[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-343-g76cf8de
Wed Jul 14 15:38:59 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  76cf8de9bc301b9a28809ce8dd5ca4e92fcab559 (commit)
      from  fba9339b0f21aed583e6e8bbe35d648756339568 (commit)
revisions in full, below.
commit 76cf8de9bc301b9a28809ce8dd5ca4e92fcab559
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 15 00:36:09 2021 +0200
    Also check TopoGeometries in collection layers for preventing edge heal and node removal
    Includes test
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index f51793a..c02ab6a 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -2572,9 +2572,9 @@ cb_checkTopoGeomRemNode ( const LWT_BE_TOPOLOGY* topo,
                     "r.layer_id, l.schema_name, l.table_name, l.feature_column, "
                     "array_agg(abs(r.element_id)) as elems FROM topology.layer l "
                     " INNER JOIN \"%s\".relation r ON (l.layer_id = r.layer_id) "
-                    "WHERE l.level = 0 and l.feature_type = 2 "
+                    "WHERE l.level = 0 and l.feature_type in ( 2, 4 ) "
                     "AND l.topology_id = %d"
-                    " AND abs(r.element_id) = ANY (ARRAY[%" LWTFMT_ELEMID ",%" LWTFMT_ELEMID
+                    " AND r.element_type = 2 AND abs(r.element_id) = ANY (ARRAY[%" LWTFMT_ELEMID ",%" LWTFMT_ELEMID
                     "]::int4[]) group by r.topogeo_id, r.layer_id, l.schema_name, "
                     "l.table_name, l.feature_column ) t WHERE NOT t.elems @> ARRAY[%"
                     LWTFMT_ELEMID ",%" LWTFMT_ELEMID "]::int4[] LIMIT 1",
@@ -2624,7 +2624,7 @@ cb_checkTopoGeomRemNode ( const LWT_BE_TOPOLOGY* topo,
                     "WHERE l.level = 0 and l.feature_type in ( 1, 4 ) "
-                    " AND r.element_id = %" LWTFMT_ELEMID
+                    " AND r.element_type = 1 AND r.element_id = %" LWTFMT_ELEMID
                     " group by r.topogeo_id, r.layer_id, l.schema_name, "
                     "l.table_name, l.feature_column ) t LIMIT 1",
                     topo->name, topo->id,
@@ -2691,7 +2691,7 @@ cb_checkTopoGeomRemIsoNode ( const LWT_BE_TOPOLOGY* topo, LWT_ELEMID rem_node )
diff --git a/topology/test/regress/st_modedgeheal.sql b/topology/test/regress/st_modedgeheal.sql
index 842426a..d827951 100644
--- a/topology/test/regress/st_modedgeheal.sql
+++ b/topology/test/regress/st_modedgeheal.sql
@@ -73,47 +73,49 @@ SELECT 'N'||topology.TopoGeo_AddPoint('t', 'POINT(2 8)');  -- 1
 SELECT 'E'||topology.AddEdge('t', 'LINESTRING(2 2, 2  8)');        -- 1
 SELECT 'E'||topology.AddEdge('t', 'LINESTRING(2  8,  8  8)');      -- 2
+-- Cannot heal edges connected by node used in point TopoGeometry
+-- See https://trac.osgeo.org/postgis/ticket/3239
 INSERT INTO t.f_poi VALUES ('F+N1',
   topology.CreateTopoGeom('t', 1, 2, '{{1,1}}'));
--- This should be forbidden, as F+N1 above could not be
--- defined w/out the joining node
--- See https://trac.osgeo.org/postgis/ticket/3239
 SELECT 'unexpected-success-with-orphaned-point-topogeom-1',
   topology.ST_ModEdgeHeal('t', 1, 2);
 SELECT 'unexpected-success-with-orphaned-point-topogeom-2',
   topology.ST_ModEdgeHeal('t', 2, 1);
+WITH deleted AS ( DELETE FROM t.f_poi RETURNING g),
+     clear AS ( SELECT ClearTopoGeom(g) FROM deleted)
+     SELECT NULL FROM clear;
-WITH deleted AS (
-  DELETE FROM t.f_poi RETURNING g
-), clear AS (
