[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-275-g96cb70a
Tue Jul 6 10:40:13 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  96cb70a4803f5d9856c811a4684bf801751648da (commit)
      from  44fb5e6edcb59c9582e83d58e8f286b2bd20357e (commit)
revisions in full, below.
commit 96cb70a4803f5d9856c811a4684bf801751648da
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jul 6 18:18:38 2021 +0200
    Add ValidateTopologyRelation function
    Closes #4923
    Includes regress test and simple docs
diff --git a/NEWS b/NEWS
index 5cc7e53..05dbcd5 100644
--- a/NEWS
+++ b/NEWS
@@ -27,6 +27,7 @@ PostGIS 3.2.0
            line to topology (Sandro Santilli)
  * New features*
+  - #4923, topology.ValidateTopologyRelation (Sandro Santilli)
   - #4933, topology.GetFaceContainingPoint (Sandro Santilli)
   - #2175, ST_Scroll (Sandro Santilli)
   - #4841, FindTopology to quickly get a topology record (Sandro Santilli)
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 952b5fb..6e64c5b 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -658,6 +658,42 @@ face without edges |   0 |
 			</refsection>
 		</refentry>
+		<refentry id="ValidateTopologyRelation">
+			<refnamediv>
+				<refname>ValidateTopologyRelation</refname>
+				<refpurpose>Returns info about invalid topology relation records</refpurpose>
+			</refnamediv>
+			<refsynopsisdiv>
+				<funcsynopsis>
+					<funcprototype>
+					<funcdef>setof record <function>ValidateTopologyRelation</function></funcdef>
+					<paramdef><type>varchar </type> <parameter>toponame</parameter></paramdef>
+					</funcprototype>
+				</funcsynopsis>
+			</refsynopsisdiv>
+			<refsection>
+                <title>Description</title>
+                <para>
+Returns a set records giving information about invalidities in the
+relation table of the topology.
+                </para>
+                <!-- use this format if new function -->
+                <para>Availability: 3.2.0</para>
+			</refsection>
+			<!-- Optionally add a "See Also" section -->
+			<refsection>
+				<title>See Also</title>
+				<para><xref linkend="ValidateTopology"/></para>
+			</refsection>
+		</refentry>
 		<refentry id="FindTopology">
 			<refnamediv>
 				<refname>FindTopology</refname>
diff --git a/topology/Makefile.in b/topology/Makefile.in
index d6d5fea..42763b6 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -126,6 +126,7 @@ topology.sql: \
 	sql/manage/FindTopology.sql.in \
 	sql/manage/ManageHelper.sql.in \
 	sql/manage/ValidateTopology.sql.in \
+	sql/manage/ValidateTopologyRelation.sql.in \
 	sql/topoelement/topoelement_agg.sql.in \
 	sql/topogeometry/type.sql.in \
 	sql/topogeometry/totopogeom.sql.in \
diff --git a/topology/sql/manage/ValidateTopologyRelation.sql.in b/topology/sql/manage/ValidateTopologyRelation.sql.in
new file mode 100644
index 0000000..588d40d
--- /dev/null
+++ b/topology/sql/manage/ValidateTopologyRelation.sql.in
@@ -0,0 +1,134 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- Copyright (C) 2021 Sandro Santilli <strk at kbt.io>
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+-- Author: Sandro Santilli <strk at kbt.io>
+-- Invalidities are:
+--   - Referenced element does not exist
+--   - Same element listed twice
+CREATE OR REPLACE FUNCTION topology.ValidateTopologyRelation(toponame varchar)
+RETURNS TABLE(error text, layer_id int, topogeo_id int, element_id int)
+AS
+$BODY$
+DECLARE
+  layerrec RECORD;
+  rel RECORD;
+  search_path_backup text;
+BEGIN
+  IF NOT EXISTS (
+    SELECT oid
+    FROM pg_catalog.pg_namespace
