[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-287-g1674bd6
Thu Jul 8 06:16:48 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  1674bd635c2a82c67de074f095fd6241f4cc70fb (commit)
      from  ce90fc77c3b3bd673ef30829bc8205a683e47390 (commit)
revisions in full, below.
commit 1674bd635c2a82c67de074f095fd6241f4cc70fb
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 8 15:16:32 2021 +0200
    Move edge-linking checking code in its own function
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index 81f4572..a6b119c 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -62,7 +62,155 @@ END;
 $BODY$
 LANGUAGE 'plpgsql' IMMUTABLE STRICT;
+-- Check that the edges incident to topology nodes
+-- (as advertised by their start_node/end_node)
+-- correctly link to the next incident node on each
+-- side (CW and CCW)
+-- NOTE: if start_node/end_node values are incorrect the behavior
+--       of this function is undefined
+-- NOTE: assumes search_path was set before calling this function
+CREATE OR REPLACE FUNCTION topology._ValidateTopologyEdgeLinking(bbox geometry DEFAULT NULL)
+RETURNS SETOF topology.ValidateTopology_ReturnType
+AS --{
+$BODY$
+DECLARE
+  retrec topology.ValidateTopology_ReturnType;
+  rec RECORD;
+  last_node_id int;
+  last_node_first_edge RECORD;
+  last_node_prev_edge RECORD;
+BEGIN
+  RAISE DEBUG 'Checking edge linking';
+  -- NOTE: this check relies on correct start_node and end_node
+  --       for edges, if those are not correct the results
+  --       of this check do not make much sense.
+  FOR rec IN --{
+      WITH
+      nodes AS (
+        SELECT node_id
+        FROM node
+        WHERE containing_face IS NULL
+        AND (
+          bbox IS NULL
+          OR geom && bbox
+      incident_edges AS (
+        SELECT
+          n.node_id,
+          e.edge_id,
+          e.start_node,
+          e.end_node,
+          e.next_left_edge,
+          e.next_right_edge,
+          ST_RemoveRepeatedPoints(e.geom) as edge_geom
+        FROM edge_data e, nodes n
+        WHERE e.start_node = n.node_id
+        or e.end_node = n.node_id
+      edge_star AS (
+        SELECT
+          node_id,
+          edge_id,
+          next_left_edge,
+          next_right_edge,
+          ST_Azimuth(ST_StartPoint(edge_geom), ST_PointN(edge_geom, 2)) as az
+        FROM incident_edges
+        WHERE start_node = node_id
+          UNION ALL
+        SELECT
+          node_id,
+          -edge_id,
+          next_left_edge,
+          next_right_edge,
+          ST_Azimuth(ST_EndPoint(edge_geom), ST_PointN(edge_geom, ST_NumPoints(edge_geom)-1))
+        WHERE end_node = node_id
+      sequenced_edge_star AS (
+        SELECT
+          row_number() over (partition by node_id order by az, edge_id) seq,
+        FROM edge_star
+      SELECT * FROM sequenced_edge_star
+      ORDER BY node_id, seq
+  LOOP --}{
+    IF last_node_id IS NULL OR last_node_id != rec.node_id
+    THEN --{
+      IF last_node_id IS NOT NULL
+      THEN
+        -- Check that last edge (CW from prev one) is correctly linked
+        retrec := topology._CheckEdgeLinking(
+          last_node_first_edge.edge_id,
+          last_node_prev_edge.edge_id,
+          last_node_prev_edge.next_left_edge,
+          last_node_prev_edge.next_right_edge
+        IF retrec IS NOT NULL
+        THEN
+          RETURN NEXT retrec;
+        END IF;
+        --RAISE DEBUG 'Finished analisys of edge star around node %', last_node_id;
+      END IF;
+      --RAISE DEBUG 'Analyzing edge star around node %', rec.node_id;
+      last_node_id = rec.node_id;
+      last_node_first_edge = rec;
+    ELSE --}{
+      -- Check that this edge (CW from last one) is correctly linked
+        rec.edge_id,
+      THEN
+      END IF;
+    END IF; --}
+    last_node_prev_edge = rec;
+  END LOOP; --}
+  IF last_node_id IS NOT NULL THEN --{
+    --RAISE DEBUG 'Out of loop: last_node_id: %', last_node_id;
+    --RAISE DEBUG 'Out of loop: last_node_first_edge edge_id:% next_left_edge:%', last_node_first_edge.edge_id, last_node_first_edge.next_left_edge;
+    --RAISE DEBUG 'Out of loop: last_node_prev_edge edge_id:% next_left_edge:%', last_node_prev_edge.edge_id, last_node_prev_edge.next_left_edge;
+    --RAISE DEBUG 'Out of loop: last_node_first_edge: %', last_node_first_edge;
+    THEN
+    END IF;
+    --RAISE DEBUG 'Finished analisys of edge star around node % (out of loop)', last_node_id;
+  END IF; --}
+END;
+$BODY$ --}
+LANGUAGE 'plpgsql' VOLATILE;
+-- Check that the edges forming all rings
+-- (as advertised by their next_right_edge/next_left_edge)
+-- consistently advertise the same face on the walking side
+-- (CW or CCW)
+-- NOTE: if next_right_edge/next_left_edge values are incorrect
+--       the behavior of this function is undefined, use
+--       _ValidateTopologyEdgeLinking to verify that
 CREATE OR REPLACE FUNCTION topology._ValidateTopologySideLabeling(bbox geometry DEFAULT NULL)
 AS --{
@@ -243,9 +391,6 @@ DECLARE
   invalid_edges integer[];
   invalid_faces integer[];
   search_path_backup text;
-  last_node_id int;
-  last_node_first_edge RECORD;
-  last_node_prev_edge RECORD;
 BEGIN
   IF NOT EXISTS (
@@ -520,122 +665,12 @@ BEGIN
     RETURN NEXT retrec;
   END LOOP; --}
-  RAISE DEBUG 'Checking edge linking';
-  -- NOTE: this check relies on correct start_node and end_node
-  --       for edges, if those are not correct the results
-  --       of this check do not make much sense.
