[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-374-gf885c33
Thu Jul 29 15:00:11 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  f885c33548a5f58f2e1568765f87a93f6dc36333 (commit)
      from  eb6248024ccbd9aac73e97a52352347f72e6ba64 (commit)
revisions in full, below.
commit f885c33548a5f58f2e1568765f87a93f6dc36333
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jul 29 14:58:55 2021 -0700
    Return NULL for ST_GeometryN(empty) for all empty inputs.
    This harmonizes with the behaviour of ST_GeometryN when N is
    out-of-range for non-empty geometry (returns NULL). It also
    matches up with ST_InteriorRingN(empty), which returns NULL.
    Also updated relevant wiki page with this behaviour.
    https://trac.osgeo.org/postgis/wiki/DevWikiEmptyGeometry
diff --git a/postgis/lwgeom_ogc.c b/postgis/lwgeom_ogc.c
index 9d2f994..e1745e2 100644
--- a/postgis/lwgeom_ogc.c
+++ b/postgis/lwgeom_ogc.c
@@ -241,11 +241,11 @@ Datum LWGEOM_numgeometries_collection(PG_FUNCTION_ARGS)
 	int32 ret = 1;
 	lwgeom = lwgeom_from_gserialized(geom);
-	if ( lwgeom_is_empty(lwgeom) )
+	if (lwgeom_is_empty(lwgeom))
 		ret = 0;
-	else if ( lwgeom_is_collection(lwgeom) )
+	else if (lwgeom_is_collection(lwgeom))
 		LWCOLLECTION *col = lwgeom_as_lwcollection(lwgeom);
 		ret = col->ngeoms;
@@ -273,10 +273,15 @@ Datum LWGEOM_geometryn_collection(PG_FUNCTION_ARGS)
 	idx = PG_GETARG_INT32(1);
 	idx -= 1; /* index is 1-based */
+	if (gserialized_is_empty(geom))
+		PG_RETURN_NULL();
 	/* call is valid on multi* geoms only */
-	if (type==POINTTYPE || type==LINETYPE || type==CIRCSTRINGTYPE ||
-	        type==COMPOUNDTYPE || type==POLYGONTYPE ||
-		type==CURVEPOLYTYPE || type==TRIANGLETYPE)
+	if (type==POINTTYPE     || type==LINETYPE    || type==CIRCSTRINGTYPE ||
+	    type==COMPOUNDTYPE  || type==POLYGONTYPE ||
+	    type==CURVEPOLYTYPE || type==TRIANGLETYPE)
 		if ( idx == 0 ) PG_RETURN_POINTER(geom);
 		PG_RETURN_NULL();
diff --git a/regress/core/empty.sql b/regress/core/empty.sql
index 6dfe078..d07ce25 100644
--- a/regress/core/empty.sql
+++ b/regress/core/empty.sql
@@ -111,6 +111,10 @@ WITH inp AS (SELECT
 WITH inp AS (SELECT
  'POLYGON EMPTY'::geometry as empty
  ) SELECT 'ST_NumGeometries(empty) == 0', ST_NumGeometries(empty) FROM inp;
+-- https://trac.osgeo.org/postgis/ticket/4736
+WITH inp AS (SELECT
+ 'GEOMETRYCOLLECTION(POLYGON EMPTY)'::geometry as empty
+ ) SELECT 'ST_NumGeometries(emptycollection) == 0', ST_NumGeometries(empty) FROM inp;
 WITH inp AS (SELECT
  ) SELECT 'ST_NRings(empty) == 0', ST_NRings(empty) FROM inp;
@@ -123,7 +127,12 @@ WITH inp AS (SELECT
 WITH inp AS (SELECT
  'POLYGON EMPTY'::geometry as empty,
  1 as n
- ) SELECT 'ST_GeometryN(empty, n) == empty', encode(ST_AsEWKB(ST_GeometryN(empty, n),'ndr'),'hex') FROM inp;
+ ) SELECT 'ST_GeometryN(empty, n) == NULL', encode(ST_AsEWKB(ST_GeometryN(empty, n),'ndr'),'hex') FROM inp;
+ 'GEOMETRYCOLLECTION(POLYGON EMPTY)'::geometry as empty,
+ 1 as n
+ ) SELECT 'ST_GeometryN(emptycollection, n) == NULL', encode(ST_AsEWKB(ST_GeometryN(empty, n),'ndr'),'hex') FROM inp;
 WITH inp AS (SELECT
  ) SELECT 'ST_ExteriorRing(empty) == empty', encode(ST_AsEWKB(ST_ExteriorRing(empty),'ndr'),'hex') FROM inp;
@@ -138,6 +147,8 @@ WITH inp AS (SELECT
  'LINESTRING EMPTY'::geometry as empty
  ) SELECT 'ST_Length(empty) == 0', ST_Length(empty) FROM inp;
 -- Operators
 -- same box, see http://trac.osgeo.org/postgis/ticket/1453
diff --git a/regress/core/empty_expected b/regress/core/empty_expected
index 53f4e8b..2eb4511 100644
--- a/regress/core/empty_expected
+++ b/regress/core/empty_expected
@@ -44,10 +44,12 @@ ST_Equals(empty1, empty2) == TRUE|t
 ST_IsSimple(empty) == TRUE|t
 ST_IsValid(empty) == TRUE|t
 ST_NumGeometries(empty) == 0|0
+ST_NumGeometries(emptycollection) == 0|0
 ST_NRings(empty) == 0|0
 ST_NumPoints(empty) == 0|0
 ST_NPoints(empty) == 0|0
-ST_GeometryN(empty, n) == empty|010300000000000000
+ST_GeometryN(empty, n) == NULL|
+ST_GeometryN(emptycollection, n) == NULL|
 ST_ExteriorRing(empty) == empty|010200000000000000
 ST_InteriorRingN(empty, n) == NULL|
 ST_Area(empty) == 0|0
Summary of changes:
 postgis/lwgeom_ogc.c        | 15 ++++++++++-----
 regress/core/empty.sql      | 13 ++++++++++++-
 regress/core/empty_expected |  4 +++-
 3 files changed, 25 insertions(+), 7 deletions(-)
hooks/post-receive
