[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-699-gfdea0c84a
Wed Apr 6 02:56:15 PDT 2022
the project "PostGIS".
       via  fdea0c84adcfdfeba432110bd99d7a5aaa35672e (commit)
      from  5fce0278a40012beb1f05bcb0751dcaffcf2ce42 (commit)
revisions in full, below.
commit fdea0c84adcfdfeba432110bd99d7a5aaa35672e
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Apr 6 11:56:07 2022 +0200
    More availability info
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 6acdd550a..168e7bd3a 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -1818,7 +1818,7 @@ Returns the identifier of the newly added node.
 		</para>
                 <!-- use this format if new function -->
-                <para>Availability: 1.? </para>
+                <para>Availability: 1.1 </para>
                 <para>Changed: 2.0 - In prior versions, this was misnamed ST_ModEdgesSplit</para>
                 <para>&sqlmm_compliant; SQL-MM: Topo-Geo and Topo-Net 3: Routine Details:  X.3.9</para>
 			</refsection>
@@ -2046,7 +2046,7 @@ Updates all existing joined edges and relationships accordingly.
 	<para>&sqlmm_compliant; SQL-MM: Topo-Net Routines:  X.3.8</para>
 			</refsection>
diff --git a/topology/sql/sqlmm.sql.in b/topology/sql/sqlmm.sql.in
index 4ff6a51a2..ec2d02c5e 100644
--- a/topology/sql/sqlmm.sql.in
+++ b/topology/sql/sqlmm.sql.in
@@ -216,6 +216,8 @@ CREATE OR REPLACE FUNCTION topology.ST_RemoveIsoEdge(atopology varchar, anedge i
 -- Not in the specs:
 -- * Update references in the Relation table.
+-- Availability: 1.1.0
 CREATE OR REPLACE FUNCTION topology.ST_NewEdgesSplit(atopology varchar, anedge integer, apoint geometry)
   RETURNS INTEGER AS
   'MODULE_PATHNAME','ST_NewEdgesSplit'
@@ -231,6 +233,9 @@ CREATE OR REPLACE FUNCTION topology.ST_NewEdgesSplit(atopology varchar, anedge i
+-- Availability: 2.0.0
+-- Replaces ST_ModEdgesSplit(varchar, integer, geometry) deprecated in 2.0.0
 CREATE OR REPLACE FUNCTION topology.ST_ModEdgeSplit(atopology varchar, anedge integer, apoint geometry)
   RETURNS INTEGER AS
 	'MODULE_PATHNAME','ST_ModEdgeSplit'
Summary of changes:
 doc/extras_topology.xml   | 4 ++--
 topology/sql/sqlmm.sql.in | 5 +++++
 2 files changed, 7 insertions(+), 2 deletions(-)
hooks/post-receive
