[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-711-g5bb5a91c8
Mon Apr 11 15:11:07 PDT 2022
the project "PostGIS".
       via  5bb5a91c807cfc85a3b50c577dfbaf8950fa17db (commit)
      from  9f249630ecf9723b043ec76d151b3b24464ffb1b (commit)
revisions in full, below.
commit 5bb5a91c807cfc85a3b50c577dfbaf8950fa17db
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Apr 11 14:51:35 2022 -0700
    Alter check_tests_enabled.sh to also work on MacOS
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index c709e81f3..8f28e38f7 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -18,9 +18,9 @@ override RUNTESTFLAGS_INTERNAL := \
   --after-upgrade-script $(topsrcdir)/topology/test/regress/hooks/hook-after-upgrade-topology.sql
 TESTS += \
-  $(topsrcdir)/topology/test/regress/addedge.sql \
+	$(topsrcdir)/topology/test/regress/addedge.sql \
 	$(topsrcdir)/topology/test/regress/addface2.5d.sql \
-  $(topsrcdir)/topology/test/regress/addface.sql \
+	$(topsrcdir)/topology/test/regress/addface.sql \
 	$(topsrcdir)/topology/test/regress/addnode.sql \
 	$(topsrcdir)/topology/test/regress/addtopogeometrycolumn.sql \
 	$(topsrcdir)/topology/test/regress/cleartopogeom.sql \
diff --git a/utils/check_tests_enabled.sh b/utils/check_tests_enabled.sh
index 1e518b44e..d14ec4fb0 100755
--- a/utils/check_tests_enabled.sh
+++ b/utils/check_tests_enabled.sh
@@ -21,18 +21,25 @@ check_enabled() {
   suffix=$2
   bd=`dirname ${mk}`/${suffix}
-  #echo "MK file: ${mk}"
+  #cho "MK file: ${mk}"
   #echo "Suffix: ${suffix}"
   #echo "Basedir: ${bd}"
   grep 'topsrcdir)' ${mk} |
       sed 's|.*topsrcdir)/||;s/ .*$//' |
       sed 's|\\||' |
-      sed 's|\.sql\>||' > ${TMPDIR}/enabled_tests
+      sed 's/\.sql$//' > ${TMPDIR}/enabled_tests
+  #cat ${TMPDIR}/enabled_tests
   find ${bd} -name '*.sql' |
+    grep -v '\-post.sql' | grep -v '\-pre.sql' |
+    sed 's|\.select.sql$||' |
+    sed 's|//|/|' |
     sed 's|\.sql$||' > ${TMPDIR}/available_tests
+  #cat ${TMPDIR}/available_tests
   MISSING=`grep -vf ${TMPDIR}/enabled_tests ${TMPDIR}/available_tests`
   if test -n "${MISSING}"; then
@@ -69,7 +76,7 @@ if [ -z "${RD}" ]; then
 fi
 cd ${RD}
-check_enabled topology/test/tests.mk regress &&
+check_enabled topology/test/tests.mk regress #&&
 check_enabled regress/loader/tests.mk &&
 check_enabled regress/dumper/tests.mk &&
 check_enabled sfcgal/regress/tests.mk &&
Summary of changes:
 topology/test/tests.mk       |  4 ++--
 utils/check_tests_enabled.sh | 13 ++++++++++---
 2 files changed, 12 insertions(+), 5 deletions(-)
hooks/post-receive
