[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-344-ged2de5c
Wed Jul 14 15:57:52 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  ed2de5c0a99c08e72f3736a42d378383a4a24410 (commit)
      from  76cf8de9bc301b9a28809ce8dd5ca4e92fcab559 (commit)
revisions in full, below.
commit ed2de5c0a99c08e72f3736a42d378383a4a24410
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 15 00:57:14 2021 +0200
    Prevent removing isolated edge used in TopoGeometry objects
    Closes #3248 in main branch (3.2.0dev)
    Includes regression tests
diff --git a/liblwgeom/liblwgeom_topo.h b/liblwgeom/liblwgeom_topo.h
index cb56f12..665e9c5 100644
--- a/liblwgeom/liblwgeom_topo.h
+++ b/liblwgeom/liblwgeom_topo.h
@@ -832,6 +832,20 @@ typedef struct LWT_BE_CALLBACKS_T {
       LWT_ELEMID rem_node
+   * Check TopoGeometry objects before an isolated edge removal event
+   * @param topo the topology to act upon
+   * @param rem_edge identifier of the edge that's been removed
+   * @return 1 to allow, 0 to forbid the operation
+   *         (reporting reason via lastErrorMessage)
+  int (*checkTopoGeomRemIsoEdge) (
+      const LWT_BE_TOPOLOGY* topo,
+      LWT_ELEMID rem_edge
 } LWT_BE_CALLBACKS;
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 60df671..51c4639 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -347,6 +347,12 @@ lwt_be_checkTopoGeomRemEdge(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id,
 static int
+lwt_be_checkTopoGeomRemIsoEdge(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id)
+  CBT1(topo, checkTopoGeomRemIsoEdge, edge_id);
+static int
 lwt_be_checkTopoGeomRemNode(LWT_TOPOLOGY* topo, LWT_ELEMID node_id,
                             LWT_ELEMID eid1, LWT_ELEMID eid2)
@@ -3767,9 +3773,14 @@ lwt_RemIsoEdge(LWT_TOPOLOGY* topo, LWT_ELEMID id)
     return -1;
-  /* TODO: notify to caller about edge being removed ?
+  /* Check that the edge can be safely removed
    * See https://trac.osgeo.org/postgis/ticket/3248
+  if ( ! lwt_be_checkTopoGeomRemIsoEdge(topo, id) )
+    lwerror("%s", lwt_be_lastErrorMessage(topo->be_iface));
+    return -1;
   return 0; /* success */
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index c02ab6a..aae7e48 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -2552,6 +2552,66 @@ cb_checkTopoGeomRemEdge ( const LWT_BE_TOPOLOGY* topo,
 static int
+cb_checkTopoGeomRemIsoEdge ( const LWT_BE_TOPOLOGY* topo,
+                          LWT_ELEMID rem_edge )
+  MemoryContext oldcontext = CurrentMemoryContext;
+  int spi_result;
+  StringInfoData sqldata;
+  StringInfo sql = &sqldata;
+  const char *tg_id, *layer_id;
+  const char *schema_name, *table_name, *col_name;
+  HeapTuple row;
+  TupleDesc tdesc;
+  POSTGIS_DEBUG(1, "cb_checkTopoGeomRemIsoEdge enter ");
+  initStringInfo(sql);
+  appendStringInfo( sql, "SELECT r.topogeo_id, r.layer_id, "
+                    "l.schema_name, l.table_name, l.feature_column FROM "
+                    "topology.layer l INNER JOIN \"%s\".relation r "
+                    "ON (l.layer_id = r.layer_id) WHERE l.level = 0 AND "
+                    "l.feature_type IN ( 2, 4 ) AND l.topology_id = %d"
+                    " AND r.element_type = 2 AND abs(r.element_id) = %" LWTFMT_ELEMID,
+                    topo->name, topo->id, rem_edge );
+  POSTGIS_DEBUGF(1, "cb_checkTopoGeomRemIsoEdge query 1: %s", sql->data);
+  spi_result = SPI_execute(sql->data, !topo->be_data->data_changed, 0);
+  MemoryContextSwitchTo( oldcontext ); /* switch back */
+  if ( spi_result != SPI_OK_SELECT )
