[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-286-gce90fc7
Thu Jul 8 04:34:10 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  ce90fc77c3b3bd673ef30829bc8205a683e47390 (commit)
      from  8b0ecf66da15b39093f36b6be84b5f84817d5bac (commit)
revisions in full, below.
commit ce90fc77c3b3bd673ef30829bc8205a683e47390
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 8 13:33:54 2021 +0200
    Reduce debugging during ValidateTopology
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index 375cd29..81f4572 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -180,11 +180,11 @@ BEGIN
       FROM edgering
       INTO rec;
-      RAISE DEBUG 'Ring % - edges:[%], faces:[%]',
-        nextEdge,
-        array_to_string(rec.edges, ','),
-        array_to_string(rec.side_faces, ',')
+--      RAISE DEBUG 'Ring % - edges:[%], faces:[%]',
+--        nextEdge,
+--        array_to_string(rec.edges, ','),
+--        array_to_string(rec.side_faces, ',')
       -- Check that there's a single face advertised
       IF array_upper(rec.side_faces,1) != 1
Summary of changes:
 topology/sql/manage/ValidateTopology.sql.in | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
