[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-698-g5fce0278a
Wed Apr 6 02:47:00 PDT 2022
the project "PostGIS".
       via  5fce0278a40012beb1f05bcb0751dcaffcf2ce42 (commit)
      from  b68342617e17bcdf800613d43b3a4fd2fe7dced5 (commit)
revisions in full, below.
commit 5fce0278a40012beb1f05bcb0751dcaffcf2ce42
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Apr 6 11:46:41 2022 +0200
    Fill in some topology functions availability info
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index ea270ee3d..6acdd550a 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -322,7 +322,7 @@ ERROR:  value for domain topology.topoelementarray violates check constraint "di
                 <para>Valid <varname>feature_type</varname>s are: POINT, LINE, POLYGON, COLLECTION</para>
                 <!-- use this format if new function -->
-                <para>Availability: 1.?</para>
+                <para>Availability: 1.1</para>
 			</refsection>
@@ -376,7 +376,7 @@ SELECT topology.AddTopoGeometryColumn('ri_topo', 'ri', 'roads', 'topo', 'LINE');
                 This function should be USED WITH CAUTION, as it could destroy data you care about.  If the schema does not exist, it just removes reference entries the named schema.</para>
 			</refsection>
@@ -418,7 +418,7 @@ SELECT topology.AddTopoGeometryColumn('ri_topo', 'ri', 'roads', 'topo', 'LINE');
                 of drop status.  NOTE: it first sets all values to NULL before dropping to bypass referential integrity checks.</para>
 			</refsection>
@@ -1019,7 +1019,8 @@ ANALYZE themselves, to use updated statistics.
                 <para>This is similar to the SQL/MM <xref linkend="ST_InitTopoGeo" /> but a bit more functional.  <varname>hasz</varname> defaults to false if not specified.</para>
+                <para>Enhanched: 2.0 added the signature accepting hasZ</para>
 			</refsection>
@@ -1114,7 +1115,7 @@ This example makes a backup of a topology called ma_topo
                 <para>This is an SQL-MM equivalent of CreateTopology but lacks the spatial reference and tolerance options of CreateTopology and outputs a text description of creation instead of topology id.</para>
                 <para>&sqlmm_compliant; SQL-MM 3 Topo-Geo and Topo-Net 3: Routine Details: X.3.17</para>
 			</refsection>
@@ -1390,7 +1391,7 @@ up to caller, see <xref linkend="Topology_StatsManagement"/>.
                 <para>If <varname>aface</varname> is not null and the <varname>apoint</varname> is not within the face, then an exception is thrown.</para>
-                <para>Availability: 1.? </para>
+                <para>Availability: 1.1 </para>
 	<para>&sqlmm_compliant; SQL-MM: Topo-Net Routines:  X+1.3.1</para>
 			</refsection>
@@ -1437,7 +1438,7 @@ up to caller, see <xref linkend="Topology_StatsManagement"/>.
                 <para>If the <varname>anode</varname> and <varname>anothernode</varname> are not the start and end points of the <varname>alinestring</varname> then an exception is thrown.</para>
 	<para>&sqlmm_compliant; SQL-MM: Topo-Geo and Topo-Net 3: Routine Details:  X.3.4</para>
 			</refsection>
@@ -2102,7 +2103,7 @@ SELECT topology.ST_NewEdgesSplit('ma_topo', 2,  ST_GeomFromText('POINT(227578.5
 	<para>&sqlmm_compliant; SQL-MM: Topo-Geo and Topo-Net 3: Routine Details:  X+1.3.3</para>
 			</refsection>
@@ -2149,7 +2150,7 @@ SELECT topology.ST_RemoveIsoNode('ma_topo',  7 ) As result;
 			</refsection>
@@ -2423,7 +2424,7 @@ ERROR:  Two or more faces found</programlisting>
                 <para>Returns the id of a topology in the topology.topology table given the name of the topology.</para>
 			</refsection>
@@ -2513,7 +2514,7 @@ ERROR:  Two or more faces found</programlisting>
                 <para>Returns the topology name (schema) of a topology from the topology.topology table given the topology id of the topology.</para>
 			</refsection>
@@ -2632,7 +2633,7 @@ FROM topology.ST_GetFaceEdges('tt',1) As t(seq,edge)
 	<para>&sqlmm_compliant; SQL-MM 3 Topo-Geo and Topo-Net 3: Routine Details: X.3.16</para>
 			</refsection>
@@ -3137,7 +3138,7 @@ faceid
 	and collections can be formed from a mixture of nodes, edges, and faces.</para>
                 <para>Omitting the array of components generates an empty TopoGeometry object.</para>
 			</refsection>
@@ -3639,7 +3640,7 @@ Refer to <xref linkend="toTopoGeom" />.
