[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-376-gd1d0d18
Thu Jul 29 15:07:11 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  d1d0d181bf07980893fd4873f748de35a9d138a3 (commit)
       via  937f2600d782c900fbca123a18d7995eeab2396a (commit)
      from  f885c33548a5f58f2e1568765f87a93f6dc36333 (commit)
revisions in full, below.
commit d1d0d181bf07980893fd4873f748de35a9d138a3
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Jul 29 18:07:01 2021 -0400
    CREATE TABLE IF NOT EXISTS is now supported on all we support
diff --git a/extras/tiger_geocoder/upgrade_geocode.sql b/extras/tiger_geocoder/upgrade_geocode.sql
index 95e11bd..6a32af6 100644
--- a/extras/tiger_geocoder/upgrade_geocode.sql
+++ b/extras/tiger_geocoder/upgrade_geocode.sql
@@ -52,9 +52,9 @@ DROP FUNCTION IF EXISTS geocode_address(norm_addy,integer); /** changed to inclu
 DROP FUNCTION IF EXISTS interpolate_from_address(integer, character varying, character varying, geometry); /** changed to use default args and added offset and side **/
 DROP FUNCTION IF EXISTS interpolate_from_address(integer, integer, integer, geometry); /**don't need this since got collapes into varchar version **/
--- this will fail if already exists, that is fine.  can't use IF NOT EXISTS until 9.1
+-- this will fail if already exists, that is fine.
 SELECT tiger.SetSearchPathForInstall('tiger');
-CREATE TABLE addrfeat
+CREATE TABLE IF NOT EXISTS addrfeat
   gid serial not null primary key,
   tlid bigint,
@@ -305,4 +305,4 @@ SELECT install_missing_indexes();
 --\i generate_drop_dupe_featnames.sql
 \o
 --\i drop_dup_feat_create_index.sql
-\echo 'Missing index Install completed'
\ No newline at end of file
+\echo 'Missing index Install completed'
commit 937f2600d782c900fbca123a18d7995eeab2396a
Date:   Thu Jul 29 18:04:38 2021 -0400
    Fixes for faces. References #4956
diff --git a/extras/tiger_geocoder/tiger_loader_2020.sql b/extras/tiger_geocoder/tiger_loader_2020.sql
index edfe17d..ee290db 100644
--- a/extras/tiger_geocoder/tiger_loader_2020.sql
+++ b/extras/tiger_geocoder/tiger_loader_2020.sql
@@ -91,27 +91,6 @@ IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_sche
 	COMMENT ON TABLE tiger.bg IS 'block groups';
 END IF;
-CREATE TABLE IF NOT EXISTS tiger.tabblock20
-    statefp character varying(2) ,
-    countyfp character varying(3) ,
-    tractce character varying(6) ,
-    blockce character varying(4) ,
-    geoid character varying(15) ,
-    name character varying(10) ,
-    mtfcc character varying(5) ,
-    ur character varying(1) ,
-    uace character varying(5) ,
-    uatype character varying(1) ,
-    funcstat character varying(1) ,
-    aland double precision,
-    awater double precision,
-    intptlat character varying(11) ,
-    intptlon character varying(12) ,
-    the_geom geometry(MultiPolygon,4269),
-    CONSTRAINT pk_tabblock20 PRIMARY KEY (geoid)
 IF EXISTS(SELECT * FROM information_schema.columns WHERE table_schema = 'tiger' AND column_name = 'tabblock_id' AND table_name = 'tabblock' AND character_maximum_length < 16)  THEN -- size of name and tabblock_id fields need to be increased
     ALTER TABLE tiger.tabblock ALTER COLUMN name TYPE varchar(20);
     ALTER TABLE tiger.tabblock ALTER COLUMN tabblock_id TYPE varchar(16);
@@ -137,6 +116,27 @@ $$
   LANGUAGE 'plpgsql' IMMUTABLE
   COST 100;
+CREATE TABLE IF NOT EXISTS tiger.tabblock20
+    statefp character varying(2) ,
+    countyfp character varying(3) ,
+    tractce character varying(6) ,
+    blockce character varying(4) ,
+    geoid character varying(15) ,
+    name character varying(10) ,
+    mtfcc character varying(5) ,
+    ur character varying(1) ,
+    uace character varying(5) ,
+    uatype character varying(1) ,
+    funcstat character varying(1) ,
+    aland double precision,
+    awater double precision,
+    intptlat character varying(11) ,
+    intptlon character varying(12) ,
+    the_geom geometry(MultiPolygon,4269),
+    CONSTRAINT pk_tabblock20 PRIMARY KEY (geoid)
 -- Helper function that generates script to drop all tables in a particular schema for a particular table
