[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-342-gfba9339
Wed Jul 14 15:19:35 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  fba9339b0f21aed583e6e8bbe35d648756339568 (commit)
      from  168f3f431a9349d83728e7623f9388362eb6e169 (commit)
revisions in full, below.
commit fba9339b0f21aed583e6e8bbe35d648756339568
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 15 00:17:02 2021 +0200
    Prevent healing edges if connecting node is used in mixed TopoGeometry
    Reference #3239
    NOTE: previous commit (168f3f431a9349d83728e7623f9388362eb6e169)
          closed ticket #3231 (iso nodes)
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index b5e6f5b..f51793a 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -2622,7 +2622,7 @@ cb_checkTopoGeomRemNode ( const LWT_BE_TOPOLOGY* topo,
                     "r.layer_id, l.schema_name, l.table_name, l.feature_column, "
                     "array_agg(abs(r.element_id)) as elems FROM topology.layer l "
                     " INNER JOIN \"%s\".relation r ON (l.layer_id = r.layer_id) "
-                    "WHERE l.level = 0 and l.feature_type = 1 "
+                    "WHERE l.level = 0 and l.feature_type in ( 1, 4 ) "
                     "AND l.topology_id = %d"
                     " AND r.element_id = %" LWTFMT_ELEMID
                     " group by r.topogeo_id, r.layer_id, l.schema_name, "
@@ -2657,10 +2657,11 @@ cb_checkTopoGeomRemNode ( const LWT_BE_TOPOLOGY* topo,
     cberror(topo->be_data, "TopoGeom %s in layer %s "
             "(%s.%s.%s) cannot be represented "
-            "healing edges %" LWTFMT_ELEMID
+            "removing node %" LWTFMT_ELEMID
+            " connecting edges %" LWTFMT_ELEMID
             " and %" LWTFMT_ELEMID,
             tg_id, layer_id, schema_name, table_name,
-            col_name, edge1, edge2);
+            col_name, rem_node, edge1, edge2);
     return 0;
diff --git a/topology/test/regress/st_modedgeheal.sql b/topology/test/regress/st_modedgeheal.sql
index 782737f..842426a 100644
--- a/topology/test/regress/st_modedgeheal.sql
+++ b/topology/test/regress/st_modedgeheal.sql
@@ -62,16 +62,18 @@ SELECT topology.DropTopology('city_data');
 -- Now test in presence of features
 SELECT topology.CreateTopology('t') > 1;
-CREATE TABLE t.f(id varchar);
-SELECT 'line_layer', topology.AddTopoGeometryColumn('t', 't', 'f','g', 'LINE');
-CREATE TABLE t.p(id varchar);
-SELECT 'point_layer', topology.AddTopoGeometryColumn('t', 't', 'p','g', 'POINT');
+CREATE TABLE t.f_lin(id varchar);
+SELECT 'lin_layer', topology.AddTopoGeometryColumn('t', 't', 'f_lin','g', 'LINE');
+CREATE TABLE t.f_poi(id varchar);
+SELECT 'poi_layer', topology.AddTopoGeometryColumn('t', 't', 'f_poi','g', 'POINT');
+CREATE TABLE t.f_mix(id varchar);
+SELECT 'mix_layer', topology.AddTopoGeometryColumn('t', 't', 'f_mix','g', 'COLLECTION');
 SELECT 'N'||topology.TopoGeo_AddPoint('t', 'POINT(2 8)');  -- 1
 SELECT 'E'||topology.AddEdge('t', 'LINESTRING(2 2, 2  8)');        -- 1
 SELECT 'E'||topology.AddEdge('t', 'LINESTRING(2  8,  8  8)');      -- 2
-INSERT INTO t.p VALUES ('F+N1',
+INSERT INTO t.f_poi VALUES ('F+N1',
   topology.CreateTopoGeom('t', 1, 2, '{{1,1}}'));
 -- This should be forbidden, as F+N1 above could not be
@@ -82,9 +84,30 @@ SELECT 'unexpected-success-with-orphaned-point-topogeom-1',
 SELECT 'unexpected-success-with-orphaned-point-topogeom-2',
   topology.ST_ModEdgeHeal('t', 2, 1);
-DELETE FROM t.p;
+WITH deleted AS (
+  DELETE FROM t.f_poi RETURNING g
+), clear AS (
+  SELECT ClearTopoGeom(g) FROM deleted
+) SELECT NULL FROM clear;
-INSERT INTO t.f VALUES ('F+E1',
+INSERT INTO t.f_mix VALUES ('F+N1',
+  topology.CreateTopoGeom('t', 4, 3, '{{1,1}}'));
+-- This should be forbidden, as F+N1 above could not be
+-- defined w/out the joining node
+-- See https://trac.osgeo.org/postgis/ticket/3239
+SELECT 'unexpected-success-with-orphaned-mix-topogeom-1',
+  topology.ST_ModEdgeHeal('t', 1, 2);
+SELECT 'unexpected-success-with-orphaned-mix-topogeom-2',
