[postgis-tickets] [PostGIS] #5023: berrie64 failing on garden tests
PostGIS trac at osgeo.org
Mon Nov 22 16:58:05 PST 2021
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 3.1.5
 Component:  buildbots  |    Version:  3.1.x
Resolution:             |   Keywords:
Comment (by robe):
 okay the offensive query is this one:
 SELECT ST_MaximumInscribedCircle(foo1.the_geom)  As result
                                                         FROM ((SELECT
 ST_MakePolygon(ST_GeomFromText('LINESTRING(1 2, 1 2,1 2, 1 2)',4326)) As
 the_geom
                         UNION ALL SELECT
 ST_MakePolygon(ST_GeomFromText('LINESTRING(1 2, 1 2,1 2, 1 2, 3 2, 1
 2)',4326)) As the_geom ) ) As foo1 LIMIT 10;
 Works fine on my system:
 POSTGIS="3.2.0dev 3.2.0beta1-24-g677d2019a" [EXTENSION] PGSQL="140"
 GEOS="3.10.0-CAPI-1.16.0" PROJ="7.2.1" GDAL="GDAL 3.3.3, released
 2021/10/25" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0
 (Internal)" (core procs from "3.2.0dev 3.2.0beta1-18-g085cc7f04" need
 upgrade) TOPOLOGY (topology procs from "3.2.0dev 3.2.0beta1-21-g530f7c88c"
 need upgrade) RASTER (raster procs from "3.2.0dev
 3.2.0beta1-18-g085cc7f04" need upgrade)
 , so could be a GEOS 3.9.0 bug fixed in later GEOS.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5023#comment:1>