-  FOR rec IN --{
-      WITH
-      nodes AS (
-        SELECT node_id
-        FROM node
-        WHERE containing_face IS NULL
-        AND (
-          bbox IS NULL
-          OR geom && bbox
-      incident_edges AS (
-        SELECT
-          n.node_id,
-          e.edge_id,
-          e.start_node,
-          e.end_node,
-          e.next_left_edge,
-          e.next_right_edge,
-          ST_RemoveRepeatedPoints(e.geom) as edge_geom
-        FROM edge_data e, nodes n
-        WHERE e.start_node = n.node_id
-        or e.end_node = n.node_id
-      edge_star AS (
-        SELECT
-          node_id,
-          edge_id,
-          next_left_edge,
-          next_right_edge,
-          ST_Azimuth(ST_StartPoint(edge_geom), ST_PointN(edge_geom, 2)) as az
-        FROM incident_edges
-        WHERE start_node = node_id
-          UNION ALL
-        SELECT
-          node_id,
-          -edge_id,
-          next_left_edge,
-          next_right_edge,
-          ST_Azimuth(ST_EndPoint(edge_geom), ST_PointN(edge_geom, ST_NumPoints(edge_geom)-1))
-        WHERE end_node = node_id
-      sequenced_edge_star AS (
-        SELECT
-          row_number() over (partition by node_id order by az, edge_id) seq,
-        FROM edge_star
-      SELECT * FROM sequenced_edge_star
-      ORDER BY node_id, seq
-  LOOP --}{
-    IF last_node_id IS NULL OR last_node_id != rec.node_id
-    THEN --{
-      IF last_node_id IS NOT NULL
-      THEN
-        -- Check that last edge (CW from prev one) is correctly linked
-        retrec := topology._CheckEdgeLinking(
-          last_node_first_edge.edge_id,
-          last_node_prev_edge.edge_id,
-          last_node_prev_edge.next_left_edge,
-          last_node_prev_edge.next_right_edge
-        IF retrec IS NOT NULL
-        THEN
-          RETURN NEXT retrec;
-        END IF;
-        --RAISE DEBUG 'Finished analisys of edge star around node %', last_node_id;
-      END IF;
-      --RAISE DEBUG 'Analyzing edge star around node %', rec.node_id;
-      last_node_id = rec.node_id;
-      last_node_first_edge = rec;
-    ELSE --}{
-      -- Check that this edge (CW from last one) is correctly linked
-        rec.edge_id,
-      THEN
-      END IF;
-    END IF; --}
-    last_node_prev_edge = rec;
-  END LOOP; --}
-  IF last_node_id IS NOT NULL THEN --{
-    --RAISE DEBUG 'Out of loop: last_node_id: %', last_node_id;
-    --RAISE DEBUG 'Out of loop: last_node_first_edge edge_id:% next_left_edge:%', last_node_first_edge.edge_id, last_node_first_edge.next_left_edge;
-    --RAISE DEBUG 'Out of loop: last_node_prev_edge edge_id:% next_left_edge:%', last_node_prev_edge.edge_id, last_node_prev_edge.next_left_edge;
-    --RAISE DEBUG 'Out of loop: last_node_first_edge: %', last_node_first_edge;
-    THEN
-    END IF;
-    --RAISE DEBUG 'Finished analisys of edge star around node % (out of loop)', last_node_id;
-  END IF; --}
-  --- Edge side-labeling check -------------------------------------------{
+  --- Validate edge linking
+  RETURN QUERY SELECT * FROM topology._ValidateTopologyEdgeLinking(bbox);
+  --- Validate side-labeling
   RETURN QUERY SELECT * FROM topology._ValidateTopologySideLabeling(bbox);
-  --- Edge side-labeling check -------------------------------------------}
   -- Now create a temporary table to construct all face geometries
   -- for checking their consistency
Summary of changes:
 topology/sql/manage/ValidateTopology.sql.in | 267 ++++++++++++++++------------
 1 file changed, 151 insertions(+), 116 deletions(-)
hooks/post-receive
