[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-710-g9f249630e
Mon Apr 11 13:48:39 PDT 2022
the project "PostGIS".
       via  9f249630ecf9723b043ec76d151b3b24464ffb1b (commit)
      from  ccc2a38d0d9726818953c63017bf3b59303019c5 (commit)
revisions in full, below.
commit 9f249630ecf9723b043ec76d151b3b24464ffb1b
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Apr 11 17:07:37 2022 +0200
    Have installcheck (or RUNTESTFLAGS=--extension) also load tiger
    Make typmod test survive presence of tiger extension
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 76edf3f87..5ecc286ab 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -202,6 +202,7 @@ topsrcdir = $(top_srcdir)
 include $(top_builddir)/regress/core/tests.mk
 include $(top_srcdir)/regress/loader/tests.mk
 include $(top_srcdir)/regress/dumper/tests.mk
+include $(top_srcdir)/extensions/postgis_tiger_geocoder/tests.mk
 ifeq ($(HAVE_SFCGAL),yes)
 	override RUNTESTFLAGS := $(RUNTESTFLAGS) --sfcgal
 	include $(top_srcdir)/sfcgal/regress/tests.mk
diff --git a/extensions/postgis_tiger_geocoder/tests.mk b/extensions/postgis_tiger_geocoder/tests.mk
new file mode 100644
index 000000000..5991bca7c
--- /dev/null
+++ b/extensions/postgis_tiger_geocoder/tests.mk
@@ -0,0 +1,6 @@
+# TODO: always pass --tiger when run_test.pl supports it non-extension based
+# TODO: run actual tests
+ifeq (,$(findstring --extension,$(RUNTESTFLAGS)))
+  override RUNTESTFLAGS := $(RUNTESTFLAGS) --tiger
+endif
diff --git a/regress/core/typmod.sql b/regress/core/typmod.sql
index 5fcec8faa..108e772d6 100644
--- a/regress/core/typmod.sql
+++ b/regress/core/typmod.sql
@@ -216,7 +216,9 @@ CREATE TABLE tm.trianglezm4326 (id serial, g geometry(trianglezm, 4326) );
 SELECT 'g',
  f_table_name, f_geometry_column,
  coord_dimension, srid, type
-from geometry_columns ORDER BY f_table_name;
+from geometry_columns
+where f_table_schema != 'tiger'
+ORDER BY f_table_name;
 SELECT 'gg',
  f_table_name, f_geography_column,
@@ -224,6 +226,7 @@ SELECT 'gg',
 from geography_columns ORDER BY f_table_name;
 SELECT distinct 'catalog-schema', f_table_catalog = current_database(),f_table_schema FROM geometry_columns
 UNION
 SELECT distinct 'catalog-schema', f_table_catalog = current_database(),f_table_schema FROM geography_columns
@@ -288,8 +291,10 @@ BEGIN
 		EXECUTE sql;
 	END LOOP;
-	FOR rec IN SELECT * from geometry_columns
-		WHERE f_table_name != 'types' ORDER BY 3
+	FOR rec IN SELECT * FROM geometry_columns
+		WHERE f_table_name != 'types'
+		AND f_table_schema != 'tiger'
+		ORDER BY 3
 	LOOP
 		out_where := rec.f_table_name;
Summary of changes:
 GNUmakefile.in                             |  1 +
 extensions/postgis_tiger_geocoder/tests.mk |  6 ++++++
 regress/core/typmod.sql                    | 11 ++++++++---
 3 files changed, 15 insertions(+), 3 deletions(-)
 create mode 100644 extensions/postgis_tiger_geocoder/tests.mk
hooks/post-receive