+  topology.ST_ModEdgeHeal('t', 2, 1);
+WITH deleted AS (
+  DELETE FROM t.f_mix RETURNING g
+), clear AS (
+INSERT INTO t.f_lin VALUES ('F+E1',
   topology.CreateTopoGeom('t', 2, 1, '{{1,2}}'));
 -- This should be forbidden, as F+E1 above could not be
@@ -101,13 +124,13 @@ SELECT topology.ST_ModEdgeHeal('t', 100, 2);
 SELECT 'E'||topology.AddEdge('t', 'LINESTRING(0 0, 5 0)');         -- 3
 SELECT 'E'||topology.AddEdge('t', 'LINESTRING(10 0, 5 0)');        -- 4
-INSERT INTO t.f VALUES ('F+E3-E4',
+INSERT INTO t.f_lin VALUES ('F+E3-E4',
   topology.CreateTopoGeom('t', 2, 1, '{{3,2},{-4,2}}'));
-INSERT INTO t.f VALUES ('F-E3+E4',
+INSERT INTO t.f_lin VALUES ('F-E3+E4',
   topology.CreateTopoGeom('t', 2, 1, '{{-3,2},{4,2}}'));
 SELECT r.topogeo_id, r.element_id
-  FROM t.relation r, t.f f WHERE
+  FROM t.relation r, t.f_lin f WHERE
   r.layer_id = layer_id(f.g) AND r.topogeo_id = id(f.g)
   AND r.topogeo_id in (2,3)
   ORDER BY r.layer_id, r.topogeo_id, r.element_id;
@@ -120,7 +143,7 @@ SELECT 'MH(3,4)', topology.ST_ModEdgeHeal('t', 3, 4);
 SELECT topology.ST_ModEdgeHeal('t', 1, 3);
diff --git a/topology/test/regress/st_modedgeheal_expected b/topology/test/regress/st_modedgeheal_expected
index cab772a..1dfcb7b 100644
--- a/topology/test/regress/st_modedgeheal_expected
+++ b/topology/test/regress/st_modedgeheal_expected
@@ -96,15 +96,18 @@ N21
 N22
 Topology 'city_data' dropped
 t
-line_layer|1
-point_layer|2
+lin_layer|1
+poi_layer|2
+mix_layer|3
 N1
 E1
 E2
-ERROR:  TopoGeom 1 in layer 2 (t.p.g) cannot be represented healing edges 1 and 2
-ERROR:  TopoGeom 1 in layer 2 (t.p.g) cannot be represented healing edges 2 and 1
-ERROR:  TopoGeom 1 in layer 1 (t.f.g) cannot be represented healing edges 1 and 2
-ERROR:  TopoGeom 1 in layer 1 (t.f.g) cannot be represented healing edges 2 and 1
+ERROR:  TopoGeom 1 in layer 2 (t.f_poi.g) cannot be represented removing node 1 connecting edges 1 and 2
+ERROR:  TopoGeom 1 in layer 2 (t.f_poi.g) cannot be represented removing node 1 connecting edges 2 and 1
+ERROR:  TopoGeom 1 in layer 3 (t.f_mix.g) cannot be represented removing node 1 connecting edges 1 and 2
+ERROR:  TopoGeom 1 in layer 3 (t.f_mix.g) cannot be represented removing node 1 connecting edges 2 and 1
+ERROR:  TopoGeom 1 in layer 1 (t.f_lin.g) cannot be represented healing edges 1 and 2
+ERROR:  TopoGeom 1 in layer 1 (t.f_lin.g) cannot be represented healing edges 2 and 1
 ERROR:  SQL/MM Spatial exception - non-existent edge 200
 ERROR:  SQL/MM Spatial exception - non-existent edge 100
 E3
diff --git a/topology/test/regress/st_newedgeheal.sql b/topology/test/regress/st_newedgeheal.sql
index de4c218..6d4545d 100644
--- a/topology/test/regress/st_newedgeheal.sql
+++ b/topology/test/regress/st_newedgeheal.sql
@@ -62,29 +62,52 @@ SELECT topology.DropTopology('city_data');
-  topology.ST_ModEdgeHeal('t', 1, 2);
+  topology.ST_NewEdgeHeal('t', 1, 2);
-  topology.ST_ModEdgeHeal('t', 2, 1);
+  topology.ST_NewEdgeHeal('t', 2, 1);
-DELETE FROM t.p;
+WITH deleted AS (
+), clear AS (
+WITH deleted AS (
+), clear AS (
@@ -101,13 +124,13 @@ SELECT topology.ST_NewEdgeHeal('t', 100, 2);
@@ -120,7 +143,7 @@ SELECT 'MH(3,4)', topology.ST_NewEdgeHeal('t', 3, 4);
 SELECT topology.ST_NewEdgeHeal('t', 1, 5);
diff --git a/topology/test/regress/st_newedgeheal_expected b/topology/test/regress/st_newedgeheal_expected
index a41313a..eb698a6 100644
--- a/topology/test/regress/st_newedgeheal_expected
+++ b/topology/test/regress/st_newedgeheal_expected
 N22
 t
-line_layer|1
-point_layer|2
+lin_layer|1
+poi_layer|2
+mix_layer|3
 N1
 E1
 E2
 E3
Summary of changes:
 topology/postgis_topology.c                   |  7 ++--
 topology/test/regress/st_modedgeheal.sql      | 45 ++++++++++++++++++------
 topology/test/regress/st_modedgeheal_expected | 15 ++++----
 topology/test/regress/st_newedgeheal.sql      | 49 ++++++++++++++++++++-------
 topology/test/regress/st_newedgeheal_expected | 15 ++++----
 5 files changed, 92 insertions(+), 39 deletions(-)
hooks/post-receive
