[postgis-tickets] [PostGIS] #5194: SELECT postgis_extensions_upgrade() fails with pgextwlist
PostGIS trac at osgeo.org
Mon Aug 1 09:56:20 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by robe):
 Replying to [comment:8 strk]:
 > I'm working on an alternative setup in which rather than messing the
 catalog tables to set our version to 'ANY' we install 0-bytes upgrade
 paths from any supported version to `ANY`, which does the SAME thing as
 the catalog update but using `ALTER EXTENSION UPDATE` instead of `UPDATE
 pg_extension`. It will still be good to try the direct catalog update in
 case those `<version>--ANY` upgrade files are missing for any reason
 (package managers end up dropping them or users want to avoid having all
 those files around). The work in progress is in an `upgrade-paths` branch
 in official repository
 Doesn't that still suffer from the issue of, if a user uninstalls a
 version before they upgrade, they are missing that
 <my current version>--ANY.sql
 script and since the new install won't provide that, they are still stuck?
 or is that where your make target comes into play, to install these
 missing files?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5194#comment:9>