+    WHERE nspname = toponame
+  THEN
+    RAISE EXCEPTION 'Topology schema % does not exist', toponame;
+  END IF;
+  IF NOT EXISTS (
+    SELECT id
+    FROM topology.topology
+    WHERE name = toponame
+  THEN
+    RAISE WARNING 'Topology % is not registered in topology.topology', toponame;
+  END IF;
+  EXECUTE 'SHOW search_path' INTO search_path_backup;
+  EXECUTE 'SET search_PATH TO ' || quote_ident(toponame) || ','
+                                || search_path_backup;
+  FOR layerrec IN SELECT * FROM topology.layer
+  LOOP --{
+    IF layerrec.child_id IS NULL
+    THEN --{ Layer is simple
+      -- Check that all referenced nodes exist
+      FOR rel IN
+        SELECT r.layer_id, r.topogeo_id, r.element_id
+        FROM relation r
+        WHERE r.layer_id = layerrec.layer_id
+        AND r.element_type = 1
+        AND r.element_id NOT IN (
+          SELECT node_id FROM node
+      LOOP
+        error := 'TopoGeometry references unexistent node';
+        layer_id := rel.layer_id;
+        topogeo_id := rel.topogeo_id;
+        element_id := rel.element_id;
+        RETURN NEXT;
+      END LOOP;
+      -- Check that all referenced edges exist
+      FOR rel IN
+        FROM relation r
+        AND r.element_type = 2
+        AND abs(r.element_id) NOT IN (
+          SELECT edge_id FROM edge_data
+      LOOP
+        error := 'TopoGeometry references unexistent edge';
+        RETURN NEXT;
+      END LOOP;
+      -- Check that all referenced faces exist
+      FOR rel IN
+        FROM relation r
+        AND r.element_type = 3
+          SELECT face_id FROM face
+      LOOP
+        error := 'TopoGeometry references unexistent face';
+        RETURN NEXT;
+      END LOOP;
+    ELSE -- }{ Layer is hierarchical
+      --RAISE DEBUG 'Checking hierarchical layer %', layerrec.layer_id;
+      FOR rel IN
+        FROM relation r
+          SELECT r2.topogeo_id
+          FROM relation r2
+          WHERE r2.layer_id = layerrec.child_id
+      LOOP
+        error := 'TopoGeometry references unexistent child';
+        RETURN NEXT;
+      END LOOP;
+    END IF; --} Layer is hierarchical
+  END LOOP; --}
+  EXECUTE 'SET search_PATH TO ' || search_path_backup;
+END;
+$BODY$
+LANGUAGE 'plpgsql' VOLATILE STRICT;
diff --git a/topology/test/regress/validatetopologyrelation.sql b/topology/test/regress/validatetopologyrelation.sql
index 0000000..36ab036
--- /dev/null
+++ b/topology/test/regress/validatetopologyrelation.sql
@@ -0,0 +1,50 @@
+\set VERBOSITY terse
+set client_min_messages to ERROR;
+\i ../load_topology.sql
+\i ../load_features.sql
+\i ../hierarchy.sql
+--\i ../more_features.sql
+SELECT 'valid-start', * FROM topology.ValidateTopologyRelation('city_data');
+-- Delete all primitives
+DELETE FROM city_data.edge_data;
+DELETE FROM city_data.node;
+DELETE FROM city_data.face WHERE face_id > 0;
+SELECT 'invalid-primitives', * FROM topology.ValidateTopologyRelation('city_data')
+ORDER BY 3,4,5;
+-- Delete features from primitive tables
+WITH
+deleted_land_parcels AS (
+  DELETE FROM features.land_parcels
+  RETURNING feature
+deleted_traffic_signs AS (
+  DELETE FROM features.traffic_signs
+  RETURNING feature
+deleted_city_streets AS (
+  DELETE FROM features.city_streets
+  RETURNING feature
+SELECT NULL FROM (
+  SELECT ClearTopoGeom(feature) FROM deleted_land_parcels
+    UNION
+  SELECT ClearTopoGeom(feature) FROM deleted_traffic_signs
+    UNION
+  SELECT ClearTopoGeom(feature) FROM deleted_city_streets
+) foo
