[postgis-tickets] [PostGIS] #5127: gdal_warp regression
PostGIS trac at osgeo.org
Sun Apr 10 21:25:33 PDT 2022
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 2.5.6
Component:  raster   |    Version:  2.5.x
 Keywords:           |
 Might be something funky with my system, but I've getting a gdal_warp
 regression.
 PostgreSQL 11.2 on x86_64-pc-mingw64, compiled by gcc.exe (x86_64-posix-
 seh-rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
   Postgis 2.5.6 - r17978 - 2022-04-11 04:10:19
   scripts 2.5.6 r17978
   raster scripts 2.5.6 r17978
   GEOS: 3.8.3-CAPI-1.13.4
   PROJ: Rel. 7.2.1, January 1st, 2021
   GDAL: GDAL 3.2.3, released 2021/04/27
  rt_gdalwarp .. failed (diff expected obtained:
 /projects/postgis/tmp/2.5.5_pg11_geos3.8_gdal3.2.3w64/test_52_diff)
 --- rt_gdalwarp_expected        2022-02-07 00:07:57.795553200 -0500
 +++ /projects/postgis/tmp/2.5.5_pg11_geos3.8_gdal3.2.3w64/test_52_out
 2022-04-11 00:21:44.006782200 -0400
 @@ -8,26 +8,26 @@
  NOTICE:  Values must be provided for both X and Y when specifying the
 scale.  Returning original raster
  0.0|||||||||||||
 -0.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 +0.1|993310|12|12|1|1007.893|-1007.893|0.000|0.000|952282.217|1409722.366|t|t|t
 0.10|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 0.11|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
 0.12|992163|10|11|1|1000.000|-1000.000|0.000|0.000|-500000.000|600009.000|t|t|t
 0.13|992163|11|11|1|1000.000|-1000.000|0.000|0.000|-500100.000|600950.000|t|t|t
 0.14|992163|201|201|1|50.000|50.000|0.000|0.000|-500040.000|589957.000|t|t|t
 0.15|992163|84|84|1|121.000|121.000|0.000|0.000|-500093.000|589875.000|t|t|t
 -0.16|993310|243|243|1|50.000|50.000|0.000|0.000|950710.000|1397157.000|t|t|t
 -0.17|993309|243|243|1|50.000|50.000|0.000|0.000|950760.000|1396957.000|t|t|t
 +0.16|993310|243|243|1|50.000|50.000|0.000|0.000|952260.000|1397607.000|t|t|t
 +0.17|993309|243|243|1|50.000|50.000|0.000|0.000|952360.000|1397407.000|t|t|t
 0.18|992163|10|10|1|1000.000|-1000.000|3.000|3.000|-500030.000|600000.000|t|t|t
 -0.19|993310|12|12|1|1009.894|-1009.894|3.000|3.000|950691.792|1409281.783|t|t|t
 -0.21|993310|24|24|1|500.000|500.000|3.000|3.000|950657.188|1397356.783|t|t|t
 -0.22|993310|26|26|1|500.000|500.000|0.000|6.000|950452.000|1396632.000|t|t|t
 -0.23|984269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 -0.24|974269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 +0.19|993310|12|12|1|1007.893|-1007.893|3.000|3.000|952241.901|1409722.366|t|t|t
 +0.21|993310|24|24|1|500.000|500.000|3.000|3.000|952207.217|1397797.366|t|t|t
 +0.22|993310|25|25|1|500.000|500.000|0.000|6.000|951952.000|1397614.000|t|t|t
 +0.23|984269|12|8|1|0.012|-0.012|0.000|0.000|-107.007|50.208|t|t|t
 +0.24|974269|12|8|1|0.012|-0.012|0.000|0.000|-107.007|50.208|t|t|t
  0.25|0|5|5|1|2.000|-2.000|0.000|0.000|0.000|0.000|t|t|t
  0.26|0|2|2|1|5.000|-5.000|0.000|0.000|0.000|0.000|t|t|t
  0.27|0|100|100|1|0.100|-0.100|0.000|0.000|0.000|0.000|t|t|t
 -0.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 -0.4|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 +0.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.007|50.208|t|t|t
 +0.4|993310|24|24|1|500.000|500.000|0.000|0.000|952282.217|1397722.366|t|t|t
 0.5|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 0.6|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 0.7|992163|20|20|1|500.000|500.000|0.000|0.000|-500000.000|590000.000|t|t|t
 @@ -59,19 +59,19 @@
 1.7|992163|40|40|1|250.000|250.000|0.000|0.000|-500000.000|590000.000|t|t|t
 1.8|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
 1.9|992163|11|10|1|1000.000|-1000.000|0.000|0.000|-500001.000|600000.000|t|t|t
 -2.1|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 -2.10|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.12|993310|6|6|1|2000.000|2000.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.13|993310|8|8|1|1500.000|1500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.14|993310|24|24|1|500.000|500.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.15|993310|16|16|1|750.000|750.000|0.000|0.000|950732.188|1397281.783|t|t|t
 -2.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.029|50.206|t|t|t
 +2.1|993310|12|12|1|1007.893|-1007.893|0.000|0.000|952282.217|1409722.366|t|t|t
 +2.10|993310|24|24|1|500.000|500.000|0.000|0.000|952282.217|1397722.366|t|t|t
 +2.12|993310|6|6|1|2000.000|2000.000|0.000|0.000|952282.217|1397722.366|t|t|t
 +2.13|993310|8|8|1|1500.000|1500.000|0.000|0.000|952282.217|1397722.366|t|t|t
 +2.14|993310|24|24|1|500.000|500.000|0.000|0.000|952282.217|1397722.366|t|t|t
 +2.15|993310|16|16|1|750.000|750.000|0.000|0.000|952282.217|1397722.366|t|t|t
 +2.3|994269|12|8|1|0.012|-0.012|0.000|0.000|-107.007|50.208|t|t|t
  2.4|||||||||||||
 -2.5|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 +2.5|993310|12|12|1|1007.893|-1007.893|0.000|0.000|952282.217|1409722.366|t|t|t
  2.6|||||||||||||
 -2.7|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 -2.8|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 -2.9|993310|12|12|1|1009.894|-1009.894|0.000|0.000|950732.188|1409281.783|t|t|t
 +2.7|993310|12|12|1|1007.893|-1007.893|0.000|0.000|952282.217|1409722.366|t|t|t
 +2.8|993310|12|12|1|1007.893|-1007.893|0.000|0.000|952282.217|1409722.366|t|t|t
 +2.9|993310|12|12|1|1007.893|-1007.893|0.000|0.000|952282.217|1409722.366|t|t|t
 3.1|992163|100|100|1|100.000|100.000|0.000|0.000|-500000.000|590000.000|t|t|t
 3.2|992163|100|100|1|100.000|100.000|0.000|0.000|-500000.000|590000.000|t|t|t
 3.3|992163|10|10|1|1000.000|-1000.000|0.000|0.000|-500000.000|600000.000|t|t|t
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5127>
