[postgis-tickets] [PostGIS] #4932: Possible Bug with geography ST_Intersects / ST_Distance
PostGIS trac at osgeo.org
Tue Jun 22 07:06:06 PDT 2021
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.1.3
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> Nek on PostGIS noted the documentation for geography ST_Intersects is
> wrong.
> https://postgis.net/docs/ST_Intersects.html
> In the docs it says this should return true
> SELECT ST_Intersects(
>                 'SRID=4326;LINESTRING(-43.23456 72.4567,-43.23456
> 72.4568)'::geography,
>                 'SRID=4326;POINT(-43.23456 72.4567772)'::geography
> But it returns false.  I just checked on my PostGIS 3.2 build and it
> indeed returns false.
> However ST_Distance returns 0
> SELECT ST_Distance(
> Even _ST_DistanceTreet returns 0
> SELECT _ST_DistanceTree(
> However _ST_DistanceUncached returns a small number, so perhaps that is
> what ST_Intersects is using
> SELECT _ST_DistanceUncached(
> returns - 1.4148932702941524e-09
> same answer with PostGIS 3.1.2
New description:
 wrong.
 SELECT ST_Distance(
 Even _ST_DistanceTree returns 0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4932#comment:1>
