[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-717-gc49ab54d2
Tue Apr 12 00:35:09 PDT 2022
the project "PostGIS".
       via  c49ab54d2c3f1e502c8f47907a100ddaa0a87018 (commit)
      from  b1359fa3258740fba126bf6fcc5d49c68f0c585d (commit)
revisions in full, below.
commit c49ab54d2c3f1e502c8f47907a100ddaa0a87018
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Apr 12 00:12:11 2022 +0200
    Fix handling of RUNTESTFLAGS make argument with installcheck
    Closes #5130
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 5ecc286ab..b27471be8 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -68,14 +68,14 @@ check-no-trailing-blanks:
 installcheck: installcheck-base installcheck-upgrade
 installcheck-base:
-	RUNTESTFLAGS="$(RUNTESTFLAGS) --extension" $(MAKE) check-regress
+	$(MAKE) check-regress RUNTESTFLAGS="$(RUNTESTFLAGS) --extension"
 # only run upgrade test if RUNTESTFLAGS was not already doing that
 installcheck-upgrade: installcheck-upgrade-byfunc
 	if test -z `echo "$(RUNTESTFLAGS)" | grep -- --upgrade`; then \
-		RUNTESTFLAGS="$(RUNTESTFLAGS) --extension \
-			--upgrade-path unpackaged--$(POSTGIS_MAJOR_VERSION).$(POSTGIS_MINOR_VERSION).$(POSTGIS_MICRO_VERSION)" \
-			$(MAKE) check-regress; \
+		$(MAKE) check-regress \
+			RUNTESTFLAGS="$(RUNTESTFLAGS) --extension \
+			--upgrade-path unpackaged--$(POSTGIS_MAJOR_VERSION).$(POSTGIS_MINOR_VERSION).$(POSTGIS_MICRO_VERSION)"; \
 	fi
Summary of changes:
 GNUmakefile.in | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
