[postgis-tickets] [PostGIS] #5194: SELECT postgis_extensions_upgrade() fails with pgextwlist
PostGIS trac at osgeo.org
Wed Aug 3 23:04:26 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 Here's the pull request with the code I described in my previous comment:
 https://git.osgeo.org/gitea/postgis/postgis/pulls/104
 We'll still be installing the upgrade paths for OLDER versions, so this
 change does NOT help with the problem of filling up the disk (#5092) but
 should fix the pgextwlist problem (as soon as I also change
 postgis_extensions_upgrade() to not mess with system catalogs)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5194#comment:10>
