[postgis-tickets] [PostGIS] #5128: Integrate tiger_geocoder tests to `make check` rule
PostGIS trac at osgeo.org
Mon Apr 11 07:32:40 PDT 2022
 Reporter:  strk            |      Owner:  robe
     Type:  task            |     Status:  new
 Priority:  medium          |  Milestone:  PostGIS 3.3.0
Component:  tiger geocoder  |    Version:  master
 Keywords:                  |
 I see tests under extras/tiger_geocoder/regress and I see --tiger switch
 support in run_test.pl (partial, as it ONLY works with --extension) but I
 don't see tiger tests being ever run by `make check`
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5128>