+SELECT 'invalid-hierarchical', * FROM topology.ValidateTopologyRelation('city_data')
+ORDER BY 3,4,5;
+--SELECT * FROM topology.layer WHERE child_id IS NOT NULL;
+SELECT topology.DropTopology('city_data');
+DROP SCHEMA features CASCADE;
diff --git a/topology/test/regress/validatetopologyrelation_expected b/topology/test/regress/validatetopologyrelation_expected
index 0000000..b08a3a0
--- /dev/null
+++ b/topology/test/regress/validatetopologyrelation_expected
@@ -0,0 +1,28 @@
+invalid-primitives|TopoGeometry references unexistent face|1|1|3
+invalid-primitives|TopoGeometry references unexistent face|1|1|6
+invalid-primitives|TopoGeometry references unexistent face|1|2|4
+invalid-primitives|TopoGeometry references unexistent face|1|2|7
+invalid-primitives|TopoGeometry references unexistent face|1|3|5
+invalid-primitives|TopoGeometry references unexistent face|1|3|8
+invalid-primitives|TopoGeometry references unexistent face|1|4|2
+invalid-primitives|TopoGeometry references unexistent face|1|5|1
+invalid-primitives|TopoGeometry references unexistent node|2|1|14
+invalid-primitives|TopoGeometry references unexistent node|2|2|13
+invalid-primitives|TopoGeometry references unexistent node|2|3|6
+invalid-primitives|TopoGeometry references unexistent node|2|4|4
+invalid-primitives|TopoGeometry references unexistent edge|3|1|-10
+invalid-primitives|TopoGeometry references unexistent edge|3|1|9
+invalid-primitives|TopoGeometry references unexistent edge|3|2|-5
+invalid-primitives|TopoGeometry references unexistent edge|3|2|4
+invalid-primitives|TopoGeometry references unexistent edge|3|3|25
+invalid-primitives|TopoGeometry references unexistent edge|3|4|3
+invalid-hierarchical|TopoGeometry references unexistent child|4|1|1
+invalid-hierarchical|TopoGeometry references unexistent child|4|1|2
+invalid-hierarchical|TopoGeometry references unexistent child|4|2|3
+invalid-hierarchical|TopoGeometry references unexistent child|4|2|4
+invalid-hierarchical|TopoGeometry references unexistent child|5|1|1
+invalid-hierarchical|TopoGeometry references unexistent child|5|1|2
+invalid-hierarchical|TopoGeometry references unexistent child|5|2|4
+invalid-hierarchical|TopoGeometry references unexistent child|6|1|1
+invalid-hierarchical|TopoGeometry references unexistent child|6|1|2
+Topology 'city_data' dropped
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index d23f1dc..8719604 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1812,6 +1812,7 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 #include "sql/manage/FindTopology.sql.in"
 #include "sql/manage/FindLayer.sql.in"
 #include "sql/manage/ValidateTopology.sql.in"
+#include "sql/manage/ValidateTopologyRelation.sql.in"
 CREATE OR REPLACE FUNCTION topology.postgis_topology_scripts_installed() RETURNS text
Summary of changes:
 NEWS                                               |   1 +
 doc/extras_topology.xml                            |  36 ++++++
 topology/Makefile.in                               |   1 +
 .../sql/manage/ValidateTopologyRelation.sql.in     | 134 +++++++++++++++++++++
 topology/test/regress/validatetopologyrelation.sql |  50 ++++++++
 .../test/regress/validatetopologyrelation_expected |  28 +++++
 topology/topology.sql.in                           |   1 +
 7 files changed, 251 insertions(+)
 create mode 100644 topology/sql/manage/ValidateTopologyRelation.sql.in
 create mode 100644 topology/test/regress/validatetopologyrelation.sql
 create mode 100644 topology/test/regress/validatetopologyrelation_expected
hooks/post-receive