                 <para>tg_id is the topogeometry id of the topogeometry object in the topology in the layer denoted by <varname>layer_id</varname> in the topology.layer table.</para>
 			</refsection>
diff --git a/topology/sql/manage/CreateTopology.sql.in b/topology/sql/manage/CreateTopology.sql.in
index a637e5487..c7fe5709a 100644
--- a/topology/sql/manage/CreateTopology.sql.in
+++ b/topology/sql/manage/CreateTopology.sql.in
@@ -21,6 +21,8 @@
 -- in the topology.topology relation, return it's numeric
 -- id.
+-- Availability: 2.0.0
 CREATE OR REPLACE FUNCTION topology.CreateTopology(atopology varchar, srid integer, prec float8, hasZ boolean)
 RETURNS integer
 AS
@@ -267,18 +269,21 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 --{ CreateTopology wrappers for unspecified srid or precision or hasZ
 --  CreateTopology(name, SRID, precision) -- hasZ = false
+-- Availability: 1.1.0
 CREATE OR REPLACE FUNCTION topology.CreateTopology(toponame varchar, srid integer, prec float8)
 RETURNS integer AS
 ' SELECT topology.CreateTopology($1, $2, $3, false);'
 LANGUAGE 'sql' VOLATILE STRICT;
 --  CreateTopology(name, SRID) -- precision = 0
 CREATE OR REPLACE FUNCTION topology.CreateTopology(varchar, integer)
 RETURNS integer AS
 ' SELECT topology.CreateTopology($1, $2, 0); '
 --  CreateTopology(name) -- srid = unknown, precision = 0
 CREATE OR REPLACE FUNCTION topology.CreateTopology(varchar)
 RETURNS integer AS
 $$ SELECT topology.CreateTopology($1, ST_SRID('POINT EMPTY'::geometry), 0); $$
diff --git a/topology/sql/sqlmm.sql.in b/topology/sql/sqlmm.sql.in
index a2f41d310..4ff6a51a2 100644
--- a/topology/sql/sqlmm.sql.in
+++ b/topology/sql/sqlmm.sql.in
@@ -25,6 +25,8 @@
 -- Type returned by ST_GetFaceEdges
 CREATE TYPE topology.GetFaceEdges_ReturnType AS (
   sequence integer,
   edge integer
@@ -36,7 +38,7 @@ CREATE TYPE topology.GetFaceEdges_ReturnType AS (
 --  ST_GetFaceEdges(atopology, aface)
 CREATE OR REPLACE FUNCTION topology.ST_GetFaceEdges(toponame varchar, face_id integer)
   RETURNS SETOF topology.GetFaceEdges_ReturnType AS
@@ -146,6 +148,8 @@ CREATE OR REPLACE FUNCTION topology.ST_GetFaceGeometry(toponame varchar, aface i
 --  ST_AddIsoNode(atopology, aface, apoint)
 CREATE OR REPLACE FUNCTION topology.ST_AddIsoNode(atopology varchar, aface integer, apoint geometry)
   RETURNS INTEGER AS
 	'MODULE_PATHNAME','ST_AddIsoNode'
@@ -170,6 +174,8 @@ CREATE OR REPLACE FUNCTION topology.ST_MoveIsoNode(atopology character varying,
 --  ST_RemoveIsoNode(atopology, anode)
 CREATE OR REPLACE FUNCTION topology.ST_RemoveIsoNode(atopology varchar, anode integer)
   RETURNS TEXT AS
 	'MODULE_PATHNAME','ST_RemoveIsoNode'
@@ -193,6 +199,8 @@ CREATE OR REPLACE FUNCTION topology.ST_RemIsoNode(varchar, integer)
 --  ST_RemoveIsoEdge(atopology, anedge)
 CREATE OR REPLACE FUNCTION topology.ST_RemoveIsoEdge(atopology varchar, anedge integer)
   RETURNS TEXT AS
 	'MODULE_PATHNAME','ST_RemIsoEdge'
@@ -241,6 +249,8 @@ CREATE OR REPLACE FUNCTION topology.ST_ModEdgeSplit(atopology varchar, anedge in
 -- * Refuse to add a closed edge, as it would not be isolated
 --   (ie: would create a ring)
 CREATE OR REPLACE FUNCTION topology.ST_AddIsoEdge(atopology varchar, anode integer, anothernode integer, acurve geometry)
@@ -343,6 +353,8 @@ CREATE OR REPLACE FUNCTION topology.ST_AddEdgeModFace(atopology varchar, anode i
 --  ST_InitTopoGeo(atopology)
 CREATE OR REPLACE FUNCTION topology.ST_InitTopoGeo(atopology varchar)
 RETURNS text
 AS
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index ebc62a5af..50f408d38 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -542,6 +542,7 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 --  Add a TopoGeometry column to a table, making it a topology layer.
