[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-708-gcbf528321
Sun Apr 10 20:13:13 PDT 2022
the project "PostGIS".
       via  cbf528321b94cd859b9012c0084a7c274b3e6493 (commit)
      from  6a6cc54bdf1315da8e8c8401575c179aa8727daf (commit)
revisions in full, below.
commit cbf528321b94cd859b9012c0084a7c274b3e6493
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Apr 10 23:13:07 2022 -0400
    Fix search path function.  References #5125 and #5126 for PostGIS 3.3.0
diff --git a/extensions/postgis_extension_helper.sql b/extensions/postgis_extension_helper.sql
index fe6ed9ba9..ab5e654db 100644
--- a/extensions/postgis_extension_helper.sql
+++ b/extensions/postgis_extension_helper.sql
@@ -119,8 +119,8 @@ BEGIN
 			WHERE datname = current_database()
 		) and setrole = 0
-	SELECT regexp_replace(c, '^search_path=', '')
-	FROM settings WHERE c like 'search_path=%'
+	SELECT regexp_replace(config, '^search_path=', '')
+	FROM settings WHERE config like 'search_path=%'
 	INTO var_cur_search_path;
 	RAISE NOTICE 'cur_search_path from pg_db_role_setting is %', var_cur_search_path;
Summary of changes:
 extensions/postgis_extension_helper.sql | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