-  SELECT ClearTopoGeom(g) FROM deleted
-) SELECT NULL FROM clear;
+-- Cannot heal edges connected by node used in collection TopoGeometry
 INSERT INTO t.f_mix VALUES ('F+N1',
   topology.CreateTopoGeom('t', 4, 3, '{{1,1}}'));
 SELECT 'unexpected-success-with-orphaned-mix-topogeom-1',
 SELECT 'unexpected-success-with-orphaned-mix-topogeom-2',
+WITH deleted AS ( DELETE FROM t.f_mix RETURNING g),
-WITH deleted AS (
-  DELETE FROM t.f_mix RETURNING g
-), clear AS (
+---- Cannot heal edges when only one is used in line TopoGeometry
+---- defined w/out one of the edges
 INSERT INTO t.f_lin VALUES ('F+E1',
   topology.CreateTopoGeom('t', 2, 1, '{{1,2}}'));
+SELECT topology.ST_ModEdgeHeal('t', 1, 2);
+SELECT topology.ST_ModEdgeHeal('t', 2, 1);
+WITH deleted AS ( DELETE FROM t.f_lin RETURNING g),
--- This should be forbidden, as F+E1 above could not be
+-- Cannot heal edges when only one is used in collection TopoGeometry
+INSERT INTO t.f_mix VALUES ('F+E1',
+  topology.CreateTopoGeom('t', 4, 3, '{{1,2}}'));
 -- This is for ticket #941
 SELECT topology.ST_ModEdgeHeal('t', 1, 200);
diff --git a/topology/test/regress/st_newedgeheal.sql b/topology/test/regress/st_newedgeheal.sql
index 6d4545d..e162b78 100644
--- a/topology/test/regress/st_newedgeheal.sql
+++ b/topology/test/regress/st_newedgeheal.sql
@@ -73,47 +73,50 @@ SELECT 'N'||topology.TopoGeo_AddPoint('t', 'POINT(2 8)');  -- 1
-INSERT INTO t.f_poi VALUES ('F+N1',
-  topology.CreateTopoGeom('t', 1, 2, '{{1,1}}'));
+INSERT INTO t.f_poi VALUES ('F+N1',
+  topology.CreateTopoGeom('t', 1, 2, '{{1,1}}'));
   topology.ST_NewEdgeHeal('t', 1, 2);
   topology.ST_NewEdgeHeal('t', 2, 1);
-WITH deleted AS (
-), clear AS (
-WITH deleted AS (
-), clear AS (
+-- Cannot heal edges when only one is used in line TopoGeometry
+-- defined w/out one of the edges
 SELECT topology.ST_NewEdgeHeal('t', 1, 2);
 SELECT topology.ST_NewEdgeHeal('t', 2, 1);
+---- Cannot heal edges when only one is used in collection TopoGeometry
+SELECT topology.ST_NewEdgeHeal('t', 1, 2);
+SELECT topology.ST_NewEdgeHeal('t', 2, 1);
 SELECT topology.ST_NewEdgeHeal('t', 1, 200);
diff --git a/topology/test/regress/st_newedgeheal_expected b/topology/test/regress/st_newedgeheal_expected
index eb698a6..973f00f 100644
--- a/topology/test/regress/st_newedgeheal_expected
+++ b/topology/test/regress/st_newedgeheal_expected
@@ -108,6 +108,8 @@ ERROR:  TopoGeom 1 in layer 3 (t.f_mix.g) cannot be represented removing node 1
 ERROR:  TopoGeom 1 in layer 3 (t.f_mix.g) cannot be represented removing node 1 connecting edges 2 and 1
 ERROR:  TopoGeom 1 in layer 1 (t.f_lin.g) cannot be represented healing edges 1 and 2
 ERROR:  TopoGeom 1 in layer 1 (t.f_lin.g) cannot be represented healing edges 2 and 1
+ERROR:  TopoGeom 2 in layer 3 (t.f_mix.g) cannot be represented healing edges 1 and 2
+ERROR:  TopoGeom 2 in layer 3 (t.f_mix.g) cannot be represented healing edges 2 and 1
 ERROR:  SQL/MM Spatial exception - non-existent edge 200
 ERROR:  SQL/MM Spatial exception - non-existent edge 100
 E3
Summary of changes:
 topology/postgis_topology.c                   |  8 ++---
 topology/test/regress/st_modedgeheal.sql      | 44 ++++++++++++------------
 topology/test/regress/st_newedgeheal.sql      | 49 ++++++++++++++-------------
 topology/test/regress/st_newedgeheal_expected |  2 ++
 4 files changed, 55 insertions(+), 48 deletions(-)
hooks/post-receive