 --  Returns created layer id.
 CREATE OR REPLACE FUNCTION topology.AddTopoGeometryColumn(toponame varchar, schema varchar, tbl varchar, col varchar, ltype varchar, child integer)
   RETURNS integer
@@ -712,6 +713,7 @@ LANGUAGE 'sql' VOLATILE;
 --  Drop a TopoGeometry column, unregister the associated layer,
 --  cleanup the relation table.
 CREATE OR REPLACE FUNCTION topology.DropTopoGeometryColumn(schema varchar, tbl varchar, col varchar)
   RETURNS text
@@ -886,6 +888,8 @@ LANGUAGE 'sql' VOLATILE;
 -- Return a topology.TopoGeometry object.
 CREATE OR REPLACE FUNCTION topology.CreateTopoGeom(toponame varchar, tg_type integer, layer_id integer, tg_objs topology.TopoElementArray)
   RETURNS topology.TopoGeometry
 AS
@@ -1007,6 +1011,7 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 -- CreateTopoGeom(topology_name, topogeom_type, layer_id) - creates the empty topogeom
 CREATE OR REPLACE FUNCTION topology.CreateTopoGeom(toponame varchar, tg_type integer, layer_id integer)
 AS
@@ -1018,7 +1023,9 @@ $$ LANGUAGE 'sql' VOLATILE STRICT;
 -- GetTopologyName(topology_id)
--- TODO: rewrite in SQL ?
+-- TODO: rewrite in SQL, as a wrapper around findTopology
 CREATE OR REPLACE FUNCTION topology.GetTopologyName(topoid integer)
   RETURNS varchar
@@ -1038,7 +1045,9 @@ LANGUAGE 'plpgsql' STABLE STRICT;
 -- GetTopologyId(toponame)
 CREATE OR REPLACE FUNCTION topology.GetTopologyId(toponame varchar)
   RETURNS integer
@@ -1076,6 +1085,8 @@ $$ LANGUAGE 'sql' STABLE STRICT;
 -- Returns a set of element_id,element_type
 CREATE OR REPLACE FUNCTION topology.GetTopoGeomElementArray(toponame varchar, layer_id integer, tgid integer)
   RETURNS topology.TopoElementArray
 AS
@@ -1440,6 +1451,8 @@ CREATE CAST (topology.TopoGeometry AS Geometry) WITH FUNCTION topology.Geometry(
 -- Drops a topology schema getting rid of every dependent object.
 CREATE OR REPLACE FUNCTION topology.DropTopology(atopology varchar)
 RETURNS text
 AS
Summary of changes:
 doc/extras_topology.xml                   | 29 +++++++++++++++--------------
 topology/sql/manage/CreateTopology.sql.in |  5 +++++
 topology/sql/sqlmm.sql.in                 | 14 +++++++++++++-
 topology/topology.sql.in                  | 17 +++++++++++++++--
 4 files changed, 48 insertions(+), 17 deletions(-)
hooks/post-receive
