[postgis-tickets] [PostGIS] #5140: Make PostGIS 2.4 regress cleanly also against newer GDAL and GEOS 3.8
PostGIS trac at osgeo.org
Fri Apr 22 07:25:23 PDT 2022
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  assigned
  Priority:  blocker                |  Milestone:  PostGIS 2.4.10
 Component:  build/upgrade/install  |    Version:  2.4.x
Resolution:                         |   Keywords:
Description changed by robe:
Old description:
> Right now 2.4 is failing on all platforms we have.
> Issues I have run into that we had already backported to 2.5
> 1. Topology failures with GEOS > 3.7
>  regress/topogeo_addlinestring .. failed (diff expected obtained:
> /projects/postgis/tmp/2.4.10dev_pg11_geos3.8_gdal3.4.2w64/test_29_diff)
> --- regress/topogeo_addlinestring_expected      2022-04-22
> 10:15:56.047196700 -0400
> +++ /projects/postgis/tmp/2.4.10dev_pg11_geos3.8_gdal3.4.2w64/test_29_out
> 2022-04-22 10:16:39.574665700 -0400
> @@ -85,10 +85,10 @@
>  contains|25
>  contains|47
>  contains|48
> -N|42||POINT(7 36)
> -N|43||POINT(14 34)
> -E|47|sn21|en42
> -E|48|sn43|en22
> +N|42||POINT(14 34)
> +N|43||POINT(7 36)
> +E|47|sn42|en22
> +E|48|sn21|en43
> 2. GDAL failures, most of these are because of order changes, most were
> fixed by backporting some tests from 2.5 and 3.0 (some covered in #5127)
> 3. Some GDAL raster issues mostly around 32-bit (though we have no bots
> that we can test against 32-bit).  I did find some obvious errors fixed
> also in 2.5 I intend to backport.  Covered in #3994 and #4102
> 4. Winnie can't build address standardizer (I think because of her newer
> autoconf, so have to support pkg-config) detailed in #5126
New description:
 @@ -85,10 +85,10 @@
  contains|25
  contains|47
  contains|48
 -N|42||POINT(7 36)
 -N|43||POINT(14 34)
 -E|47|sn21|en42
 -E|48|sn43|en22
 +N|42||POINT(14 34)
 +N|43||POINT(7 36)
 +E|47|sn42|en22
 +E|48|sn21|en43
  regress/topogeo_addpolygon .. failed (diff expected obtained:
 /projects/postgis/tmp/2.4.10dev_pg11_geos3.8_gdal3.4.2w64/test_31_diff)
 --- regress/topogeo_addpolygon_expected 2022-04-21 14:53:22.166658300
 -0400
 +++ /projects/postgis/tmp/2.4.10dev_pg11_geos3.8_gdal3.4.2w64/test_31_out
 2022-04-22 10:16:41.114831800 -0400
 @@ -32,8 +32,8 @@
  N|26||POINT(28 18)
  E|30|sn14|en26
  E|31|sn26|en18
 -E|32|sn26|en13
 -E|33|sn17|en26
 +E|32|sn17|en26
 +E|33|sn26|en13
  F|14
  F|15
  ex_hole|3
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5140#comment:1>
