[postgis-tickets] [PostGIS] #4923: ValidateTopologyRelation (was: ValidateTopology does not check for existance of elements referenced in relation table)
PostGIS trac at osgeo.org
Tue Jul 6 10:15:57 PDT 2021
  Reporter:  strk         |      Owner:  strk
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 3.2.0
 Component:  topology     |    Version:
Resolution:               |   Keywords:
Description changed by strk:
Old description:
> When the `element_id` field of the relation table points to unexistent
> elements this is NOT reported by ValidateTopology, I guess it should
> be...
New description:
 elements this is NOT reported by ValidateTopology. As ValidateTopology now
 has an optional bounding box parameter, it's better to use a separate
 function for checking the relation table
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4923#comment:1>
