[postgis-tickets] [PostGIS] #4932: Possible Bug with geography ST_Intersects / ST_Distance
PostGIS trac at osgeo.org
Tue Jun 22 07:02:42 PDT 2021
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.1.3
Component:  postgis  |    Version:  master
 Keywords:           |
 Nek on PostGIS noted the documentation for geography ST_Intersects is
 wrong.
 https://postgis.net/docs/ST_Intersects.html
 In the docs it says this should return true
 SELECT ST_Intersects(
                 'SRID=4326;LINESTRING(-43.23456 72.4567,-43.23456
 72.4568)'::geography,
                 'SRID=4326;POINT(-43.23456 72.4567772)'::geography
 But it returns false.  I just checked on my PostGIS 3.2 build and it
 indeed returns false.
 However ST_Distance returns 0
 SELECT ST_Distance(
 Even _ST_DistanceTreet returns 0
 SELECT _ST_DistanceTree(
 However _ST_DistanceUncached returns a small number, so perhaps that is
 what ST_Intersects is using
 SELECT _ST_DistanceUncached(
 returns - 1.4148932702941524e-09
 same answer with PostGIS 3.1.2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4932>
