[postgis-tickets] [PostGIS] #5128: Integrate tiger_geocoder tests to `make check` rule
PostGIS trac at osgeo.org
Mon Apr 11 08:34:41 PDT 2022
  Reporter:  strk            |      Owner:  robe
      Type:  task            |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.3.0
 Component:  tiger geocoder  |    Version:  master
Resolution:                  |   Keywords:
Comment (by robe):
 Those can't be included in run_test.pl.  The only tests that can be
 included are the ones in extensions/postgis_tiger_geocoder/sql folder that
 start with test-
 The ones in extras require tiger data to be loaded before they'll work.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5128#comment:1>
