[postgis-tickets] [PostGIS] #5023: berrie64 failing on garden tests
PostGIS trac at osgeo.org
Mon Nov 22 16:47:39 PST 2021
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 3.1.5
Component:  buildbots  |    Version:  3.1.x
 Keywords:             |
 berrie64 got swapped out with a newer berrie64 and sadly she is hanging on
 her garden test run.
 00:18:40 PostgreSQL 13.5 on aarch64-unknown-linux-gnu, compiled by gcc
 (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
 00:18:40   Postgis 3.1.5dev - (77a4e86) - 2021-11-22 05:04:52
 00:18:40   scripts 3.1.5dev 77a4e86
 00:18:40   raster scripts 3.1.5dev 77a4e86
 00:18:40   GEOS: 3.9.0-CAPI-1.16.2
 00:18:40   PROJ: 7.2.1
 00:18:40   GDAL: GDAL 3.2.2, released 2021/03/05
 00:18:40
 00:26:22 -------------------------------------------------
 00:26:22 Regression tests in progress (it will take time)
 00:26:22 Result output: ./regress/postgis_garden_result.txt
 00:26:22 psql --no-psqlrc -ad postgis_garden <
 ../doc/postgis_gardentest_31.sql > postgis_garden_result.txt 2>&1
 17:07:08 make[1]: *** [Makefile:100: garden] Error 2
 17:07:08 make[1]: Leaving directory
 '/home/jenkins/workspace/PostGIS_Worker_Run/label/berrie64/77a4e86e2a22432d6bd56b424d8a48517d91f317/regress'
 17:07:08 make: *** [GNUmakefile:115: garden] Error 2
 17:07:08 Build step 'Execute shell' marked build as failure
 I'll update with forensics after I have checked the forensics
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5023>