+    cberror(topo->be_data, "unexpected return (%d) from query execution: %s",
+            spi_result, sql->data);
+    pfree(sqldata.data);
+    return 0;
+  if ( SPI_processed )
+    row = SPI_tuptable->vals[0];
+    tdesc = SPI_tuptable->tupdesc;
+    tg_id = SPI_getvalue(row, tdesc, 1);
+    layer_id = SPI_getvalue(row, tdesc, 2);
+    schema_name = SPI_getvalue(row, tdesc, 3);
+    table_name = SPI_getvalue(row, tdesc, 4);
+    col_name = SPI_getvalue(row, tdesc, 5);
+    SPI_freetuptable(SPI_tuptable);
+    cberror(topo->be_data, "TopoGeom %s in layer %s "
+            "(%s.%s.%s) cannot be represented "
+            "dropping edge %" LWTFMT_ELEMID,
+            tg_id, layer_id, schema_name, table_name,
+            col_name, rem_edge);
+    return 0;
+  return 1;
+static int
 cb_checkTopoGeomRemNode ( const LWT_BE_TOPOLOGY* topo,
                           LWT_ELEMID rem_node, LWT_ELEMID edge1, LWT_ELEMID edge2 )
@@ -3336,7 +3396,8 @@ static LWT_BE_CALLBACKS be_callbacks =
   cb_checkTopoGeomRemNode,
   cb_updateTopoGeomEdgeHeal,
   cb_getFaceWithinBox2D,
-  cb_checkTopoGeomRemIsoNode
+  cb_checkTopoGeomRemIsoNode,
+  cb_checkTopoGeomRemIsoEdge
 static void
diff --git a/topology/test/regress/st_removeisoedge.sql b/topology/test/regress/st_removeisoedge.sql
new file mode 100644
index 0000000..38a2db0
--- /dev/null
+++ b/topology/test/regress/st_removeisoedge.sql
@@ -0,0 +1,40 @@
+\set VERBOSITY terse
+set client_min_messages to ERROR;
+-- Import city_data
+\i ../load_topology.sql
+CREATE TABLE city_data.f_lin(id serial primary key);
+SELECT NULL FROM AddTopoGeometryColumn('city_data', 'city_data', 'f_lin', 'tg', 'LINE');
+CREATE TABLE city_data.f_mix(id serial primary key);
+SELECT NULL FROM AddTopoGeometryColumn('city_data', 'city_data', 'f_mix', 'tg', 'COLLECTION');
+BEGIN;
+INSERT INTO city_data.f_lin(tg) VALUES(
+  topology.CreateTopoGeom(
+    'city_data', -- Topology name
+    2, -- Topology geometry type (line)
+    1, -- TG_LAYER_ID for this topology (from topology.layer)
+    '{{25,2}}'
+SELECT '#3248.line', topology.ST_RemoveIsoEdge('city_data', 25);
+ROLLBACK;
+BEGIN;
+INSERT INTO city_data.f_mix(tg) VALUES(
+    4, -- Topology geometry type (collection)
+    2, -- TG_LAYER_ID for this topology (from topology.layer)
+    '{{25,2}}'
+SELECT '#3248.collection', topology.ST_RemoveIsoEdge('city_data', 25);
+ROLLBACK;
+SELECT 'non-iso', topology.ST_RemoveIsoEdge('city_data', 1);
+SELECT 'iso', topology.ST_RemoveIsoEdge('city_data', 25);
+SELECT NULL FROM topology.DropTopology('city_data');
diff --git a/topology/test/regress/st_removeisoedge_expected b/topology/test/regress/st_removeisoedge_expected
index 0000000..ad2cd1d
--- /dev/null
+++ b/topology/test/regress/st_removeisoedge_expected
@@ -0,0 +1,4 @@
+ERROR:  TopoGeom 1 in layer 1 (city_data.f_lin.tg) cannot be represented dropping edge 25
+ERROR:  TopoGeom 1 in layer 2 (city_data.f_mix.tg) cannot be represented dropping edge 25
+ERROR:  SQL/MM Spatial exception - not isolated edge
+iso|Isolated edge 25 removed
Summary of changes:
 liblwgeom/liblwgeom_topo.h                      | 14 ++++++
 liblwgeom/lwgeom_topo.c                         | 13 ++++-
 topology/postgis_topology.c                     | 63 ++++++++++++++++++++++++-
 topology/test/regress/st_removeisoedge.sql      | 40 ++++++++++++++++
 topology/test/regress/st_removeisoedge_expected |  4 ++
 5 files changed, 132 insertions(+), 2 deletions(-)
 create mode 100644 topology/test/regress/st_removeisoedge.sql
 create mode 100644 topology/test/regress/st_removeisoedge_expected
hooks/post-receive
