacy_invalid_expected
@@ -18,4 +18,5 @@ face without edges|10|
 face has no rings|10|
 face within face|11|2
 face overlaps face|2|12
+not-isolated node has not-null containing_face|4|
 Topology 'invalid_topology' dropped
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index e1d60bc..2943854 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1671,22 +1671,35 @@ BEGIN
   -- Check nodes have correct containing_face (#3233)
   FOR rec IN EXECUTE format(
     $SQL$
-      SELECT n.node_id, f.face_id, e.edge_id
+      SELECT
+        n.node_id,
+        -- in a corrupted topology multiple faces may contain the node
+        min(f.face_id) face_id,
+        -- multiple edges may contain the node
+        min(e.edge_id) edge_id
       FROM %1$I.node n
       LEFT JOIN face_check f ON ( ST_Contains(f.geom, n.geom) )
       LEFT JOIN %1$I.edge e ON (
         ST_Equals(ST_StartPoint(e.geom), n.geom) OR
         ST_Equals(ST_EndPoint(e.geom), n.geom)
       WHERE
-       n.containing_face != f.face_id
-        OR
-       ( n.containing_face IS NULL AND f.face_id IS NOT NULL )
-        OR
-       ( n.containing_face IS NOT NULL AND e.edge_id IS NOT NULL )
+         e.edge_id IS NULL AND (
+          n.containing_face != f.face_id
+          OR ( n.containing_face IS NULL AND f.face_id IS NOT NULL )
+       OR ( n.containing_face IS NOT NULL AND e.edge_id IS NOT NULL )
+      GROUP BY n.node_id, n.containing_face
     $SQL$, toponame)
   LOOP
     IF rec.edge_id IS NOT NULL THEN
+      -- node is not really isolated
       retrec.error := 'not-isolated node has not-null containing_face';
     ELSE
       retrec.error := 'isolated node has wrong containing_face';
Summary of changes:
 topology/test/regress/legacy_invalid_expected |  1 +
 topology/topology.sql.in                      | 25 +++++++++++++++++++------
 2 files changed, 20 insertions(+), 6 deletions(-)
hooks/post-receive