 -- This is useful in case you need to reload a state
 CREATE OR REPLACE FUNCTION drop_state_tables_generate_script(param_state text, param_schema text DEFAULT 'tiger_data')
@@ -342,22 +342,22 @@ ${psql} -c "CREATE INDEX ${data_schema}_${state_abbrev}_${lookup_name}_the_geom_
 ${psql} -c "CREATE INDEX idx_${data_schema}_${state_abbrev}_${lookup_name}_countyfp ON ${data_schema}.${state_abbrev}_${lookup_name} USING btree(countyfp);"');
 INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, level_nation, single_geom_mode, insert_mode, pre_load_process, post_load_process, columns_exclude )
-VALUES(13, 'zcta5_raw', 'zcta510', false,false, false,true, false, 'c',
+VALUES(13, 'zcta5_raw', 'zcta520', false,false, false,true, false, 'c',
 	'${psql} -c "CREATE TABLE ${data_schema}.${lookup_name}( zcta5 character varying(5), classfp character varying(2),mtfcc character varying(5), funcstat character varying(1), aland double precision, awater double precision, intptlat character varying(11), intptlon character varying(12), the_geom geometry(MultiPolygon,4269) );"',
 $post_load$${psql} -c "ALTER TABLE tiger.zcta5 DROP CONSTRAINT IF EXISTS enforce_geotype_the_geom; CREATE TABLE ${data_schema}.zcta5_all(CONSTRAINT pk_zcta5_all PRIMARY KEY (zcta5ce,statefp), CONSTRAINT uidx_${lookup_name}_all_gid UNIQUE (gid)) INHERITS(tiger.zcta5);"
 ${psql} -c "SELECT loader_load_staged_data(lower('${table_name}'), lower('${lookup_name}'));"
 ${psql} -c "INSERT INTO ${data_schema}.zcta5_all(statefp, zcta5ce, classfp, mtfcc, funcstat, aland, awater, intptlat, intptlon, partflg, the_geom) SELECT  s.statefp, z.zcta5,  z.classfp, z.mtfcc, z.funcstat, z.aland, z.awater, z.intptlat, z.intptlon, CASE WHEN ST_Covers(s.the_geom, z.the_geom) THEN 'N' ELSE 'Y' END, ST_SnapToGrid(ST_Transform(CASE WHEN ST_Covers(s.the_geom, z.the_geom) THEN ST_SimplifyPreserveTopology(ST_Transform(z.the_geom,2163),1000) ELSE ST_SimplifyPreserveTopology(ST_Intersection(ST_Transform(s.the_geom,2163), ST_Transform(z.the_geom,2163)),1000)  END,4269), 0.000001) As geom FROM ${data_schema}.zcta5_raw AS z INNER JOIN tiger.state AS s ON (ST_Covers(s.the_geom, z.the_geom) or ST_Overlaps(s.the_geom, z.the_geom) );"
 	${psql} -c "DROP TABLE ${data_schema}.zcta5_raw; CREATE INDEX idx_${data_schema}_zcta5_all_the_geom_gist ON ${data_schema}.zcta5_all USING gist(the_geom);"$post_load$
-, ARRAY['gid','geoid','geoid10', 'partflg']);
+, ARRAY['gid','geoid','geoid10', 'geoid20', 'partflg']);
-INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, single_geom_mode, insert_mode, pre_load_process, post_load_process )
+INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, single_geom_mode, insert_mode, pre_load_process, post_load_process, columns_exclude )
 VALUES(6, 'faces', 'faces', true, true, false,false, 'c',
 	'${psql} -c "CREATE TABLE ${data_schema}.${state_abbrev}_${table_name}(CONSTRAINT pk_${state_abbrev}_${lookup_name} PRIMARY KEY (gid)) INHERITS(tiger.${lookup_name});" ',
 	'${psql} -c "CREATE INDEX ${data_schema}_${state_abbrev}_${table_name}_the_geom_gist ON ${data_schema}.${state_abbrev}_${lookup_name} USING gist(the_geom);"
 	${psql} -c "CREATE INDEX idx_${data_schema}_${state_abbrev}_${lookup_name}_tfid ON ${data_schema}.${state_abbrev}_${lookup_name} USING btree (tfid);"
 	${psql} -c "CREATE INDEX idx_${data_schema}_${state_abbrev}_${table_name}_countyfp ON ${data_schema}.${state_abbrev}_${table_name} USING btree (countyfp);"
 	${psql} -c "ALTER TABLE ${data_schema}.${state_abbrev}_${lookup_name} ADD CONSTRAINT chk_statefp CHECK (statefp = ''${state_fips}'');"
-	${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"');
+	${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', ARRAY['gid'] );
 VALUES(7, 'featnames', 'featnames', true, true, false,false, 'a',
Summary of changes:
 extras/tiger_geocoder/tiger_loader_2020.sql | 50 ++++++++++++++---------------
 extras/tiger_geocoder/upgrade_geocode.sql   |  6 ++--
 2 files changed, 28 insertions(+), 28 deletions(-)
hooks/post-receive
