[postgis-tickets] [PostGIS] #5140: Make PostGIS 2.4 regress cleanly also against newer GDAL and GEOS 3.8
PostGIS trac at osgeo.org
Fri Apr 22 07:24:04 PDT 2022
 Reporter:  robe                   |      Owner:  robe
     Type:  defect                 |     Status:  assigned
 Priority:  blocker                |  Milestone:  PostGIS 2.4.10
Component:  build/upgrade/install  |    Version:  2.4.x
 Keywords:                         |
 Right now 2.4 is failing on all platforms we have.
 Issues I have run into that we had already backported to 2.5
 1. Topology failures with GEOS > 3.7
  regress/topogeo_addlinestring .. failed (diff expected obtained:
 /projects/postgis/tmp/2.4.10dev_pg11_geos3.8_gdal3.4.2w64/test_29_diff)
 --- regress/topogeo_addlinestring_expected      2022-04-22
 10:15:56.047196700 -0400
 +++ /projects/postgis/tmp/2.4.10dev_pg11_geos3.8_gdal3.4.2w64/test_29_out
 2022-04-22 10:16:39.574665700 -0400
 @@ -85,10 +85,10 @@
  contains|25
  contains|47
  contains|48
 -N|42||POINT(7 36)
 -N|43||POINT(14 34)
 -E|47|sn21|en42
 -E|48|sn43|en22
 +N|42||POINT(14 34)
 +N|43||POINT(7 36)
 +E|47|sn42|en22
 +E|48|sn21|en43
 2. GDAL failures, most of these are because of order changes, most were
 fixed by backporting some tests from 2.5 and 3.0 (some covered in #5127)
 3. Some GDAL raster issues mostly around 32-bit (though we have no bots
 that we can test against 32-bit).  I did find some obvious errors fixed
 also in 2.5 I intend to backport.  Covered in #3994 and #4102
 4. Winnie can't build address standardizer (I think because of her newer
 autoconf, so have to support pkg-config) detailed in #5126
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5140>
